parking brake check & adjustment - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2004 Honda Accord Instructions
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 12-23-2005, 12:23 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
Check
Pull the parking brake lever (A) with 196 N (20 kgf, 44 lbf) of force to fully apply the parking brake. The parking brake lever should be locked within the specified number of clicks (B).
Lever locked clicks:
With rear disc:
6 to 9
With rear drum:
4 to 7
Adjust the parking brake if the lever clicks are not within the specification.
We don't tolerate personal attacks!! 3 strikes & you're out!!
I kicked cancer's butt! You might be next!!!! :)
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
His: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
Old 12-23-2005, 12:24 PM
princess's Avatar
ready to go....
Adjustment
NOTE: After servicing the rear brake shoes, loosen the parking brake adjusting nut, start the engine, and press the brake pedal several times to set the self-adjusting brake before adjusting the parking brake (with rear drum brake).
Raise the rear of the vehicle, and support it with safety stands in the proper locations.
Remove the center console.
Pull the parking brake lever up one click.
Old 12-23-2005, 12:26 PM
princess's Avatar
ready to go....
Tighten the adjusting nut (A) until the parking brakes drag slightly when the rear wheels are turned.
Release the parking brake lever fully, and check that the parking brakes do not drag when the rear wheels are turned. Readjust if necessary.
Pull the parking brake all the way up, and make sure the parking brakes are fully applied.
Reinstall the center console.
Old 11-02-2006, 11:04 AM
avexnsx's Avatar
avexnsx avexnsx is offline
4th Gear
I did this.. and now my brakes squeal like mad!!! =(
2004 Accord EX L4
Hot InaZma ECO, DIY gnding kit, DIY interior accent lighting, DIY front grill, OEM front lip, K&N stock repl. filter, IPF Rev. 4 foglights.
... and lots of Zaino! o_O
Old 11-02-2006, 11:27 AM
mwmcginn's Avatar
mwmcginn mwmcginn is offline
<error: divide by zero>
Maybe a little too tight?
Mike M
2006 Accord VP
Wheels, AutoDim Mirror (temp and Maplights), Car PC.
Old 11-03-2006, 09:57 AM
avexnsx's Avatar
4th Gear
no.. i think i just need new rotors... =P
last time I had them turned, it was pretty badly warped... and I've had about 78000 km on them already... I think I will put up with the noise, and change the rotors after winter...
2004 Accord EX L4
Old 04-15-2008, 02:08 PM
Sig86 CM8's Avatar
Sig86 CM8 Sig86 CM8 is offline
aka Rich
Send a message via AIM to Sig86 CM8 Send a message via Yahoo to Sig86 CM8
i found out how to do this when i installed my comptech short shifter. now my ebrake actually works. thanks to tightening it!!
Old 03-14-2009, 08:38 AM
jagboy's Avatar
jagboy jagboy is offline
4th Gear
Princess,
can you post instructions on how to remove center console?
2007 Acura RDX
DDM 8000K Fogs | 20% Tint | iSimple | Exhaust resonator delete | Hondata reflash | 2-way Alarm/ remote starter
Accord sedan 2005 EX-L i4 [TRADED]
miles: 40,XXX
DDM 8000K HIDS | 20% Tint | Eibach Pro | OEM fogs | Rotora | Hawk | Switch blade key | iSimple ipod adapter | 2-way Alarm/ remote starter | Intake Resonator delete
Old 03-16-2009, 10:12 AM
princess's Avatar
ready to go....
It's been posted several times....here it is again...
Old 04-28-2009, 05:52 AM
BigAnt1969 BigAnt1969 is offline
4th Gear
Does anyone know how to remove a 2008 Accord sedan e-brake handle?
I'm having the gear shift knob leather wrapped and I would also like to have the e-brake leather wrapped.
Ant
Old 04-28-2009, 06:16 AM
princess's Avatar
ready to go....
Can't get the handle instructions... which usually means it's obvious... here's the center console instructions.
Old 06-28-2009, 11:18 PM
owequitit owequitit is offline
Just as a note, it is not necessary to remove the entire center console in the 2003-2007 Honda Accords in order to adjust the e-brake.
Honda provides an access panel at the back of the console that may be removed to adjust the brake.
1) Remove the two exposed screws at the rear of the center console, one on each side of the console, that are down and close to the floor. They are the only exposed screws you will see at the back of the console.
2) Using your fingers, gently pry evenly on both sides of the rear center console cover, starting from the bottom up. there are several alignment tabs up the sides, and two clips at the top, near where the center console lid attaches to the console.
3) Once the panel pops free, you will be able to see the adjuster underneath the center console bin, by looking up under the console. You may wish to use a light to make it more visible. Using a 12MM socket, and an extension, you can adjust the parking brake without removing the center console.
4) When finished, installation of the access panel is the reverse of removal.
Here is a link to an image on Majestic Honda that shows the rear panel clearly:
http://www.hondaautomotiveparts.com/...tcgry5=CONSOLE
It would be represented by part #11 or #12 respectively.
Old 05-17-2010, 05:17 PM
reframmellator's Avatar
reframmellator reframmellator is offline
Reframmellator
Instructions are very helpful. Went through this over the weekend, because I had no parking brake. Raised the rear and found the left wheel spinning freely and the right wheel held pretty firmly. Had about 50% of left pads left and hardly any on the right side. Replaced both calipers, pads and rotors but found right side still engages more aggressively than left. I backed it off to where I still have parkng brake effect but it's all from the right and engagement is not within specs.
Any idea what could be causing this?
"Communication isn't what you say. It's what they hear." - Red Auerbach
When everyone's home:
2007 SE I4 5AT, Cool Blue, 52k
2007 Civic EX-Navi, Galaxy Gray, 96k
2011 Acura TSX 6MT-Navi, 22 k
2004 EX I4 5MT, Desert Mist, 134k
Gone but not forgotten:
2001 Accord EX I4 5MT, Satin Silver, oil slick at 86K
1999 EX-LV, Heather Mist, sold at 146,567
1994 Accord LX I4 5 MT ABS, Malachite Green, traded at 285k
1993 Volvo 940 Turbo Wagon, Blue Green, 229.5k
Old 05-30-2010, 11:11 AM
turtlesdove3's Avatar
turtlesdove3 turtlesdove3 is offline
Thanks for the link. I was actually looking for the rear panel.
Old 10-23-2011, 03:55 PM
Boing Boing is offline
Parking brake only works half
HELP PLEASE!!
My parking brake was very loose, every time I pulled it I'd hear over 12 clicks and the handle ended up being really high! However the driver's side wheel still wouldn't lock. So I checked and tightened the adjusting nut by following the procedures that were posted before. Now, the brake handle feels tighter and lower. The pasenger's side wheel would be locked in just 4 or 5 clicks. Unfortunately, there is still NO change to the driver's side. Even if I pulled the brake handle for 8 or 9 clicks, the driver's side wheel would still spin freely like lottery spinner
What could cause this problem? And what should I do?
