Reset the Check Engine Light - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 81 votes, 5.00 average. Display Modes
Old 01-07-2011, 02:20 PM
Citadel Citadel is offline
Does anyone know how to do a DIY reset of the check engine light? Had a HID kit installed and the light came on afterwards. Seems like a normal thing after researching. I called the local dealership and they said only way to clear it is by paying them $70 and running a programmer.
I know our other vehicles can be soft reset, and I understand earlier models could as well. So can anyone save me some time and money at the stealership?
Thanks
Old 01-07-2011, 02:36 PM
HaCk3rx's Avatar
HaCk3rx HaCk3rx is offline
Should Have Went 5peed
I dont think you can reset it... it turns on for a reason so i think youhave to find out what triggered it and fix it.
|2009 EX Coupe|BlackonBlack|
| TSX RSB|
| Tint 20/5 |
| HID 5000k |
| LED Interior |
| Odyssey Grille |
| Weather Tech Visors |
| OEM Rear Wing Spoiler |
| Type 2 DUAL Turn Signals |
| Nokya Yellow Fogs w/ Yellow Lamin-X Film |
If Life Gives you Drama, Let VTEC Kick in!
Old 01-07-2011, 03:09 PM
Aviography's Avatar
OP,
While some cars throw an error code when HID is installed, the 8th Gen Accord does not appear to be one of them, at least not based on experiences seen here on DA over the past couple of years.
Resetting the code when the prevailing fault is not fixed means the CEL will just return sometime later, you might as well just donate the $70 to your favorite charity!
You should have the code read (typically for free) by local PepBoy, AutoZone etc. to find out what the code points to, HID is most likely not the cause.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 01-07-2011, 04:30 PM
peter01592's Avatar
peter01592 peter01592 is offline
NJDR
Originally Posted by aviography View Post
op,
while some cars throw an error code when hid is installed, the 8th gen accord does not appear to be one of them, at least not based on experiences seen here on da over the past couple of years.
Resetting the code when the prevailing fault is not fixed means the cel will just return sometime later, you might as well just donate the $70 to your favorite charity!
You should have the code read (typically for free) by local pepboy, autozone etc. To find out what the code points to, hid is most likely not the cause.
+1+1+1
2009 honda accord coupe ex-l v6
MODS:
To many to list.
Old 01-07-2011, 04:43 PM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
You can reset it by disconnecting the battery but it will eventually show back up if there is still a problem but yea HID's won't cause a check "engine" light.
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 01-07-2011, 07:00 PM
Thanks all, I will have the code pulled tomorrow.
Old 01-07-2011, 07:19 PM
avs avs is offline
4th Gear
You can buy a OBD II reader for 20-30 bux at your local walmart.
Old 01-07-2011, 09:40 PM
xpshooter xpshooter is offline
3rd Gear
Sometimes the local auto store will allow you to clear the code after they tell you what it is.
Although it's not legal to just clear the code without fixing the problem, i have heard they will check the codes and when it comes to the point to clear the code on the diagnostic tool they will say "we can not clear the code for you, but if you push this button you will clear your code" this takes the liability away from them and puts it on you, because you cleared the code.
2010 Accord Coupe - Black - V6 - 6 spd
Old 01-08-2011, 10:37 AM
fastball fastball is offline
Honda Nation
The check engine light on all OBDII (all 1996 and later North American vehicles) vehicles reflects an issue with something in the emission controls, fuel delivery, ignition, timing, or exhaust system. Not related to electrical which it seems you may be correlating it to based on your presumption that it is related to your HID install.
It's just a coincidence it came on after you did your HIDs. You should have it checked..... your car should still be under warranty so your dealer should run the codes and repair the problem for free, unless you have over 60k on it (remember Honda warranty is 3/36 bumper to bumper and 5/60 on drivetrain)
If there was an electrical issue your battery or alternator indicator lamp would illuminate.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
Old 01-08-2011, 03:17 PM
Right you are. Took it to the dealership today, called us in the back and began telling us the O2 sensor was faulty. I asked him how and we walked under the car on a lift to see that a damn rat or something had chewed through the harness/wire. Here's the real damage...it's going to cost ~$400 to replace both harness and sensor, and apparently such damage is not covered under warranty.
Old 01-08-2011, 04:01 PM
Danielc409's Avatar
Did the dealer tell you that or is that how it actually looks.
No longer owned
Old 01-09-2011, 06:10 AM
I'll admit it looked legit. We walked into their service garage and had the car on a lift so we walked under it, and low and behold...two spots where the wire had been chewed and mangled.
Old 01-09-2011, 06:35 AM
pghturbo88 pghturbo88 is offline
2nd Gear
400 bucks? Really? I do not know the extent of your damage, but if it were me, I'd splice/solder/patch the wiring. I would also use heat shrink tubing to protect the repair. Unless the wiring was completely obliterated, I see no reason why a decent mechanic or auto electric shop could not make a full repair of the existing wiring (for a lot less money).
1988 Chrysler LeBaron 2.2L Turbo Convertible (original owner)
1989 Chevrolet Beretta GT 2.8L (original owner)
1996 Chrysler Town & Country 3.8L
2009 Honda Accord EX Sedan 2.4L (original owner)
Old 06-07-2012, 07:47 PM
Booch Booch is offline
My First Post
Well as a guy that just replaced the o2 sensor in my 2007 I can say the "harness" is part of the sensor. The "harness" is 30 inches long and runs continuous from the sensor s rewed into the catalytic converter thru 4 clips (provided) to a rubber plug on the floor provided to a clip plug under the passenger seat. Undo the passenger seat w a 14mm wrench and the connection. Is obvious. There is no harness. Just a sensor with a long wire sold to me at autozone for 62 bucks with 25 dollars to use the special slotted socket set. The 25 comes back when I return it.
Granted it was a pita to get under the car, unbolt the seat, buy the part, return the tool and reset the light but 300 bucks saved gave me the chance to do this w my 20 year old son.
You probably did right taking it in as jacking and blocking up a car isn't for everyone.
Old 06-07-2012, 08:02 PM
PatronTequila's Avatar
PatronTequila PatronTequila is offline
4th Gear
Rats are known to chew through wiring, that' why Honda even has "Rodent Deterrent Tape":
http://www.bernardiparts.com/products/4019-2317.aspx
Title goes here
close
video goes here
