Humming/growling noise when going 30-65 mph! - Drive Accord Honda Forums
Old 09-27-2010, 11:09 AM
TUBHMOOBVAJ's Avatar
TUBHMOOBVAJ TUBHMOOBVAJ is offline
3rd Gear
Owner of a 99 Honda Accord 2.3 cyc. automatic w/141K miles. When I am driving at a steady speed of 30-65 mph I can hear a humming/growling noise coming through the front passenger side of the car. I lifted the car and was able to pinpoint the sound, it's coming from where the inner CV joint and transmission intersect. When I drive my car I am able to shift my car from P-D4 without any issues and also haven't not notice any gear slipping. When I turn my car around corners, there is not grinding noise or vibrations to the steering wheel. The noise only happens when I am driving.
Has anyone experience this? Do you think it's a transmission issue or inner cv joint issue? Bad wheel bearings? Transmission bearing issue?
1999 Honda Accord LX 4-Cyl
15' OEM 2002 SE rims
Yokohoma all season tires
AEM SRI
Apexi WS2 catback exhaust
Red and clear tail lights
Chrome Headlights without amber
DDM Tuning 55W 6000K low bean
Nokya Hyper Yellow 2500K high bean
01-03 Honda Civic foglights w/DIY OEM Fog switch
Old 09-28-2010, 09:08 PM
metrick1235's Avatar
metrick1235 metrick1235 is offline
3rd Gear
bad CV axle maybe?? usually when its a bad wheel bearing the noise goes away when you go around a corner.. so it could be both.. i will tell you that the front end is a pain in the ass if you are doing it yourself.. you will need a press for the bearing..
Old 09-30-2010, 01:45 PM
3rd Gear
It was actually my transmission that was crapping out. Had to swapped in a used one. Differential bearings were messed up causing fluid leaking.
AEM SRI
Title goes here
close
video goes here
