Outside Temp OEM kit - installed - Drive Accord Honda Forums
Old 07-30-2010, 07:18 PM
RinconVTR RinconVTR is offline
4th Gear
Today after work, I installed Honda's OEM temp sensor kit. Many of us have known of the outside temp kit from Honda but I dont think anyone has installed it before?
The kit is for 03-07 Accord EX and LX models. Its crazy simple, and a very quick plug and play type install. All connectors on the car are open and ready, just waiting for this kit! It took me a hair over an hour, but that also included a coolant drop and refill.
The directions appear involved, but it isnt and some bolt removal isnt actually required. I could have shaved 20 minutes if I opted to route the wires more crude from the front of the car to the back of the relay box, where the plug is hiding. Most important, is you dont need to remove the hood latch to push pin install the sensor bracket if your hands fit. I figured that out before I removed it.
Honda has discontinued this kit, and now they are under $100 shipped from common Honda part web sites. Anyone with a 03-07 EX or LX who ever wanted outside temp...this is a must do add on! Its too easy!
Sensor attaches with 2 push pins just below and in front of the hood latch.
[IMG][/IMG]
Brown plug is the exsisting open plug connected to the temp sensor. Under hood install complete.
Under the dash, its all plug and play to exsisting plugs and ground location. The module gets mounted to an exsisting bracket if you have cruise. If not, a bracket is included.
And 6 years later...I know the outside temp.
Old 07-30-2010, 07:27 PM
Valkyrie1911 Valkyrie1911 is offline
4th Gear
Nice, I think I may do this.
2004 Accord Coupe i4, San Marino Red
Current mod list: OEM fog light kit, Xenondepot LED interior and license plate kit (6k white), AEM Cold Air Intake
Future mod list: Tint, Retro HIDs, OEM style LED taillights, Coilovers, New wheels (07-08 TL Type-S I think)
Old 07-30-2010, 07:38 PM
hillstones hillstones is offline
Sold the Accord
Nicely done. The "accessory" outside temp sensor can only be installed if the accessory fog lights are not already installed, since both accessories use the same harness. On the EX-V6, the outside temp sensor is integrated with the Auto Dual-Climate Control system to monitor outside temp combined with inside temp and the sunlight sensor to automatically adjust the temp and fan speed. So EX-V6 owners can install the accessory fogs and still retain the outside temp sensor. EX/LX owners that have accessory fog lights already installed cannot install the accessory temp sensor. Just an FYI.
I got your outside temp beat. Here is a So CA summer day for you.
Old 07-30-2010, 07:52 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
i live in socal too and we are NOWHERE near 115....i think that was from you leaving your car out in the sun for a long time to the sensor was nice and baked.
and btw, the outside temperature sensor integration into the auto dual climate control is also on the EX-L I4 not only EX-L V6 ;] give some credit to us I4 owners
2007 Acura TL Type-S
Old 07-30-2010, 08:04 PM
4th Gear
Good call on the restrictions. I forgot to mention the kit can not be installed with fog lights, Navigation, EX-L Trim levels (dual climate) ot the Hybrid.
That said, under the hood and under the dash, there are back up (or duplicate) plugs that can be used. They are spelled out in the directions, and I found them, but I dont understand when they may be needed. It simply says "if in use by another accesory"...
Seems odd that each of the seconardy plugs would all be used the above noted restrictions. My bet its if you have more than one of the above, like EX-L with Nav, or Nav with Fog lights for example, then each of the LX/EX level accessory plugs would be in use.
May be someone with the just one of the above noted restrictions, like EX-L only, could look behind their fuse/relay box for any open plugs.
Old 07-30-2010, 08:05 PM
WolfpackBill's Avatar
WolfpackBill WolfpackBill is offline
6th Gear
Send a message via AIM to WolfpackBill
It's not just EX-V6 but EX-L gets to enjoy that benefit as well because we also get auto climate control. The only things the EX-L doesn't have but EX-V6 has power passenger seat (sedan only), Homelink, and obviously the V6 engine :p.
Billy
'06 Honda Accord EX-L - Carbon Bronze/Black My Accord
Mods:
Fog lights, autodimming mirror, USASpec iPod adaptor, LED backup lights, cathode lights in trunk, fog light mod, Inspire taillights, 35% tints, HID retro w/TSX projectors, lip spoiler, TL switchblade key, TL 17mm rear sway, TSX signal mirrors, TL rims
Old 07-30-2010, 08:30 PM
4th Gear
Well that ****s, I'm adding fog lights and a navi system so no temp monitor for me...guess I'll have to rely on my phone, casio pathfinder watch, and whatever devices I might have Does kinda ****, but oh well.
Old 07-31-2010, 02:54 PM
Sold the Accord
Forgot the I4 has a Leather option. The 115 was during one of our heat waves a few years ago and the car was parked under a carport in the shade at work, no direct sunlight. It was a hot one! As I was driving, it went down to about 110. It gets hot in the San Fernando/Santa Clarita valleys during a nasty heat wave.
Old 08-04-2010, 06:15 PM
brickman's Avatar
brickman brickman is offline
College...ouch!
So this will work on my '07 SE-V6?
2007 Accord SE V6 Sedan Graphite Gray @ 85k
Previous - 2002 Accord SE I4 AT Sedan Silver
Everything easy has its cost....
Old 08-04-2010, 06:25 PM
thisismyusrnm's Avatar
thisismyusrnm thisismyusrnm is offline
4th Gear
just a refresher, from HandA
In reference to the OEM fog light kit.
"Can't be installed with accessory (add-on) exterior temperature sensor. If you have an The EX-L or an EXL-Nav models (EX modelsl with factory leather) then it came from the factory with the temperature sensor so the fog lights CAN be installed. The restriction only applies to those vehicles that had the sensor added later.
Fits Years 2003-2005, for other years"
2004 Nighthawk Black Pearl/Black Honda Accord EX-L Coupe
Only Mods Thus Far...
LED License Plate Lights.
LED Interiors - Ambient Light, Dome,
Ceiling, Glove box, Doors and Trunk.
Accord Branded All-Weather Mats
OEM Splash Guards
20% Window Tint Rear Windows
Wish List
Short Ram Intake
Wheel Spacers
OEM Fog Lights
Trunk Tray WITH cargo Net :)
I aim for nicer, not ricer.
Old 08-04-2010, 06:28 PM
Out of Control
dont forget hood struts(its been a long honda tradition to give this to all v6 cars), trunk lining, vsa/tcs(depending on year), front strut bar(6speed only)
Old 08-04-2010, 06:46 PM
Aviography's Avatar
And that's why I got the car I did!
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 08-05-2010, 08:28 AM
jeffislouie jeffislouie is offline
No longer active
Thanks for this. Guess what I just bought off ebay?
When it arrives in a few days, I too will know the temperature outside my car.
Since I can't figure out how to cancel my account, this serves as notice that the above user is no longer an active member of this community.
No messages will be checked. No responses will be given.
Frankly, even though this forum has a lot of very nice people, the few bad apples around here have gotten on my nerves. I simply don't care enough to log on and try and help others when all too frequently, I get mocked or made fun of.
Old 08-05-2010, 09:13 AM
7w15t3dz 7w15t3dz is offline
banned
That's awesome. I wonder if anyone has tried this on the 8th gen....
Old 08-05-2010, 09:25 AM
brickman's Avatar
College...ouch!
Does this mean it won't work on my '07?
Title goes here
close
video goes here
