DIY: Installing Injen CAI on 03-07 Accord I4 - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > DIY
Old 03-31-2010, 09:17 PM
braddtm's Avatar
braddtm braddtm is offline
4th Gear
Send a message via AIM to braddtm
How to install an Injen Cold Air Intake(CAI) or Short Ram Intake(SRI) on a 2003-2007 Honda Accord I4. My DIY is for an Injen Brand Intake, but other Brands should be similar.
Takes about less than an hour to install, depending how well you know your car/know how to take things apart.
Tools:
Phillips and Flat screwdriver
10mm Socket
8mm Socket(Optional)
Socket Extension(Optional)
Socket Wrench
Pliers
Step 1: Removing Front Bumper
I followed these instructions to remove my bumper:
http://www.driveaccord.net/forums/sh...ad.php?t=20581
GOING UNDER
1. Remove the 6 plastic clips on the bottom(Using a Flat Screwdriver
2. Remove 2 bolts from each side also on the bottom [A] (Using a 10mm Socket)
….Forgot about those Non-Ricer friendly driveways after my drop
1. Remove both screws by the front fender well (Using a Phillips Screwdriver)
UPTOP
1. Remove 8 more plastic clips on the top (coming out to a total of 14 clips) [B]
2. Remove the 2 side screw clips [A]
Step 2: REMOVING THE STOCK AIRBOX
1. Remove the 2 bolts where the filter is at(Using a 10mm Socket)
1.Remove the Vent Chamber…You should be able to just pull it out
1. Remove this sensor using a plier to squeeze the clamps
1. Remove the clamp holding the stock airbox tube using a Phillips Screwdriver
Step 3: INSTALLING NEW INJEN INTAKE (DON”T TIGHTEN ANYTHING TILL THE VERY END)
1. Install the new rubber tubing(Make sure you push it all the way in) Tighten it a little using a Flathead or 8mm Socket so that it does move to much.
2. Insert the Sensor
Screw on the 1st Vibra-Mount (One female end and one male end) to the top battery screw
The second Vibra-Mount (2 male ends) goes where the old Factory Resonator was…Near the Fenderwell
1. Install the 1st part of the CAI
2. Install the stock vacuum line [A]
1. Slide the bracket onto of the Vibra-Mount and screw on the nut(using a 10mm Socket)
You won't be needing this piece(the PVC Pipe and Short Coolant line)
Remove the short coolant tube and Install the long coolant line where the existing short coolant line was.
1. Install Breather Hose directly onto the Vent Chamber
2. Install the the Injen Sleeve and then Assemble the Vent Chamber
If you want a Short Ram Intake (SRI) install the filter now and put everything back to together ….If not lets keep going…
Insert the other Injen Sleeve onto the end of the tubing
1. Going from the bottom insert the 2nd part of the CAI into the Sleeve
2. Slide the Bracket onto the Vibra-Mount and screw it on
Install your filter and you are done!
Should like this
Oooo Painted Manifold Cover(GunMetal Gray)
2003 Honda Accord EX I4 MT
Eibach Pro-Kit_04 TSX Intake Mani_TL TypeS RSB_Injen CAI/RS_18' Black Gloss Enkei_Megan Racing Rear Camber Kit_Interior/Exterior LED Upgrade_Yellow Ebay Fogs_Blackhoused OEM Headlights
Old 03-31-2010, 09:22 PM
NickkxO's Avatar
NickkxO NickkxO is offline
The taste of Vtec!
Send a message via AIM to NickkxO Send a message via MSN to NickkxO
Very nice write up! I'm jealous. This is for I4 tho slight difference in V6 :p
SHOW US HOW TO TAKE OFF RESONATOR!!!
2003 Ex-L V6 Honda Accord
| Blue Interior | Blue LEDGlow Bars | Dual Halo Projectors with LEDs | Smoked Foglights | 8000k HIDs on Fogs and Projectors | Magnaflow Cat-Back Exhaust | Secret Weapon Intake | Pioneer DEH-P7100BT (Bluetooth, iPod, USB) | JL TR690-TXi (Rear) + JL TR600-CXi (Front) Speakers |
2009 Acura RDX
| Fully Loaded | Stock |
Old 03-31-2010, 09:32 PM
braddtm's Avatar
4th Gear
Come Nick thats so easy ...
