Door cable. I broke it. - Drive Accord Honda Forums
Old 11-16-2010, 06:39 PM
BMBaccord's Avatar
BMBaccord BMBaccord is offline
5th Gear
I have a 2006 sedan and recently got new speakers. While taking off the passenger side front door cover I broke a piece for the door cable that lets you open the door from the inside. It really is a poor design, just a small plastic piece that breaks very easily if you arent careful. I got a new cable ($10) and have it. Unfortunately I am not sure how to install it. The cable goes down into the door and I don't know even what to look for. I tried looking around, but havent had any luck. All I need to do is replace the old with new. Any help would be great! Thanks!
Present: 2011 BMW 335i e92 6MT
Past: 2006 Accord Sedan 2.4
2007 Odyssey (dad's)
Old 11-16-2010, 09:18 PM
dmo069's Avatar
dmo069 dmo069 is offline
06 6MT Sedan
I have replaced one of these before. It isn't really that hard. Just follow the old cable and you will see where it goes. You will have to temporarily remove the plastic film from the door.
2006 Accord Sedan 6MT Navi
Audio Control LC6I / Rockford Fosgate R600X5 / Infinity Reference 9633cf / Infinity Reference 6030cs / Rockford Fosgate Punch P1-2X10 / Parrot MK6000 / Diode Dynamics 6000K HID Low Beams / DDM 3000K HID Factory Fogs / Diode Dynamcs Stage II LED Conversion / Backup Camera / Mid Muffler Delete / Dynomax Exhaust Resonator / Fujita CAI / 17mm TL Rear Sway Bar / Tein S Tech Springs / Tokico Blues / Ingalls Camber Kit / Ingalls Stiffy
Old 11-16-2010, 09:52 PM
hillstones hillstones is offline
Sold the Accord
You need to remove the latch mechanism. You will have to unclip the two rods, one for the lock cylinder, and one for the door handle. Be careful, or you will break those clips too. Also, be careful not to bend the rods. Remove the three large screws on the side of the door next to the latch. Then pull the latch out of the door frame. You might have to remove the lower bolt for the window channel so you can move that out of the way to get the latch out of the door. Once you have the latch out, you can remove the cable and replace it. You might also want to consider replacing the door lock actuator since you will have the latch mechanism out of the door.
Tags
broken, door cable, sedan
Title goes here
close
video goes here
