CEL came on, what could be the problem? - Drive Accord Honda Forums
Old 01-07-2011, 05:42 PM
NightMarcher01's Avatar
NightMarcher01 NightMarcher01 is offline
aka 'The Gif King'
Took it to Autozone to scan it. Here's what I got:
Troubleshooting P0134
Definition-
A/F sensor 1 heater system malfunction
Probable Cause-
-Open or short circuit condition
-Poor Electrical Connection
-Faulty A/F sensor 1
A few days ago, the CEL came on, I checked the engine, and the air filter of my CAI came off. So I guess that was the problem, but the thing is, I couldn't get into until I came home, so I probably drove a good 50-75 miles before coming home.
I put it back on, and the CEL was still on. Then I cleaned the MAF sensor and disconnected the battery, and the CEL went away. 20 miles later, it comes back on. So this time I checked both o2 sensor and primary sensor, both are good. So I disconnected the battery again and connected it (this time I made sure it was tight, because it said it could be poor electrical connection) anway this time it was better, went about 50 miles...... then BAM, it turns on again.
Any help is appreciated! Thank you.
2003 Honda Accord Sedan
http://www.cardomain.com/ride/3877738
CHECK IT OUT!
Old 01-07-2011, 05:59 PM
IVT3C's Avatar
IVT3C IVT3C is offline
2nd Gear
I read some where on a DIY forum for a test pipe that he ran into this issue with the CEL. That it didnt come on right after they installed it, but a little while later.
2003 Honda Accord Sedan i4 Auto.
Old 01-07-2011, 06:06 PM
aka 'The Gif King'
Naww bro I sold the test pipe way back ago. I put the OEM back on, it's been fine ever since!
It happened ever since the stupid air filter came, and I been ****ing up dirty air that whole day
CHECK IT OUT!
Old 01-07-2011, 06:08 PM
IVT3C's Avatar
2nd Gear
oh damn, well i have no clue then, i dont even have a MAF.
Old 01-07-2011, 07:09 PM
AMAN1 AMAN1 is offline
6th Gear
Assuming it's because of the filter coming off, have you checked the throttle body? I highly doubt that's the cause, but you never know.
Current:
2003 Honda Accord EXL: 2008-
Growing up:
1992 Chevrolet Cavalier: 2000-2008
1986 Pontiac 6000 LE: 1995-2000
1982 Honda Accord: 1993-1995
1979 Honda Civic: 1991-1993
Old 01-07-2011, 07:46 PM
aka 'The Gif King'
A guy at V6 said it was the primary sensor since it said sensor bank 1. Should I go ahead and replace it? Should I try a seafoam treatment?
CHECK IT OUT!
Old 01-07-2011, 11:32 PM
OPTiiCKz OPTiiCKz is offline
2004 Accord Coupe
Mine did this same thing recently then one day just went off....hasn't been back on in about 2 weeks and it was on for probably 2 months.
Old 01-08-2011, 12:44 AM
aka 'The Gif King'
Any idea on it could have been?
CHECK IT OUT!
Old 01-08-2011, 02:22 AM
Drew03Accord Drew03Accord is offline
6th Gear
Well, it's a sensor for sure. It's either your primary oxygen sensor or the Air/fuel ratio sensor, which according to Google, is a separate and more expensive sensor.
Old 01-08-2011, 06:05 AM
ak1059 ak1059 is offline
I had this problem after I changed an air filter before. A vacuum line came disconnected from the air box when I took it off to swap the filter. I did the same things as you cleaned the maf and cel went off for 20 mins or so. Then I noticed a vacuum line had came disconnected. Check all vacuum lines from the throttle body to the air box.
Old 01-10-2011, 12:33 PM
aka 'The Gif King'
So I bought a code reader, it's actually a P1157 code.
Same thing having to do with A/F sensor, should I go ahead and replace it?
CHECK IT OUT!
Old 01-10-2011, 01:25 PM
6th Gear
Sounds like the right thing to do, yes. Let us know how it works out.
