Using oil, causing a P1259 VTEC code - Drive Accord Honda Forums
Old 07-05-2010, 03:47 PM
gustophersmob's Avatar
gustophersmob gustophersmob is offline
Howdy!
my '02 coupe (2.3 I4, AT) now has 215k miles. Right before my last oil change (~7000 miles on oil) it threw a P1259 code. The dealer said it is usually due to low oil, and we checked and I was about 1 quart low. Now it it 2 oil changes later, again with about 7000 miles on the oil, and I am about a quart maybe a quart and a half low again. I've never had this problem before (or at least it didn't use/burn enough oil in 7500 miles to throw a code for me to notice), but am wondering if this is just part of having a 215k mile car?
Thanks for any help you can give!
Mine:
2002 Accord SE Coupe
2.3L I4 VTEC
225k Miles
Wife:
2002 Accord SE Sedan
2.3L I4 VTEC
100k Miles
Old 07-05-2010, 05:00 PM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
Using 1-2 quarts per 7k is remarkable for a 215k mile engine. Some new Accords don't don't do that good. What oil are you using? You could switch to one of the high mileage oils like Valvoline Maxlife to see if that reduces your minimal consumption and check the oil level more often instead of relying on the CEL. You also might want to change the PCV valve if it has not been changed before.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 07-05-2010, 05:20 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
I agree about the oil consumption. On a F23 that's quite good for that mileage.
Check the screen in the vtec solenoid (part of the gasket) make sure it's clean, any dirt in the screen can cause the oil pressure to the solenoid to be low, when you run lower on oil the volume of oil available isn't enough to get full pressure up there.
What oil are you currently using in the car?
Old 07-05-2010, 05:37 PM
Thanks for the input!
I am currently running Honda's 5W-20. The stuff the dealer uses.
Mine:
2.3L I4 VTEC
225k Miles
Wife:
2.3L I4 VTEC
100k Miles
Old 07-06-2010, 07:32 AM
Well,
On the way into work this morning, the car tried to stall at idle several times. If I kept my foot on the gas to keep the idle at around 1000rpm, it ran fine. It did this for a few stoplights, then seemed to run OK after that. When I got to work I checked the oil again, and it was barely touching the bottom of the dipstick (after I added 1 qt yesterday). So I guess I was around 2+ qts low.
The question is, will having low oil cause it to want to stall at idle?
Mine:
2.3L I4 VTEC
225k Miles
Wife:
2.3L I4 VTEC
100k Miles
Old 07-06-2010, 07:53 AM
shadow85's Avatar
shadow85 shadow85 is offline
5th Gear
Dirty fuel injectors?
2013 ACCORD EX I4 Sdn MSM
2008 ACCORD LX-P I4 Sdn PMM
Old 07-06-2010, 08:38 AM
AccordNV's Avatar
AccordNV AccordNV is offline
2nd Gear
Does your commute consist of a lot of highway driving? Just curious...
2000 Accord Lx 4-dr 5spd 100,000 miles (11/10)
Aftermarket head unit, speakers, 2 10" subs, amp, 1 farad cap
Crystal head lights
Euro tail lights
Neon lights under dash, in trunk
215/50/17s
To do list:
Interior LEDs
Remove pin stripe
Body colored door guards
Old 07-06-2010, 09:06 AM
Not anymore. From 04/07 to 07/08 I was commuting about 160 hwy miles a day, so I racked up quite a few in that time frame.
Now I commute about 50 miles a day, but it is more state route/back road type stuff.
Mine:
2.3L I4 VTEC
225k Miles
Wife:
2.3L I4 VTEC
100k Miles
Old 07-06-2010, 09:10 AM
AccordNV's Avatar
2nd Gear
I was asking because mine seems to consume oil too, but only when I'm on the highway with the constant high rpm. I can cruise around town all month and not have a problem, but if I make a trip to the shore and back (hour each way) I'll be down 2 qts just that fast. And no one I know has a clue of why that happens.
Crystal head lights
Euro tail lights
215/50/17s
To do list:
Interior LEDs
Remove pin stripe
Old 07-06-2010, 09:46 AM
Thats odd. I don't spend all my time at high rpms, but who knows, could be a similar problem.
Mine:
2.3L I4 VTEC
225k Miles
Wife:
2.3L I4 VTEC
100k Miles
Old 07-06-2010, 01:38 PM
AccordNV's Avatar
2nd Gear
Well I don't like to really have it going more than 3k rpms (which equals about 80mph in 5th). But when I keep it there for a while that's when the oil disappears on me. But like I said, with regular city driving I have no issues.
Here's the thread I started when I initially notice the problem: http://www.driveaccord.net/forums/sh...ad.php?t=29280
Crystal head lights
Euro tail lights
215/50/17s
To do list:
Interior LEDs
Remove pin stripe
Old 07-06-2010, 02:58 PM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
Consider a 10W30 for the next oil change to see if it lessens consumption. With that many miles it may not do squat but it is worth a try. It doesn't need to be Honda branded oil. 10W30 is usually safe to about -15F. Try it.
Old 07-06-2010, 04:50 PM
Fredsvt's Avatar
Moderator
10w30 will actually increase consumption. It sounds backwards, but it does prove out on many cars.
The 5w20 that Honda and Ford use are a much higher quality oil than most, 10w30 oils out there. No dino 10w30 is anywhere near as good as a Ford/Honda spec'd 5w20.
Has your car in its life ever had the thermostat replaced?
Old 11-28-2012, 06:04 PM
d.drew d.drew is offline
My First Post
oil leak
My mother drives a 2001 accord im not readily handy with hondas as i am with american vehicles but i plugged in and got this code i know for over a year it has been shifting rough but it very recently started leaking oil at first just a little but now ALOT of oil so much i perhaps thought the filter may have come loose but i checked and it wasnt and i cant find the source of the leak the oil is the same she has always used Pen 5W-20 and it has about 2500 miles on it but ive added two quarts over the last two days the engine itself has 135,000 miles on it with only belts plugs and one alternator being put on it since it was purchased new and almost all the miles are city miles any ideas to where this leak is
Title goes here
close
video goes here
