Windshield Washer Nozzles - Drive Accord Honda Forums
Old 12-01-2010, 11:41 AM
G Stone's Avatar
G Stone G Stone is offline
Greg
Mine are not spraying evenly. The passenger side sprays like all hell and the driver's side sprays very weakly. It barely sprays to the middle of the windshield. I checked the hose under the hood that the washer fluid runs through and looked for cracks or kinks. None found. I am thinking the only other thing it could be is sediment built up in the washer nozzle on the driver's side. Has anyone ever cleaned the washer nozzles and what should I use to clean them with? Any other advice on what it could be? Thanks for any help anyone might have.
2012 Hyundai Sonata SE Turbo
1999 Honda Accord EX Coupe - SOLD
3.0L V6
166,800 miles
35% Tint
Old 12-01-2010, 12:06 PM
redaccordcoupe's Avatar
redaccordcoupe redaccordcoupe is offline
Second gear slammer!
paperclip? staple? saftey pin?
run an air hose through them after and blow the shit out of it, instead of having the debris fall in further
Old 12-01-2010, 12:08 PM
sodaks2k sodaks2k is offline
Moderator
^try this. Other wise it could be the motor going out.
2014 MSM Accord Sport Sedan 6M
Old 12-01-2010, 12:20 PM
stiller fan's Avatar
stiller fan stiller fan is offline
next stop: 300k!!!
you could try some compressed air to clean it out with.
another way would be to take off the nozzle and soak it in warm soapy water....
my old 93 had cracked washer nozzles, where the hose meet the nozzle fitting. you could check those as well...
worst case scenario: get a new nozzle, and hope that the color matches ur car....
Originally Posted by craigslist ad
I'm 5'6'brown eyes,38 old,no child,but like. Please press 1 for English. No child, but like. You are child-like? You like no child? You like children? Sorry, the subscription for my translator is expired.
PROUD FAN OF STEELERS, PIRATES, AND PENGUINS
DA moderator
2007 Honda Accord LX Coupe 2.4 MT (201k miles)
gone, but not forgotten:
1993 Honda Accord (341k when sold, retired @ 369k)
1999 Honda Accord coupe (168k when sold, last check-in @ ~197k, blown head gasket)
next stop: 300k!!!
if it was the motor going out, then he would get weak pressure out of both nozzles, right?
DA moderator
Old 12-01-2010, 12:24 PM
Moderator
Yeah, you're probably right.
Old 12-01-2010, 06:17 PM
G Stone's Avatar
Greg
Thanks for the input guys. Do the nozzles come off easily? I may take them off and take a look at them and see if they are jammed with crap or cracked.
3.0L V6
166,800 miles
35% Tint
Old 12-01-2010, 06:20 PM
next stop: 300k!!!
there should be plastic tabs that are holding them to the hood underneath.... if you pop the tabs, they should come off without much issue...
DA moderator
Old 12-01-2010, 10:27 PM
Djmolina07 Djmolina07 is offline
They come off fairly easy, only a few clips hold the in.
Just shoot compressed air from a compressor through the tube connected to the nozzles an it should clear them.
I did this an it worked perfectly!
Old 12-02-2010, 07:45 AM
SatinSilver's Avatar
Moderator
CLR works very well also. Cleans your shower nozzle also. If you have any rusted paint chips dab with CLR 1st then touch up.
Old 12-07-2010, 07:49 AM
99' Ex-l coupe v6 *black current pearl. R.I.P.
00' ex coupe 5spd. *san marino red (daily)
86' hatchback lx-i 5spd *silver metallic (toy)
91 Prelude Si B20A5 frankenproject!!!
"when i fill my tank i go to stop and shop,to the rice aisle, pour in that uncle bens white rice. SON! the stuffs better than 110k"
Old 12-07-2010, 10:11 AM
next stop: 300k!!!
you make out ok???
DA moderator
Old 12-09-2010, 06:28 PM
G Stone's Avatar
Greg
I tried getting the nozzles off the other night and could only get one notch out on each of them. There seems to be 2 notches on either side that you press together, push up and out. I can only get one of those notches out of the hood. Didn't want to press too hard as I didn't want to break it. I finally get a weekend off this weekend so I'm going to try again. Any other suggestion? I may try pressing both tabs together with a needle-nose pliers if it comes to it.
3.0L V6
166,800 miles
35% Tint
Old 12-10-2010, 04:48 AM
CARVERitUP's Avatar
CARVERitUP CARVERitUP is offline
5th Gear
Send a message via Skype™ to CARVERitUP
Just go to your local auto store and get some of those "LED washer nozzle things" I have them but I just cut the wires so they're only used as nozzles. The things work beautifully! And they're under 20 bucks I believe. That's if you honestly don't know what to do about it. But take it from me, if you get some of those LED things, just cut the wires all the way up to the nozzle and just use them for their main function. They don't look to bad on cars either (make sure you get like black cased ones, because some of those chrome ones will peel)
EDIT: This is also an idea in case you're trying to take those things off to look at them and you happen to accidentally break one
2000 Honda Accord LX- 4CYL Sedan:
"JAIDA"
Thrush Welded Muffler
Airaid Throttle-Body Spacer
Spectre Cold Air Intake
K&N Cone Filter
Cosmetics
Black Housing Crystal Headlights
DDM Tuning Raptor HID Kit 35W 6000K (Just installed!)
Ultra White Series Fog Lights
Eyelids
Painted Blue Valve Cover/Painted Black Header Heat Shield
In The Future:
Eibach Racing Springs
Front Lip
18" rims
Detailing
Title goes here
close
video goes here
