Help driver side headlight fuse diagram! - Drive Accord Honda Forums
Old 10-30-2010, 10:51 PM
ga006959 ga006959 is offline
Exclamation Help driver side headlight fuse diagram!
I don't know where to post this problem
I just bought HID Kit today and as i was trying to adjust my projector my driver headlight just went off completely.
I was thinking either fuse or the ballast died.
I tried my old light bulb driver side didn't light up but passenger side did.
so at least now i know i need to change the fuse.
but my question is which fuse for driver side headlight?
My car didn't come with original manual so I have been looking for 2006 fuse diagram for like pass 2 hours.
If anyone know where it is please tell me if there's clear picture would be appreciated.
Thank you.
Old 10-30-2010, 11:01 PM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
the fuse for the headlight is in the engine bay fuse box. the fuse box cover has the diagram of the fuses
2007 Acura TL Type-S
Old 10-30-2010, 11:13 PM
Are those regular fuse?
I haven't open it up yet i am going to do it tomorrow morning.
if is different what kind of fuse is it?
is there a picture what type of fuse i should get?
Old 10-31-2010, 06:47 AM
Aviography's Avatar
It's standard blade style, should be 10A rating.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 10-31-2010, 10:47 AM
By the way I've seen people say once you get HID i should change it to 20A?
should i do that? or just leave 10A is fine.
Thank you
Old 10-31-2010, 11:10 AM
Aviography's Avatar
Leave it at 10A unless you are going 55W, but no one should need 55W HID kits, 35W is plenty bright enough, I've had zero issues for 3 years now with 35W kit and stock 10A fuse.
DA Moderator Team
Old 06-21-2011, 04:54 PM
Need4Speed808's Avatar
Need4Speed808 Need4Speed808 is offline
The rice-inspired Accord!
I had the same problem.... replaced one of the engine bay fuses and it worked!!! Thanks to this thread (esp. paperboy and Aviography)
Tags
driver side, fuse, fuse diagram, honda accord
