Radio and LCD display turn on by themselves - Drive Accord Honda Forums
Old 12-31-2010, 02:12 PM
freeflight freeflight is offline
2nd Gear
Hi there,
I have a 04 Accord LX 4 cylinder sedan. It has 120K. The battery is 6 month old. Recently I found the factory radio and LCD display turn on by themselves, when the car is parked and locked without car key inside.
I tried to turn off the radio when I turn off the car. But it didn't help. The radio still turns on by itself. I found that if I change the volume to zero, then the radio stays off. But LCD display turns on and off by itself every few seconds with backlit. Both radio and LCD operate normally when I drive.
Can someone tell me what is the problem? How to fix it? Any input is highly appreciated.
Thanks,
Kevin
Old 01-04-2011, 12:42 AM
2nd Gear
Any input?
There is apparently a more serious circuit problem. I garaged the car for 5 days around Christmas. After that I couldn't start it, the battery is drained. I don't believe the LCD back lit can drain the battery that quickly.
I had to recharge the battery. Any pointer on how to go about fixing it? Thanks.
Old 01-04-2011, 09:20 PM
2nd Gear
Thanks. Will stop by Autozone this weekend.
Originally Posted by Dreamacre View Post
You have a short somewhere.
If you have an Advance Auto or Auto Zone near you, they have a computer thingy that will hook into your car and diagnose the problem, for free.
Old 01-15-2011, 03:20 PM
CivilMA CivilMA is offline
freeflight,
Did you find a solution? I have noticed the same problem with the radio turning on and the screen flashing after I turn off my '07 Accord. I did not drive for 2 days and found my battery had drained so I needed a jump start.
I tried changing the battery but this did not stop the radio from turning on. Next I pulled the fuse for the radio so my radio no longer works, but the battery has also not drained again.
Old 02-02-2011, 12:35 AM
2nd Gear
Hi CivilMA,
I haven't got a chance to fix it. After some research, I found this is a common problem with Accord.
In your case, the radio is clearly the culprit. What works for me is
1. turn the volume to zero
2. turn off the radio
Although the LCD backlit display still flashes, this keeps the radio off. LCD alone doesn't drain battery that fast. I can start the car without trouble after parked it for three days.
Hope this helps.
Kevin
Originally Posted by CivilMA View Post
freeflight,
Old 02-02-2011, 03:18 AM
Antarctica's Avatar
Antarctica Antarctica is offline
Forum Insomniac
Do you have any aftermarket mods? If so, they could have caused a short somewhere that affects your radio. It's possible two melted or uninsulated wires are touching each other. Just a thought.
2003 Honda Accord EX-L V6 6MT, Satin Silver Metallic
Infinity speakers with 3 Treo 10" subwoofers
Old 02-05-2011, 11:14 PM
2nd Gear
No mods what so ever. Will do a check when I got a chance.
Old 02-05-2011, 11:33 PM
Antarctica's Avatar
Forum Insomniac
Yeah that's just plain odd since the radio shouldn't be getting any power to itself other than the security system installed into the radio.
Old 02-07-2011, 04:40 PM
2nd Gear
I did some search on the Internet. It seems to be a relatively common problem with Accord. The problem is likely with the radio itself. Dealer's fix is to replace the factory radio for about $500+
Old 02-07-2011, 06:52 PM
I bought the car brand new and nothing has been added. Would an aftermarket radio solve the problem? I think I could get an aftermarket sterio for less than $500.
Old 02-08-2011, 08:15 AM
Yal Yal is offline
07 Sdn
Yeah for $500 i'd go aftermarket than replace.
Old 02-08-2011, 09:36 AM
CarlR33's Avatar
CarlR33 CarlR33 is online now
6th Gear
Or did you buy it used and somebody had installed/removed accessories before selling to you?
03 Accord LX I4 5spd, 230k miles.
Old 02-14-2011, 03:28 PM
I talked to an installer at Best Buy when I was looking at radios. He suggested the problem might be with a relay that gets stuck in the "on" position. Anyone familiar with the wiring or try replacing a relay?
Old 02-15-2011, 02:28 AM
MikeCz MikeCz is offline
Mike
Hi, some random thoughts, from memory there are no mechanical relays inside the radio, so the only relay he could be talking about would be a relay supplying ACC and IGN +12volts to the radio. However I donít think a separate relay exists for that circuit?
Apart from a 7.5 ampere switched circuit (IGN/ACC), there is also a permanent un-switched + 12v supply to the radio for real-time clock, security and last Radio/CD state etc. As itís appears to be a 10A circuit, I would think that this circuit is likely switched electronically (electronic relay if you like) in the radios and therefore could be the source of the problem.
There would be a number of ways the radio could fail and trigger this fault, without a circuit it would be hard to fix as there is a microprocessor controlling the on/off operation. I have never found a circuit of the internal radio/CD.
04 - V6 Auto Luxury Accord (Thail build).
Various DIY info.
Itís easy to be NASTY - Sometimes it takes a little more effort to be NICE.
Old 05-10-2011, 09:41 PM
2nd Gear
Good info, thanks.
I will take the car to Kragen for a test, see what those guys say about this problem.
Title goes here
close
video goes here
