Why is my car shaking at a complete stop? - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-26-2010, 12:21 PM
ryan mcgrogan's Avatar
ryan mcgrogan ryan mcgrogan is offline
4th Gear
Send a message via AIM to ryan mcgrogan
Any ideas? I only have 38k on the car. The idle rate isnt changing, its at like <1k. It's been doing it for a few weeks now.
Old 08-26-2010, 01:05 PM
oh3EX's Avatar
oh3EX oh3EX is offline
4th Gear
is the a/c on or anything? im pretty sure its normal because mine "vibrates" sometimes at an idle while other times i have to glance down at the tach. just to make sure the car is still on.
!ZAMOHTí
2003 Accord Sedan i4 5 speed
http://www.cardomain.com/ride/3838954/1
To do's:
  • Exhaust
  • Wheels and Tires
  • Retros
To done's:
  • Injen Short Ram
  • Alpine Head unit
  • JBL GTO series speakers
  • Tints:35% on doors and 20% rear window
  • Phillips Crystal Vision Ultra Low Beams
  • Nokya Hyper Yellow High Beams
  • Megan Racing Coilovers
  • SPC Camber Kits
  • OEM Front Lip
  • 15mm Spacers
  • TSX Intake Manifold
Previous Cars:
  • 1991 Civic DX 5 speed
  • 2002 Civic LX 5 speed
Old 08-26-2010, 01:09 PM
4th Gear
AC off, lights off
Old 08-26-2010, 01:17 PM
highercal's Avatar
highercal highercal is offline
4th Gear
Originally Posted by ryan mcgrogan View Post
AC off, lights off
Have you checked your drive belt yet? that also maybe causing the issue.
2005 Accord EX I-4 AUTO SEDAN.
Old 08-26-2010, 02:38 PM
nodrog321's Avatar
nodrog321 nodrog321 is offline
6th Gear
Send a message via AIM to nodrog321
maybe the motor mounts? happened to my minivan. car was shaking like no tomorrow at a stop, but once it starts, it goes away. but you got low miles.. so unless you drive so crazily everytime..
2007 Honda "Nikita" Accord I-4 LX Sedan
Graphite Pearl
-Blackhoused MH1 Retrofit projectors with DDM 4500k HIDs
-Soundgate aux integration
-Diode Dynamics stage 2 kit (license plate, front door lights)
-Aftermarket Inspire Fogs with 4300k HIDs
-TL Type S rims!
-OEM Decklid Spoiler
-Nokya Hyper Yellow DRL
-JL Audio TR690 rear speakers
-Polk DB 6501 front speakers
-K&N Short Ram Intake
-Acura TL RSB
Cardomain
Old 08-26-2010, 05:50 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
+1, unless the car has been in an accident before? an accident would surely put a HUGE stress on the motor mounts instantly if not straight up rip them.
2007 Acura TL Type-S
Old 08-27-2010, 06:02 AM
4th Gear
nope, im the second owner. it hasn't been in an accident before. clean carfax
Old 08-27-2010, 11:25 AM
peach007 peach007 is offline
The vaccum hose could be loose.
Old 09-02-2010, 03:47 PM
jared jared is offline
99% sure it is the motor mounts. I had a civic that did the same thing and it only had 18,000 miles. Should be easy enough to see with some mechanics mirrors.
Old 09-02-2010, 05:28 PM
dougw03 dougw03 is offline
3rd Gear
Clean carfax doesn't mean it hasn't been in an accident. It just hasn't been in a reported accident. Check your motor mounts just to be sure.
Old 09-02-2010, 06:03 PM
andres0603's Avatar
andres0603 andres0603 is offline
4th Gear
Send a message via MSN to andres0603 Send a message via Yahoo to andres0603
mine has a minimal, almost not noticeable vibration when the car is in Park or Neutral
2013 Honda Accord EX-L V6
mods done:
17" Chrome-Look Alloy Wheels
OEM Illuminated door sills
white LED back-up lights
exLED 6K interior lights
2006 Honda Accord EX-L V6
mods done:
white LED interior lights, stage II
OEM foglights
tint 35% all around
Old 10-21-2010, 02:52 PM
PKile PKile is offline
2003 I4 Noble Green EX
What year is your car?
I just took care of this problem on my 2003 EX I4. Just bought the car with 41,500 miles on it. Steering wheel shook badly at idle, stopped at lights, especially with A/C on.
There is a Honda Service Bulletin 04-024 that applies to 2003 and 2004 Accords. The dealer can check the rear engine mount, then if it is OK there is a new front mount and a "smoothing" kit that consists of some radiator bushings and a heavier plate inside the front lower bumper.
My car is out of warranty, so I bought the kit and mount for ~$210, installed it myself last night, and it is like night and day - very smooth now.
Cheers,
Paul
Old 10-21-2010, 09:26 PM
jeffislouie jeffislouie is offline
No longer active
05 I4 Automatic, 43000 or so miles, the first and only owner - mine does this - a bit, usually when the car hasn't been running very long, when I'm in drive but stopped with my foot on the brake. I've heard it might be motor mounts, but the condition usually goes away once I've been driving for a while. Best as I can tell, this is just a Honda thing. Various friends of mine have owned Hondas over the years (civics mostly, a CRX, and one Accord) and all of them did this too (only the automatics of course). When I got my Honda I noticed it. Once in a while, I still notice it. I think it's just the vibration of the car being in gear and pulling against the brakes. RPM at start up is 1200-1500 for a few minutes, then once it drops to normal (7-800 RPM or so) and I'm stopped, it vibrates. It goes away, so I don't know if it is due to fluids not being warmed up or parts not being fully lubricated yet, but that's my guess.
I read something about the motor mount having two 'modes' and when stuck in the "firm" mode, vibrations have been noted. To fix, I believe the mount needs to be replaced. Mine seems to go away after a few minutes, so I'm not too worried at this point. You could take it in and see if a tech thinks the mount is bad.
Since I can't figure out how to cancel my account, this serves as notice that the above user is no longer an active member of this community.
No messages will be checked. No responses will be given.
Frankly, even though this forum has a lot of very nice people, the few bad apples around here have gotten on my nerves. I simply don't care enough to log on and try and help others when all too frequently, I get mocked or made fun of.
Old 10-22-2010, 06:59 AM
TonyWare's Avatar
TonyWare TonyWare is offline
'09 TL SH AWD Tech
The front motor mount has two chambers in it with liquid that flows from one to the other when you are stopped or idle so that you won't feel the engine vibration. There is a hose under the motor mount that connects to the intake manifold with a valve to turn on and off the flow of the liquid from the "hard" to the "soft" chamber.
Best thing to do is to check the valve itself that is sitting on the top and back of the intake manifold and check the hose for cracks. The valve kicks in under 1,000 rpm to "turn-on" the front active engine mount and shuts down below 1,000 rpm. A simple test is at idle to disconnect the vacum hose from the intake manifold and plug in the hole on the manifold itself with something so that the rpms won't go up and see if the idle is rough. If the idle is rough then the valve and engine mount is ok. If after you re-connect the hose, it is still rough then the engine mount and perhaps the valve has to be replaced.
