How do you replace struts? - Drive Accord Honda Forums
Old 04-02-2010, 10:32 AM
highercal's Avatar
highercal highercal is offline
4th Gear
How do you change ALL struts on a 05 Accord EX I-4 AUTO SEDAN? i recently purchased tokico hp struts but i need a guide showing how to replace struts. any help would be greatly appreciated.
Old 04-02-2010, 05:02 PM
highercal's Avatar
4th Gear
^bump.
nobody really knows?
Old 04-02-2010, 05:38 PM
Aviography's Avatar
Have you searched?
This link http://www.driveaccord.net/forums/sh...ighlight=strut is in the Honda Factory Instruction section, it's for the front dampers.
The rears will be similar and simpler.
Just make sure you use approved spring compressor so you don't hurt/kill yourself!
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 04-02-2010, 05:59 PM
highercal's Avatar
4th Gear
Originally Posted by Aviography View Post
Have you searched?
Does having a '05 make a difference?
Old 04-02-2010, 06:16 PM
Aviography's Avatar
No, they are all 7 Gen, and therefore all the same.
DA Moderator Team
Title goes here
close
video goes here
