Cleared Fault Code, Car Won't Start - Drive Accord Honda Forums
Old 08-03-2010, 07:50 PM
watzae123 watzae123 is offline
I had a check engine light on and took my 2004 Honda Accord to the shop. The fault code said the heat sensor was malfunctioning. The mechanic said this sensor should last for 100,000 miles and I only have 43,000 miles on my car. After the mechanic cleared the code, the car wouldn't start. He checked all fuses, relays and the fuel pump. All are working fine. The keyless entry works but when you try to start the car it cranks and won't turn over. Help!
Old 08-03-2010, 07:59 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
just wanted to make sure, you ARE using the regular key right? because cranking but not turning over is a symptom of using a dummy key to start the car.
2007 Acura TL Type-S
Old 08-03-2010, 08:02 PM
I am using the correct key. I actually tried both keys and neither work. Any ideas? Is it possible the mechanic messed up the programming of the keys?
Old 08-04-2010, 09:10 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
Whats the immoblizer light doing (green key light) off, on steady, flashing?
When you turn the ignition ON, it should come on for about 2 seconds then turn off if it recognizes the key.
If it is blinking then it does not recognize the key and the engine will not start.
If the immoblizer is working correctly then the mechanic should know how to check for spark at the plugs to see if the problem is ignition related and spray starting fluid in the intake to see if its fuel delivery related.
2000 Accord SE I4 F23A1 Auto @159k miles - My Daily Driver
1998 Accord LX I4 F23A1 5 speed - sons car
1986 Accord LX Auto Totaled @125k miles
1983 Accord LX 5 spd My Second Accord
1978 Accord LX 5 spd My First Accord
Old 08-04-2010, 09:22 AM
luke luke is offline
What was the code ? Was it a P0141 faulty 02 sensor heater circuit ?
I just posted something on that problem above just wondering
if the 2 problems (P0141 and not starting) were related ?
Bill
2004 Accord Lx 4 dr 4 cyl automatic
Old 08-04-2010, 09:43 AM
overdrive overdrive is offline
I agree with the others, first pull off the intake hose and give it a 2-3 second spray of starter fluid. Then quick put the hose back on and have someone start it. If it doesn't start pull one of the plugs to see if they are sparking.
Do let us know what the "key lookin" immobilizer light on the dash does.
It is possible the mechanic accidendally cleared the key info, which you can change or re-program. In this case the car would crank but not start.
This happened to my older 2003
dodge and I had to re-program it,
it had a different system, the car would start, then stall 3 seconds later.
If you tryed twice more the ecu would shut down permenantly
I hope the Honda isn't like that.
Tags
2004, accord, heat, honda, sensor
