04 2.4 coupe shudder/vibration just under 40mph - Drive Accord Honda Forums
Old 10-05-2010, 06:19 PM
jeepjimmy jeepjimmy is offline
have a shudder/vibration just under 40mph. does not matter how fast or slow you drive. tires are not the issue. any ideas?
Old 10-06-2010, 05:22 AM
87944turbo 87944turbo is offline
I had a similar problem when driving at part throttle right around 40 mph. Automatic trans. fluid needed to be changed.
Ben
2003 LX I4 Sedan (Eternal Blue Pearl)
- DC Sports Intake
- TSX rear sway
Other Cars:
2006 Nissan Murano
1987 Porsche 944 Turbo
Old 10-06-2010, 06:01 AM
accordslacker's Avatar
accordslacker accordslacker is offline
3rd Gear
need more info on ur car. auto/ manual, mileage?
Just a guess at this point would be cv axles (not the cv joint, but the axle itself). Could be bad ball joints or struts as well though.
'03 4cyl 5mt NHBP LX sedan
tsx IM, AEM shorty intake, 225/45-17s nexens on black Apec rims,17mm TL rear swaybar, Ingalls Stiffy
Old 10-06-2010, 11:37 AM
erfan9's Avatar
erfan9 erfan9 is offline
4th Gear
I have the same problem, right around 60km/h which i assume is 40 mph, i feel a smart vibration, My car is manual 2005,and its got 65,000 miles
2003 Acura RSX Type S 6MT SOLD
2005 Honda Accord Coupe 5 MT Totaled
2011 Honda Accord Coupe EX 4 Cyl 5MT
  • Takeda SRI
  • Fog lights
Old 10-06-2010, 03:48 PM
rufusvonstorm rufusvonstorm is offline
4th Gear
Same here - 100k miles
2005 Accord Coupe I4 5MT
- Fujita CAI, TSX IM, AV6 Strut Bar, TL 17mm Rear Sway
Old 10-06-2010, 03:54 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
but doesnt changing the axle change the cv joint too?
2007 Acura TL Type-S
Old 10-06-2010, 04:12 PM
-sorry. its a automatic, trans fluid is orig, has just under 100,000 miles on it.
Old 10-06-2010, 06:06 PM
CarlR33's Avatar
CarlR33 CarlR33 is offline
6th Gear
um, probably should change fluid more often......
03 Accord LX I4 5spd, 230k miles.
Old 10-07-2010, 06:21 AM
3rd Gear
It does. Just stating that the weak point and cause of the vibration is the shaft itself, not the cv joint.
Old 10-07-2010, 12:48 PM
4th Gear
So, if I'm getting some front-end vibration should I look at replacing the axles sooner than later? 100k on the car, I guess it could be alignment but I don't think so...
Will it eventually shred the whole trans if I let it keep going?
And could I replace these myself if I have the time or not a good idea for a novice mechanic? TY
Old 10-09-2010, 05:51 AM
Optimus Prime's Avatar
Optimus Prime Optimus Prime is offline
2nd Gear
I'm interested in the answer to this also ...
Old 10-10-2010, 06:55 AM
erfan9's Avatar
4th Gear
Same here, can somebody please let us know
  • Takeda SRI
  • Fog lights
Old 10-10-2010, 08:30 PM
3rd Gear
replacing the cv axles is not all that hard if you are mechanically inclined. there is a write up on this site for it.
EDIT: here's a link. It is for full transmission removal, but it'll get you headed in the right direction.
http://www.driveaccord.net/forums/sh...ad.php?t=34874
Old 10-12-2010, 01:47 PM
smykhaisouk smykhaisouk is offline
you might want to check your wheel bearings. they say one way to check it is to jack it up and shake/wobble the wheel in any direction for play. another sign that your bearing is out is to cruise at 40mph or whenever you hear the nosie/vibration and slighty pull to the left or right to see if that noise goes away.if it does then you have a bad wheel bearing. same thing happened to my civic. goodluck!
Old 10-13-2010, 11:11 PM
4th Gear
Thank you!
