06 V6 Coupe wont crank at all
Put the key in the ignition after forgetting something at my house, turned it over and nothing at all happened, no sound at all. Keyless Entry and all lights are working. Battery light and oil light are staying on though. Just had oil changed and car has never done this before. Have been reading about the stereo fuse being an issue and a few other things. Not a skilled mechanic but i can do simple stuff, not under warranty, so any advice would be helpful... Thanks
| Sponsored Links | ||
Advertisement | ||
It dont take much to drain the battery on these cars to where you could have lights and such but no start. I would start with jumping it and taking to a auto parts store for a free batter check and work from there first.
03 Accord LX I4 5spd, 216k miles. with 19 HFP Wheels and Eibach pro spring kit (second set as the first set of rear springs rusted apart). Previous car: 98 Civic EX 5sp. with 155K, RIP |
Wouldnt it still make some sort of noise even if it was the battery? I turned it off for maybe 5 mins... Do you know anything about the thing with the radio fuse?
I'd've thought you get at least a very slow crank, or some sign that shows the car is at least trying to tick over.
Current: 2003 Honda Accord EXL: 2008- Growing up: 1992 Chevrolet Cavalier: 2000-2008 1986 Pontiac 6000 LE: 1995-2000 1982 Honda Accord: 1993-1995 1979 Honda Civic: 1991-1993 |
It may be the crank sensor on that car, that happened to me when I had my altima and I was worried it was a fuel pump, but turned out being the crank sensor
2007 Accord Coupe V6 AT Taffeta White 20% tints all around tinted taillights 8k hids Ksport Lowering Springs SPC front and rear camber kit Tokico Struts |
2006 Accord Sedan 6MT Navi MTX REQ5 / Alpine MRP-F250 / Infinity Reference 9633cf / Infinity Reference 6030cs / Infinity Basslink II / Parrot MK6000 / Diode Dynamics 6000K HID Low Beams / DDM 3000K HID Factory Fogs / Diode Dynamcs Stage II LED Conversion / Backup Camera / Mid Muffler Delete / Dynomax Exhaust Resonator / Fujita CAI / 17mm TL Rear Sway Bar / Tein S Tech Springs / Tokico Blues / Ingalls Camber Kit / Ingalls Stiffy |
2005 Accord EX I-4 AUTO SEDAN. |
If nothing at all happens it could be the starter. After you try to jump it next have someone bang the starter while you try to crank. Also make sure it is fully in park look at the select light in the cluster. That happened to me a few times.
2007 EX-L 4DR |
Sounds like the new Fox show, "When batteries go bad".
I think it was at this site or v6p that I read that there are issues with the transmission "P" sensor. In other words when that sensor fails the car thinks it is in gear instead of "P" and it won't start. If you insert the key in the hole next to the shifter and move the shifter to "N", it may start.
I really appreciate all of the advice guys, i've tried everything you have suggested and determined that it was the starter. Im a newbie at mechanics, but i really want to attempt to change it myself. Sounds like a good idea to me right now, but looking at the engine bay kinda scares me. Not sure i really know where the starter is at... If you guys have any advice or if anybody would wanna walk me through the steps of removing it and locating it, i would def be appreciative. Wanna get familiar with my car and know how to do some things to it... Love this car!
Tried hitting the starter while cranking it and it did nothing... Lol! Got a little too confusing, so im having a mechanic friend come over and change it, he said its simple... Thanks for all of the advice once again guys!
Take a look at this http://www.alldatadiy.com/alldata/AF...0021/142223159
id almost garauntee its your terminals on your batt. take them off and clean them with terminal cleaner and a wire brush. and reinstall them. if its not that tap on your starter housing with a wrench. not hard, because there are magnets inside it which may break or crack if you beat them too hard. then give it another crank.. lemme know what you find out.
99' Ex-l coupe v6 *black current pearl. R.I.P. 00' ex coupe 5spd. *san marino red (daily) 86' hatchback lx-i 5spd *silver metallic (toy) "when i fill my tank i go to stop and shop,to the rice aisle, pour in that uncle bens white rice. SON! the stuffs better than 110k" |
Hey, I was reading something, the 05's had a recall about something breaking off in the fuel pump and rendering it useless......
Here is the link http://consumerguideauto.howstuffwor...a-accord-9.htm It does sound like the problem you described since you turned on the car and it ran and then died on you and now won't crank over. Just an idea maybe check the fuses etc and see if that is the problem. Because everything would work minus you being able to crank over if it had no fuel? Just an idea |
| Sponsored Links | |
Advertisement | |