Remove your Bumper and you'll see something like this(sorry this is an I4 "slight difference in V6") hehehe
The Bolts are already removed on the picture below, but you can see where the bolts were at
Old 03-31-2010, 09:33 PM
korrupt3dazn's Avatar
korrupt3dazn korrupt3dazn is offline
2008 Honda Accord V6 EX-L
Send a message via AIM to korrupt3dazn Send a message via Skype™ to korrupt3dazn
Wow great write up dude!!!!! I will be using this very very soon. Thanks for hooking us dude
2008 Honda Accord EX-L V6 Coupe w/ Navi
Previous Cars:
2004 Accord EX-L I4
2000 Accord EX V6
Old 03-31-2010, 09:35 PM
yea Nick gosh...just break ur bumper like in the picture and remove those bolts duhhh. If you need help ill come down to NYC with a hammer and help you out. haha jk
Previous Cars:
2004 Accord EX-L I4
2000 Accord EX V6
Old 03-31-2010, 09:39 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
why is your front impact sensor places so far back? mine is all the way to the front right behind the foglight...
2007 Acura TL Type-S
Old 03-31-2010, 09:46 PM
braddtm's Avatar
4th Gear
that yellow thing???
Old 03-31-2010, 11:07 PM
THAiPHOON's Avatar
THAiPHOON THAiPHOON is online now
6th Gear
Great write up dude. This really helps if I ever decide to install one in the future. I know I'm a noob for asking, but whats the difference between a CAI and an SRI? Positives and negatives?
2007 Honda Accord Sedan SE AT
Alabaster Silver Metallic
17mm TL RSB, Diode Dynamics Stage 2 LED kit, 5000k 35w DDM Tuning HID kit, Nokya Hyper Yellow DRLs,
eBay foglight kit, 35% SolarGard Titanium Tint, LED Glow 7-Color kit, MH1 Retro/Blackhouse, Fujita CAI,
Hybrid tail replicas, Megan Racing coilovers, Ingalls rear camber kit, Acura TL wheels w/ Conti DWS
Old 04-01-2010, 05:49 AM
braddtm's Avatar
4th Gear
Don't ask me, I don't know much about the differences....I do know that CAI has more chances of HydroLocking the Engine, while SRI has more chances of heat stroking
Also, sound wise..I think CAI has that more raspy loud roar where as SRI has that low deep roar...not 100% sure about this
Old 04-01-2010, 05:54 AM
Vixen89 Vixen89 is offline
banned
Search is your friend.
Great DIY Brad..it's very similar to the 8th gen CAI install on mines.
Old 04-01-2010, 06:06 AM
sodaks2k sodaks2k is offline
Moderator
Wait, so you're driving around without a front bumper on?
Nice write up!
Filling a need-2006 Accord EX manual 5spd sedan
Old 05-28-2010, 12:04 AM
GNAWHDIVAD GNAWHDIVAD is offline
hey btw do you know whats the bolt size? socket size? sorry if this sounds really noobie... thanks
Old 05-28-2010, 08:05 AM
7thGenCoupe's Avatar
7thGenCoupe 7thGenCoupe is offline
03 Accord coupe Ex 2.4L
Nice job
:GNAWHDIVAD: If I remember right the bolts are 10's on the res. And a side note for you most all the bolts on Honda are; 10, 12, and 14.
Sold the Accord___ Mods: Injen CAI, Sloted/dimpled rotors, 8k HID high and low beam, 20* tint, TL-S front and rear SB, GReddy strut tower bar, OEM fog lts w/8k HID, DC Sport header, Tanabe exhaust system, Enkei EDR9 18" black, OEM lip kit, Exedy lightweight fly wheel and stage 1 clutch, Tein SS coilover kit, NEUSPEED short shifter, TSX intake manifold
DIY headlight swap---> http://www.driveaccord.net/forums/sh...ad.php?t=46767
Rome wasn't built in a day
Old 05-28-2010, 10:51 AM
crackerteg's Avatar
crackerteg crackerteg is offline
Call me Z
With a 17mm mixed in somewhere.
The name is Z. Not Cracker. Not CrackerTeg. *$#@!&% Z. Is that too hard to comprehend?
