Power steering pump groaning noise... again! - Drive Accord Honda Forums
Old 01-13-2011, 05:51 PM
Antarctica's Avatar
Antarctica Antarctica is offline
Forum Insomniac
Hey all, to start off, my power steering pump used to make a whining noise every time I started my car, so I followed the DIY for replacing the power steering pump o-ring (http://www.driveaccord.net/forums/sh...ad.php?t=42915). That shut up the whining noise for a while until a couple days ago. I don't know if it has to do with the temperature here being in the high 20s and mid 30s or if I put on the o-ring wrong, but the whining and groaning noise has come back, and this time it doesn't go away like it used to when the engine is warm.
So, do any of you have a solution to this problem? I'm going to replace my drive belt tomorrow with the Goodyear Gatorback, so maybe I can fix this power steering noise while I'm under the hood. I'm thinking somehow when I replaced the old o-ring, maybe I put the new one in wrong. I'm not too sure. Anyway, any help would be appreciated. Thanks.
2003 Honda Accord EX-L V6 6MT, Satin Silver Metallic
Infinity speakers with 3 Treo 10" subwoofers
Old 01-13-2011, 06:00 PM
Drew03Accord's Avatar
Drew03Accord Drew03Accord is offline
Out of Control
Maybe the pump is bad and you need a new pump.
Old 01-13-2011, 06:19 PM
Cholung's Avatar
Cholung Cholung is offline
how old is the fluid?? try flushing out the pump with fresh fluid then changing it again to clean out any debris. if it still occurs you may need a pump
Old 01-13-2011, 09:48 PM
Ilovemy06VtecV6 Ilovemy06VtecV6 is offline
banned
Wait till you feeeeel how buttery smooth your steering will be after you replace the PS pump and drive belt. I was like you, I would have normally not replaced anything early to protect and keep the total cost of ownership(TCO) low to justify a Honda even more. I replaced the drive belt almost by accident because the power steering hoses broke on separate days and the 2nd time, PS fluid spilled on the drivebelt thus prompting replacement prematurely. But after seeing hos smooth, easy and literally effortless it is to turn the steering wheel, replacing the pump *and* drivebelt is something I would do early because the benefits are so great. Trust
Old 01-14-2011, 02:16 AM
Antarctica's Avatar
Forum Insomniac
Alright guys. I added some power steering fluid while I was at the gas station earlier and that shut up the problem. My car has approximately 91,000 miles, and maybe a new pump would help, but I'm going to try some other things right now like replacing my drive belt tomorrow. As far as the flush goes, how do I properly go about that? As a last resort, I'll go and replace the pump.
Old 01-14-2011, 05:15 AM
CarlR33's Avatar
CarlR33 CarlR33 is offline
6th Gear
Take something to pull out the old fluid out (**** out) of the pump like a turkey baster. Add new fluid back in and run for a few weeks and repeat process. I had to repeat the process because the dirty fluid that remains in the steering rack and needs circulated through the system.
03 Accord LX I4 5spd, 230k miles.
Old 01-14-2011, 09:20 AM
Antarctica's Avatar
Forum Insomniac
Okay, I get it. Drain and refill, and then drain and refill again a couple weeks later. Easy enough.
I'm gonna do some other maintenance later today, but damn it's so cold outside! I hope it warms up later today.
Old 01-14-2011, 11:11 AM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
If you had to add fluid and the noise stopped that means the fluid was low. You might have a leak in the system. When you changed the o-ring did you top off the fluid? Check the fluid in a week to see if the level changed.
The pump could be leaking at the seals or it could also be a line.
2007 EX-L 4DR
Old 01-14-2011, 05:28 PM
Antarctica's Avatar
Forum Insomniac
You're right. I checked my fluid and it's apparently leaking. I looked under the car and found power steering fluid along my frame on the passenger side. The lines are fine around the reservoir and low pressure side. I did notice some fluid around the metal high pressure line where it comes out of the pump, but I don't think there's enough fluid there to actually cause the leak I'm looking for. I hope it's an easy fix. And you know what? I didn't have this problem until I replaced the o-ring. I don't know if this is coincidental though.
Old 01-15-2011, 08:49 AM
03LXV6's Avatar
Moderator
You wont notice a leak by looking at the hose. When the wheel is being turned that's when there is pressure and you will notice a leak.
2007 EX-L 4DR
Old 01-15-2011, 07:50 PM
Antarctica's Avatar
Forum Insomniac
So I did my oil change today and noticed power steering fluid around and near a rubber boot that's connected to the front axle. The line connected to the boot is metal, and I'm thinking it's a high pressure line. I'm hoping it's just a gasket or something rubber that's easy to replace and not the whole metal line.
Title goes here
close
video goes here
