Engine ticking when cold - Drive Accord Honda Forums
Old 02-18-2006, 07:48 PM
edwilson13185's Avatar
edwilson13185 edwilson13185 is offline
Send a message via AIM to edwilson13185 Send a message via MSN to edwilson13185
When the weather is really cold (like it has been today and yesterday here in St. Louis), I've noticed a very fast tick coming from my engine. It's most noticable for the first half hour or so the car is driven, then it fades somewhat, but is still there. I mentioned this problem to my dealer about a month ago, but they couldn't find anything wrong. They did a valve adjustment, and said that should cure it. It didn't. A second dealer wasn't able to fix it, either. The sound is noticable even if I walk several paces away from the car. The noise goes away when the temperature is higher outside (40+ degrees).
I popped the hood tonight--the sound seems to be coming from the driver's side area of the engine. I noticed two things over there--what looks like the EGR valve and the PCV valve. The larger of the two, which I think is the EGR valve, had a Siemens label on it. The ticking sound seemed strongest here---is it possible that the noise is coming from a valve or solenoid in this area? Are there any known problems with any of this stuff? Or is it more likely that there's something mechanically wrong with the engine? I'd appreciate any information anybody can offer--it doesn't seem like these dealerships know what is wrong, and they don't seem remotely interested in trying to figure it out, either.
-Ed
2005 Honda Accord EX-L 2.4 5AT coupe
2008 Honda Accord EX-L 2.4 5AT sedan
Old 02-18-2006, 08:15 PM
ItsaHonda's Avatar
ItsaHonda ItsaHonda is offline
6th Gear
All of my Honda 4-cylinders (including the new one) have had noisy ('ticking') valves when cold. Could this be what you are hearing? From what I've gathered, it's normal valvetrain racket, so long as it quiets down as the engine reaches normal operating temps.
1990 Honda Accord LX coupe
130,XXX miles
1989 Honda Accord LX sedan
186,XXX miles
1998 Lexus GS400
170,XXX miles
1992 Cadillac Allante
70,XXX miles
2013 Kia Optima LX
8,xxx miles
Old 02-18-2006, 08:24 PM
BenjiBoy650's Avatar
Oil should take longer to warm up than the engine itself, generally.
Old 02-19-2006, 04:12 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
ed-
What oil are you using? Silly as it sounds, some brands are noisier in Hondas than others. I use Mobil 1 0W-20 with no problems but others have complained of noise using M1. Try a different oil next change such as Havoline or Motorcraft 5W-20. They are both top quality dino oils. If the noise remains it just may be the nature of the beast but it's worth a try.
Old 02-19-2006, 09:03 AM
jbuffethed's Avatar
jbuffethed jbuffethed is offline
Parrot Head
Send a message via ICQ to jbuffethed Send a message via AIM to jbuffethed Send a message via Yahoo to jbuffethed
Block heater probably would fix that. Its pretty much mandatory up because it gets sooooo freakin cold
Greg
'03 Accord LX - Totaled
'09 Toyota Highlander
Old 02-19-2006, 09:27 AM
If you're really concerned about it, stick a flathead screwdriver on the valvecover, then put your ear directly onto the plastic end, and you should hear the valves. I doubt there's a problem though...mine are noticeable too. It's just one of those Honda things I guess. Maybe you can ask someone with high miles, like ssjones (150K+ on his K24).
Old 02-19-2006, 10:17 AM
stiller fan's Avatar
stiller fan stiller fan is offline
next stop: 300k!!!
as stated above, as long as the ticking goes away then oil is fully warmed up, you have nothing to worry about.... honda engines are known to tick when cold; mine does it too.....
good luck...
Originally Posted by craigslist ad
I'm 5'6'brown eyes,38 old,no child,but like. Please press 1 for English. No child, but like. You are child-like? You like no child? You like children? Sorry, the subscription for my translator is expired.
PROUD FAN OF STEELERS, PIRATES, AND PENGUINS
DA moderator
2007 Honda Accord LX Coupe 2.4 MT (201k miles)
gone, but not forgotten:
1993 Honda Accord (341k when sold, retired @ 369k)
1999 Honda Accord coupe (168k when sold, last check-in @ ~197k, blown head gasket)
Old 02-19-2006, 12:40 PM
Thank you, everyone, for your thoughts.
I'm using Mobil 1 5W-20. I'd really rather not go back to dino, but I will try a different synthetic at the next oil change.
-Ed
Old 02-19-2006, 10:49 PM
zoeyfactor's Avatar
zoeyfactor zoeyfactor is offline
2nd Gear
I also noticed it today for the first time...In houston its very chilly!!!!!
1998 Honda Accord EX-LEA Sedan Pearl Black
