Getting out rotor screws - Drive Accord Honda Forums
Old 08-06-2010, 07:52 AM
slidingdelta slidingdelta is offline
Later this afternoon I'm hopefully going to change the rotors and pads on the front wheels of my father's Accord. But in searching around I've seen that there are two rotor retaining screws that can be difficult to get out. Instead of buying an impact driver I'm hoping I can drill them out as suggested before on here. I've never actually done this and could really use some tips. So you use a drill bit about the same size as the screw shank and drill through the middle untill the head falls off, then grip the portion of the thread that is sticking out? Does this sound right, or what would happen if the head brakes off evenly with the rotor surface and there is nothing to grip on? Lastly, it should be ok not to replace these screws to avoid this problem in the future, right?
Thanks!
2007 Accord I4 sedan Auto
Old 08-06-2010, 07:58 AM
Aviography's Avatar
Someone will tell you otherwise, but you do not need these screws when reinstalling brake rotor.
And yes a drill bit that is slightly larger in diameter than the screw thread will do the trick, you will drill out the head only as the drill will contact the chamfered hole in the old rotor, remove the rotor, and grab the remaining thread with a Vise-Grip to back it out.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 08-06-2010, 08:14 AM
So once the heads are off the screw, the rotor will just slide right off? At first I was thinking the screw threads would still hold the rotor on even if the screw head is off...
Thanks again!
Old 08-06-2010, 08:21 AM
Aviography's Avatar
Yes, the hole in the rotor is straight through with no threads, the thread is in the hub behind the rotor, you'll be fine.
DA Moderator Team
Old 08-06-2010, 08:33 AM
Ah, that should make it easier!
As an unrelated question...Before I buy the parts, for those that have used ceramic brake pads have you notice any change in wear rate of the rotors? Either faster or slower? Searching on google is yielding mixed answers on this. I can't order online, since I need them today, so I will have to rely on local stores. I'm hoping they could help keep down the brake dust which gets frustrating to clean off the plastic hub caps. But if the rotors wear faster I wonder if it's worth the hassle...
Old 08-06-2010, 08:38 AM
Aviography's Avatar
I am using Wagner ceramic pads, no observable increase in rotor wear and significant dust reduction, and they stop very well.
DA Moderator Team
Old 08-06-2010, 09:12 AM
dmo069's Avatar
dmo069 dmo069 is offline
06 6MT Sedan
Ditto this!
2006 Accord Sedan 6MT Navi
Audio Control LC6I / Rockford Fosgate R600X5 / Infinity Reference 9633cf / Infinity Reference 6030cs / Rockford Fosgate Punch P1-2X10 / Parrot MK6000 / Diode Dynamics 6000K HID Low Beams / DDM 3000K HID Factory Fogs / Diode Dynamcs Stage II LED Conversion / Backup Camera / Mid Muffler Delete / Dynomax Exhaust Resonator / Fujita CAI / 17mm TL Rear Sway Bar / Tein S Tech Springs / Tokico Blues / Ingalls Camber Kit / Ingalls Stiffy
Old 08-06-2010, 09:13 AM
Gapo Boy's Avatar
Gapo Boy Gapo Boy is offline
3rd Gear
I installed Brembo Pro-ACT ceramic pads summer last year. I have not notice significant rotor wear, brakes really well, a lot less brake dust.
Current Ride:
2011 Toyota 4Runner SR5 Upgrade Package@7,000km
2004 Accord EXL I4 @ 150,000 km
Previous Rides:
1997 Accord EX-R V6
1994 Toyota Cressida I6
1991 Toyota Corolla I4
Old 08-06-2010, 10:13 AM
WhiteFire07's Avatar
WhiteFire07 WhiteFire07 is offline
2007 EX-L V6
I just replaced the rotors and pads on my sedan using Raybestos Adv Technology rotors and regular Duralast ceramic pads. This was a huge improvement to the stock rotors and pads that were trying to vibrate my wheels off on every stop. Braking is smooth and even, but they have not been on long enough to determine brake life.
During the replacement, I had no issue with the first three rotors and the last screw on the last rotor decided to completely strip. Since the screw head was completely stripped, I was forced to drill it out. I used a drill bit that was the same size as the screw body with a decent powered drill and it took about 30 secs to get the screw out. Since I used a bit that was the same size, I could tell when I was to the old rotor because the screw head began to rotate with the drill bit.
As for if you need the screws for normal operation, I would say they are nice for reassembly. If you have no screws, the rotor will not sit flat on the hub while you are trying to insert the brake pads. One screw will hold it on just fine for you. I reinstalled all of the screws on the first three rotors and one on the last and all have performed pefectly. I would recommend that you not crank them down very hard to help you on the next swap.
I hope that helps since this is my first post. (I will add pictures of my own car when I can)
Old 08-06-2010, 10:21 AM
Aviography's Avatar
WhiteFire07,
Welcome to DA.
What would also help is to put some anti-seize compound on the threads of these bugger screws, it will help to stop them from seizing in there, but doesn't guarantee as I've had screws seize even when I did put the compound on them before.
DA Moderator Team
Old 08-06-2010, 04:12 PM
cjg1999 cjg1999 is offline
good luck! I just did this job 2 weeks ago, brakes all around. All of the screws came out with a regular screwdriver (i am lucky i know) this was at 81K on the clock. I took them out and did NOT put them back in. I used centric premium rotors and hawk pads in the front and duralast pads in the rear.
Old 08-06-2010, 05:43 PM
thumperac thumperac is offline
sounds like more work to me. An impact driver for like $25
Old 08-06-2010, 05:54 PM
rszappa1 rszappa1 is offline
6th Gear
have not had to mess with them yet. On my 07 Accord have 111,000 on it with OEM front pads still on and replaced the rear at around 100,00. Got the new front pads ready to go......
Old 08-06-2010, 06:04 PM
Aviography's Avatar
That, HAS to be a record!
DA Moderator Team
Old 08-06-2010, 06:57 PM
6th Gear
and they acually still have some meat on them....no noise at all...
Title goes here
close
video goes here
