Wont Start!!!! (sparatic) - Drive Accord Honda Forums
Old 07-13-2010, 04:16 PM
dametalone dametalone is offline
2002 Accord EX 3.0 ltr V6
Sometimes i will get in the car, put in the key and turn to crank and it will not fire. It does crank but it wont fire at all. Ones and a while it will start and then shut off right away. It seems to do this when its warm/hot out. Then sometimes after its doing this, i will turn the key and it will fire up right away. Very weird but its happening more and more now
98k miles
changed spark plugs a year ago
Old 07-13-2010, 04:26 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
Main relay is my best first guess.
Does the check engine light come on for 2 seconds then go off when first turning the key on, when it doesn't start? You should also hear the relay click on key on, then click again after 2 seconds.
If the check engine light doesn't come on or stays on steady with key on, engine off when it doesn't start, the main relay is definitely something to look at.
Old 07-13-2010, 04:36 PM
i have not noticed the check engine light coming on at all and in terms of a relay click, i dont quite know what to listen for so i have not noticed it.
sometimes it seems like an anti theft immobilizer issue because sometimes it will fire up and die right away
Old 07-13-2010, 05:09 PM
Fredsvt's Avatar
Moderator
what's the green key light doing?
The check engine light will not be on when the car is running if the main relay has an issue.
You have to watch it when the key is on and engine is OFF when it doesn't start.
Old 07-13-2010, 05:32 PM
ElPigto ElPigto is offline
I use to have this very same problem and it turned out to be the Main Relay for me.
Old 07-15-2010, 08:43 PM
caod's Avatar
caod caod is offline
When the main relay went out on me, my car never started. It was more like as if the battery was dead except all my lights still turned on in the instrument cluster.
1999 Accord EX V6
Old 07-19-2010, 04:18 PM
prorider0 prorider0 is offline
My First Post
My 02 is doing the same thing. I figured it was the main relay or a fuel pump relay. Old preludes have this same problem, you'd think honda would have fixed it over the last decade. For now I'm just parking in the shade, and leaving the sun roof cracked, so the cabin temp doesn't get hot enough to affect it.
Old 07-19-2010, 08:01 PM
tidu tidu is offline
This happened to my 99 Accord a few weeks ago, turned out to be the Main Relay as mentioned above. I wasn't as lucky as you guys, I was able to start the car fine but I noticed the problem when the engine shut off going 35 down the road. I coasted to a stop, waited a few minutes and it started up just fine. Confused the hell out of me. A simple DIY fix:
http://www.youtube.com/watch?v=viIZ8k60awY
Watch this video even if you don't want to do the repair yourself, he does a good job of explaining the problem. Basically faulty solder joints break down over time, and if you looked at your relay you'd probably find the weak joint easily. When it gets hot, the metal expands too thin and opens the circuit. I soldered my relay myself and (after a month of 90+ degrees) my car has yet to shut off randomly. It's up to you if you trust your soldering skills.
Old 08-04-2010, 05:07 AM
luke luke is offline
I looked at that video on youtube...very good info.
Anybody know where that main relay is exactly located
on an 04 Accord 4 cyl and do I have to pull off any access panels?
The weather 's been really cookin the past few months so stuff can
break down.
Luke
2004 Accord Lx 4 dr 4 cyl automatic
Old 08-04-2010, 04:44 PM
Fredsvt's Avatar
Moderator
There is no main relay on an '04 like what's on the older models.
It has 2 separate relays, one for the PGM and one for the fuel pump.
Old 08-10-2010, 12:28 PM
metrick1235's Avatar
metrick1235 metrick1235 is offline
3rd Gear
Mine did the same.. check your EGR valve.. thats what mine was.. cleaned mine out (had gunk and crap in the plug) and now it works perfect..
Old 08-14-2010, 12:44 AM
Flyboy's Avatar
Flyboy Flyboy is offline
Out of Control
Similar symptoms on mine last month. Dealer replaced the main relay due to the solder joint issue and hot weather.
2013 Accord Coupe EX-L I4 San Marino Red
2000 Accord Coupe V
6
San Marino Red 170,000 miles and still counting!
2007 Fit Sport Silver 60,000 miles and going strong.
Previous Honda: 1994 Accord Wagon Red, 1988 Prelude White 5 speed manual, 1981 Accord 4 Door Ivory 5 speed manual
Previous Cars before Honda: 73 Mazda RX2 manual, 63 VW Bug manual, 63 Alfa Romeo 2600 Spyder manual, 70 Toyota Crown manual, 59 Vauxhall Victor manual (worst car ever produced, a pre Yugo, Yugo)
Old 01-12-2014, 01:10 PM
lsvtecwmf lsvtecwmf is offline
My First Post
I'm having the same problem with my 99 accord but I cant figer it out what is it the car has fuel pressurea and spark and I already change the main relay and I got a new Ecu reprogrammed for the key and still won't star does any one have any idea what can it be please let me know w.Francia@Yahoo.com or text me 4027089867
Title goes here
close
video goes here
