HVAC unit replacement - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2006 Honda Accord Instructions
Old 03-03-2006, 02:15 PM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
SRS components are located in this area. Review the SRS component locations and the precautions and procedures before performing repairs or service.
NOTE:
Put on gloves to protect your hands.
Take care not to scratch the dashboard and related parts.
Lay a workshop towel under the parts when working on them to protect the face panel from scratches or other damage.
Do not work in a dusty or dirty place.
Discharge static electricity from your body before and during the work.
Do not touch the circuit board with your bare hands.
Do not work with dirty hands.
Be careful not to fold the flat plate cable.
Do not touch the terminal connector of the flat plate cable with your bare hands. (If you have touched it, wipe it off thoroughly.)
Make sure you have the anti-theft codes for the radio and navigation system, then write down the frequencies for the radio's preset buttons.
Remove the upper panel.
Remove the center pocket.
Remove the screws and bolts, disconnect the audio-HVAC display module connectors (A) and the antenna lead (B), then remove the audio-HVAC display module (C).
Install the audio-HVAC display module and note these items:
Make sure the disconnected connectors plugged in properly, and the antenna lead is connected properly.
Enter the anti-theft code for the radio, then enter the customer's radio station presets.
With climate control:
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 03-03-2006, 06:08 PM
princess's Avatar
ready to go....
audio wiring
Old 03-03-2006, 06:23 PM
princess's Avatar
ready to go....
wiring with remote
Old 03-03-2006, 06:26 PM
princess's Avatar
ready to go....
more hvac wiring
Old 03-03-2006, 06:27 PM
princess's Avatar
ready to go....
If you see a page number or photo mentioned that isn't here....ask & hopefully I can find it.
Old 03-03-2006, 07:15 PM
Accord4Life's Avatar
Accord4Life Accord4Life is offline
Can you say 270HP?
Thanks Princess! Im going to be helping a friend with a 2003 Honda Accord EX MT Sedan install his new headunit tomorrow. The first one filed with the notorious backlight problem. But he went on ebay and got a refurb head unit, for $215.00. Are there any strightforward instuctions are taking the dash apart? I'll do some searching and see what I find on the site.
Thanks,
Mike
BTW Congrats on breaking the 9k posts mark! :bananna: !
Current:
2004 ACURA TL ASPEC 6spd
2006 Honda Accord LX V6
1996 Honda Accord LX Sedan 100,045k
Previous:
2001 Honda Accord LX-L Sedan 103,422k
1989 Honda Accord SE-I Sedan MINT! 92k,
2006 Accord EX V6 6-spd Sedan! - 9k
2003 Honda Accord EX-L 5spd Sedan Totaled:( R.I.P. , 1986 Honda Accord LX Sedan - 127k in 2001 , 1984 Honda Accord LX Hatchback - 265k in 1999
Old 03-03-2006, 08:54 PM
princess's Avatar
ready to go....
1 of 4
remove upper dash panel
Special Tools Required
Upper panel/vent removal tool 07AAC-SDAA100
NOTE: Take care not to scratch the dashboard and related parts.
Push the hazard warning switch button (A). Carefully insert a flat-tip screwdriver into the slot (B) below the button, and push down on the center clip.
Old 03-03-2006, 08:56 PM
princess's Avatar
ready to go....
2 of 4
With the special tool and a flat-tip screwdriver
Set both ends of the special tool in the center vent openings (A) as shown. While pressing the center clip (B) down, pull the upper panel (C) back with the tool to detach the clips (D).
Old 03-03-2006, 08:58 PM
princess's Avatar
ready to go....
3 of 4
With two flat-tip screwdrivers
Carefully insert a flat-tip screwdriver wrapped with tape into the slot (A) on one side of the upper panel (B). While pressing down on the center clip (C), carefully pull out on the side of the panel to detach the clips (D). Repeat this operation on the other side of the panel.
Old 03-03-2006, 09:01 PM
princess's Avatar
ready to go....
4 of 4
Pull the upper panel (A) in the direction shown to release the remaining clips, disconnect the hazard warning switch connector (B), and if equipped, sunlight sensor connector (C) and navigation subdisplay connector (D). Detach the harness clips (E), then remove the upper panel.
Install the panel in the reverse order of removal, and make sure each connector is plugged in properly.
Old 03-03-2006, 09:03 PM
princess's Avatar
ready to go....
removing center pocket
NOTE:
Remove the center holder.
Remove the center pocket (A).
-1 Remove the screws (B).
-2 Open the lid, then pull the pocket back by hand to detach the clips (C).
-3 Close the lid, then remove the pocket.
Install the pocket in the reverse order of removal, and note these items:
Make sure the holders (D) are installed onto the pins (E) properly.
Push the clipped portions into place securely.
Make sure the center pocket lid opens smoothly.
Can you say 270HP?
Thanks Princess!!!
This helps us alot!
My Appreciation for you is unelxplainable!
Mike
Current:
Previous:
Old 03-03-2006, 09:06 PM
princess's Avatar
ready to go....
It should all be the same for the 06....
The gear shift area is 6 more pages....I'll do it in the morning. I'm pooped!
Old 03-03-2006, 09:18 PM
stevencrosbie's Avatar
stevencrosbie stevencrosbie is offline
Rule Enforcer
Send a message via AIM to stevencrosbie
All of this work for the interior trim. Makes me thing I should spring for the extended warranty.
-Steve (Moderator)
2015 Ram 2500 Crew Cab 6.7 Cummins Longhorn
2012 VW Golf TDI 4dr Tech Package 6MT
Forum Rules and Regulations
Originally Posted by Markus View Post
Here's a hint - if you don't want to be judged by what you write on an internet forum then don't write on an internet forum.
Old 03-03-2006, 09:21 PM
Can you say 270HP?
I don't think you should worry. The new 06 headunit on the EX's look redesigned in the lighting department, which leads me to think they got the clue.
Current:
Previous:
Title goes here
close
video goes here
