HID Lights Stopped Working!
I purchased Night Vision 35w digital from RetroSolution with the relay harness about ten days ago. I was so exited to get them installed and did, with the help of Steve. Two days after the right bulb would not fire up . Turned them off then on and they worked fine. Three days ago I was coming home and out of the blue they just turned off. After trying to turn them off then on for two blocks I gave up and had to drive with only my fogs on. As I'm pulling in my garage the f***ing lights turned on all on their own. Tonight after the game I was gonna go out to get some smokes and my lights would not turn on at all. I checked the fuse thats attached to the red wire from the battery and it looked fine to me. Are there any more fuses? What else should I do? PLEASE HELP!!!
Now: 09 PMM Coupe V6 EX-L 6MT w/Navigation Greddy Evo2 K&N 69 Typhoon Megan Racing Coilovers Nokya Hyper Yellow DRL HID NightVision 35w digital 8000 15% Tint and Taillights Coming Soon: Wheel Spacers(rear) ?WHEELS? |
| Sponsored Links | ||
Advertisement | ||
Exchange from Retro! ASAP! lol
I will Lisa, I just wanted to see if anyone else might of had this problem and if there was a fix.
they are not grounded properly. trust me on this one. I had the exact same issue, ground them to the battery -ve terminal and they should fire up just fine. it took, 6 people and about 5 hours at the NJ meet to figure out that a bad ground bolt was to blame for my HID's to not fire up! try that out. if they dont, then exchage cos usually when both stop working togther its not the ballasts or the bulbs its the grounding or something like that!
2006 Inspire a.k.a Ruby 30% tint all around. Diode Dynamics stage 3 LED kit ACURA TL A Spec rims (chrome) Inspire Chrome Headlamps 03-05 Front Lip modded on 06 Hybrid OEM tails 06 Hybrid OEM sideview mirrors Full leather conversion from a totaled 2004 EXL-V6 Full OEM navi -transplant from a 2006 sedan with voice command and back up camera Leather steering wheel Illuminated door sills Tein SS coilovers OEM Honda all weather mats front and rear OEM decklid lip spolier |
put the relay harness ground on the -ve terminal and make sure no wires are disconnected. if you are using them for the headlamps, you dont even need a relay harness to be honest!
there are no more fuses to check. if you are sure your wiring is correct, power and ground wires are tight, then the only option i see is contacting them for an RMA.
2010 EX-L V6 NAVI SEDAN 1999 EX V6 COUPE 2006 Si Viper 5901 DIY 3rd Brake Light LED Conversion I unlock iPhones! 3G 3GS 4 4S 5 |
Thank you guys...I'll try it in the morning and let you guys know my findings
Hope it works..haha
I never heard anyone grounding it wrong. :x |
trust me lisa, my ground was horrible! also OP make sure you test out the system by getting rid of the relay harness, just attach your Low beam connectors directly to the ballasts. If they fire up then the relay harness has some kind of problem with it! if they dont fire up, remove and flip the OEM harness to ballast connection and try again. if all else fails contact retro-solutions!
I will try anything to see if it works. Thx
it worked after that with no problems...
|2009 EX Coupe|BlackonBlack| | TSX RSB| | Tint 20/5 | | HID 5000k | | LED Interior | | Odyssey Grille | | Weather Tech Visors | | OEM Rear Wing Spoiler | | Type 2 DUAL Turn Signals | | Nokya Yellow Fogs w/ Yellow Lamin-X Film | If Life Gives you Drama, Let VTEC Kick in! |
bad ground or loose connection somewhere.
Try to connect the ground directly to -ve post on the battery. If problem persists, start retracing back from bulb to harness to ballast to battery, making sure there is solid connection.
2013 EX-L V6, MSM/Black Mods - Deck lid spoiler - Llumar 30 + Air Blue 80 - exLEDusa interior - Morimoto Elite 3Five 5500K - WeatherTech floor liner - 3M ScotchGard 2008 EX-L Night Hawk/Ivory, RIP |
If you're not using the relay harness how are you guys grounding it? Stick a ground wire from the ballast casing to the (-) of the battery terminal?
If you are not using a relay harness the ballast will plug into the stock harness which contains power and ground wire.. So there is no need for external wiring.
Like californium90 said its the ground
2008 Accord 2.4L AT LX PMM current mods Xenon HID kit 8000K k&N dropin filter 09 Acura TSX RSB 20% Tint Back Windsheild 35% Tint Rear Driver and Passanger Doors Inspire Lower Trunk+Lights Inspire Decklid spoiler Magnaflow Custom exhaust facebook profile |
| Sponsored Links | |
Advertisement | |
