Softer ride for my 2006 - Drive Accord Honda Forums
Old 12-09-2010, 01:10 PM
McGrady III's Avatar
McGrady III McGrady III is offline
2nd Gear
I have 90,000 on the original suspension and was looking to plan ahead for an alternative to OEM replacements. Plenty of people change their suspension to stiffen the ride or improve handling. I'm on the other end of the spectrum and want a softer smooth ride. Does anyone know where I find a ride like this without actually buying an old Buick or Cadillac?
2012 Accord SE Taffeta White + 2009 Odyssey EX
Old 12-09-2010, 02:24 PM
A&Fbro28's Avatar
A&Fbro28 A&Fbro28 is offline
Out of Control
Send a message via AIM to A&Fbro28 Send a message via Yahoo to A&Fbro28
Just so with a tire with softer sidewall i guess but keep in mind a softer side wall means number steering, Less quicker steering, and a tad less mpg.
Desmond,
08 Acura TL w/Technology Pkg
08 Taffeta White Honda Accord EX-L w/Navi Coupe (traded-in)
http://www.cardomain.com/ride/3093726
Old 12-09-2010, 06:14 PM
Deutsch Driver Deutsch Driver is offline
Goodyear has a purpose built tire for ride comfort: http://www.goodyeartires.com/tire/as...mfortred|Exact
I don't think you'll be able to find any suspension components that will improve ride comfort. Koni FSD shocks come to mind but they don't make any that fit the Accord.
2005 Desert Silver EXL-V6
Old 12-09-2010, 07:49 PM
Sultan's Avatar
Sultan Sultan is offline
Motor City
Tires make a decent difference in the ride...but hes going to have to continue buying new ones..
2010 Accord EX-L
Old 12-10-2010, 08:04 AM
FJRaccord FJRaccord is offline
Option 1: Buy soft touring tires and run OEM pressure or a hair lower.
Option 2: Buy a Camery
Old 12-10-2010, 10:28 PM
Knale's Avatar
Knale Knale is offline
2nd Gear
The only thing I can think of besides different tires as others have suggested is an adjustable dampening shock like Koni Sports (yellow). But, even at the full soft setting, is the ride softer than stock shocks? That I personally do not know. I have them, but I am not on stock springs.
My suspicion is, if you want a ride like a Buick or a Cadillac, you need to change cars.
Old 12-10-2010, 10:49 PM
Aviography's Avatar
Aviography Aviography is online now
OP,
At 90,000 miles, your OEM struts likely are close to the end of its useful life, which might be why you felt the ride is harsh.
While I enjoy good handling performance, I opted to add sway bars rather than sport springs/struts exactly because I didn't want to compromise the ride quality of OEM struts.
I am very happy with the combination, you may find a new set of OEM struts ride nicely compared to your 90,000 miles worn out ones.
Also keep in mind that softer sidewall tires will make your steering/cornering vague, I put Falkan ZE512 tires on my previous car, an 1996 Integra GSR, the ride definitely softened, but the handling took a nose dive even just in regular daily driving.........
I now run the Bridgestone RE960 Pole Position all-season ultra performance tires, loving every minute of it for the perfect combination of performance, comfort, quietness.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 12-10-2010, 11:18 PM
A&Fbro28's Avatar
Out of Control
see if you find oem struts on ebay with less miles. People are always modding their cars fast and selling barely used shocks, struts.
Desmond,
Old 12-10-2010, 11:59 PM
dmo069's Avatar
dmo069 dmo069 is offline
06 6MT Sedan
I have 4 OEM struts sitting in my garage. They have about 50K on them. Would you happen to be in the Dallas area?
2006 Accord Sedan 6MT Navi
Audio Control LC6I / Rockford Fosgate R600X5 / Infinity Reference 9633cf / Infinity Reference 6030cs / Rockford Fosgate Punch P1-2X10 / Parrot MK6000 / Diode Dynamics 6000K HID Low Beams / DDM 3000K HID Factory Fogs / Diode Dynamcs Stage II LED Conversion / Backup Camera / Mid Muffler Delete / Dynomax Exhaust Resonator / Fujita CAI / 17mm TL Rear Sway Bar / Tein S Tech Springs / Tokico Blues / Ingalls Camber Kit / Ingalls Stiffy
Old 12-16-2010, 07:41 AM
2nd Gear
Originally Posted by Aviography View Post
OP,
I always thought the ride would get softer with age. I love the car as is but if I could change anything it would be the ride. I don't want a camry or buick or Cadi but would love a softer ride. I looked into the Goodyear "soft" tires but read reviews that they were prone to defects in the inner belts.
Thanks for the comments on the Koni Shocks too. It would be great to know if they were softer on the lowest setting than OEM ones. I would get them if I knew that I could adjust them for a softer ride than I have now.
Old 12-16-2010, 08:17 AM
SatinSilver's Avatar
Moderator
I had 166k on my 99 on the original shocks/struts. I had them inspected at the dealer where I know the guys pretty well. They test drove it, inspected it and said they were fine. Struts were dry with no leaks.
Find a tire that has a soft ride BUT only drop the speed rating by 1 notch. If yours is a H rating drop it to a T rating. I believe thats the next increment lower off the top of my head. Don't go any lower or it will affect the handling too much in a negative way...aka buick handling.
The higher the speed rating the thicker the sidewall which consequently = stiffer ride.
I would look into some Cooper CS4's. Very quiet and nice ride.
Old 12-16-2010, 08:48 AM
2nd Gear
No, I'm near Detroit
Old 12-16-2010, 08:52 AM
2nd Gear
I replaced the tires last year to some BFgoodrich Advantage but I don't now the speed rating. I figured my shocks/struts were about to go due to mileage but I never thought they would last THAT long (166K).
Old 12-16-2010, 08:57 AM
Moderator
I did about 50/50 highway/city driving. Maybe a bit more highway. The OE struts are very expensive BUT they can last a long time.
The Coopers come in a V/h rating but also a T rating. Here is the link below.
http://www.coopertire.com/html/produ...=cs4_touring_t
Old 12-16-2010, 07:40 PM
A&Fbro28's Avatar
Out of Control
I hod Konis on my Prelude SH. On softest setting, they were firmer than stock. KYB G2 maybe what you want and are inexpensive. I'd call your dealer and ask for an answer which will help. Tires or shocks. Question. Has the ride changed to you since you 1st drove it?
Desmond,
Title goes here
close
video goes here
