Replacing speakers but no new aftermarket amp - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Audio & Electronics
Old 03-13-2006, 04:32 PM
DR0832 DR0832 is offline
How much of an improvement in sound can you get by replacing the factory speakers with some nice speakers like JL's but running them off the stock amp?
Old 03-13-2006, 05:23 PM
nicta nicta is offline
A lot! You will have a good laugh when you see the factory speakers.
Accord 06 lx 4 cylinder
Old 03-14-2006, 04:38 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
I replaced mine with Kickers and it really helped. They are begging for more power but that will come later.
Old 03-14-2006, 09:50 AM
SSMV6's Avatar
SSMV6 SSMV6 is offline
39.1 going on 40mpg!
Yeah! The stock speakers weigh next to nothing! (no exaggeration here).
2013 Accord EX-L Navi 6,612 miles and counting...
YTD avg mpg = 30.07 . . . . Last tank mpg = 33.84
2005 Accord EX-V6 Sedan (3/05-1/13) retired at 127,110 miles
1993 Accord 10th Anniversary Edition Sedan (5/08-7/10) Retired at 153,007 miles
2000 Civic Si (5/00-3/3/05) Retired at 59,500 miles
Old 03-14-2006, 08:21 PM
for you guys that replaced the fronts with 6.5's did you use a spacer of some sort or have to cut or drill to get them to fit. And for the rears was there anything you had to do. Do speakers cause the door panels or rear deck to rattle at all from the new speakers?
Old 03-15-2006, 01:40 AM
ThEvil0nE's Avatar
ThEvil0nE ThEvil0nE is offline
3rd Gear
If you want just to only replace the speakers and leave everything else a stock, I wouldn't recommend dropping anything other than Infinity Kappa Series speakers. They're not expensive and they're the best sounding speakers I've ever laid my ears upon when in replacement only the speakers.
Pro/comp level speakers needs high powered quality amps. If you should do a killer/SQ install in the future, my speaker recommendations to anyone... FOCAL and if you can't afford FOCALs then maybe you can get your hands on some MBQ (musicomp).
Speaker replacements are as typical as doing an R&R.
Old 03-15-2006, 08:41 AM
RTexasF's Avatar
Both pair of mine needed drilling and adaptors for the fronts. I'm not handy in that area so I paid to have it done. I also had sound deadening material applied in the front doors and across the rear shelf.
Old 03-20-2006, 12:14 PM
bbtaco bbtaco is offline
2nd Gear
I am thinking about upgrading the rear 6x9 speakers in my 06 Accord SE sedan. Would 3 way speakers be any better than 2 way? I can get Boston Acoustics S95 (2 way) or BA S953 (3 way) for the same price. Which would be better?
2006 Honda Accord LX SE Sedan auto in Graphite Pearl
2002 Toyota Tacoma extended cab TRD V6 4x4
1999 Honda Accord LX V6 Sedan
Old 03-21-2006, 01:50 PM
MajorDad MajorDad is offline
2nd Gear
either one will be better than stock. the magnet size in either of the speakers you listed will be much better than stock. you may be surprised when you change the OE speakers. either speaker will do just fine. it's based on your listening preferences.
2005 Accord LX I4 5sp
2005 Odyssey
2005 BMW 1150RT
1995 Nissan Kingcab 4x4
