Quick question... how often for tune up? - Drive Accord Honda Forums
Old 01-31-2011, 09:24 AM
k1ngkev1n1 k1ngkev1n1 is offline
3rd Gear
Have a 2010 honda accord sedan EXL. I only have about 6000 miles on it and in may will be the 1 year mark of having the car. I probably will have about 10000 miles by then how often are you supposed to get a tune up? and what is a reasonable price? (I am not tech savy).
Thank you in advance
Old 01-31-2011, 09:42 AM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
What exactly do you consider a tune up? Just read your owners manual and follow the maintenance minder.
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 01-31-2011, 09:44 AM
GoLowDrew's Avatar
GoLowDrew GoLowDrew is offline
Low Gear
There is really nothing to tune in today's cars, or should I even say yesterday's cars too. That term is now just being past on with no real meaning.
We would need to "tune" the old cars with carburetor and idle. Today, everything is electronic and it tunes itself.
Change the oil. Check the filters, rotate the tires, and that's about it. And if there is a TSB, have the dealer take care of that, if necessary.
So don't let anyone sell you a "tune up package" or "lube the chassis" too. There is nothing to lube because it's all sealed.
2010 Accord EX-L V6 Sedan.
2009 Odyssey EX-L RES
Old 01-31-2011, 09:56 AM
3rd Gear
I am going to a oil change every 6 onths (about every 5k miles) and also rotate tires every other oil change sound ok? I tend to take care of my car pretty well. Just want to make sure everything stays in top notch shape.
Old 01-31-2011, 09:57 AM
toomanyaccords toomanyaccords is offline
3rd Gear
Quick Answers:
> Do not read your owner's manual.
> Take your car to the dealer for a tune-up, which includes multiple inspections and a cabin filter replacement. Each of these tasks is so technically challenging that only a trained Honda tech has the skills to do it. The tune-up will cost about $600 to $1000.
Thank you for supporting your local dealer.
2008 Accord LXP 4dr 4cyl 5AT
Old 01-31-2011, 10:05 AM
3rd Gear
Originally Posted by toomanyaccords View Post
Quick Answers:
thanks for the advice sounds pretty legit....
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
What engine do you have? The V-6 requires a timing belt and a few other items (water pump, tensioner, spark plugs) around 105,000 miles. Actually the water pump isn't required then but it's smart to do so.
The four cylinder has a timing chain so it's essentially spark plugs around 105K and possibly a valve adjustment. Water pump could also be done then.
As far as oil changes use the oil life monitor on the car, it's extremely accurate. Look in the manual for suggested tire rotation. There's a lot in that book but one must read it to gain knowledge.
Old 01-31-2011, 11:00 AM
3rd Gear
I have a 4 cylinder i will look in the manual. thank you so much for your input though appreciate it greatly.
Old 01-31-2011, 11:46 AM
Zembonez's Avatar
Zembonez Zembonez is offline
Also available in sober.
Tune ups are a thing of the past. Keep the fluids changes as required and drive. Check your manual for the maintenance schedule.
2010 Honda Accord EX - 2007 GMC Sierra - 1981 Mazda RX7 - 97 Mazda Miata
Old 01-31-2011, 01:27 PM
fastball fastball is offline
Honda Nation
Last car my family ever owned including my parents and Grandparents was a 1985 Buick Regal. Had to do the points/plugs/timing adjustment every 30k.
Ever since the mid-1990s virtually all cars have been tuneup free. The advent of fuel injection, better engine design and tolerances, and more efficient overall operation has made the old tune up a thing of the past.
May 2009 - Present: 2009 Accord V6 6 MT coupe w/o nav, Alabaster Silver
Dec. 1999 - May 2010: 2000 Prelude 5 MT, sold with 220,000 miles and still running great - gone, but not forgotten
Old 02-02-2011, 07:08 AM
09 ACCORD COUPE's Avatar
09 ACCORD COUPE 09 ACCORD COUPE is offline
09ACCORDCOUPE
3,000 myth
You can forget the 3,000 mile oil change myth too:
http://www.moneybluebook.com/the-300...ve-your-money/
09 Accord Coupe BBP/BLK Leather EX-L V6 6MT Navi
05 Acura TL NBP/BLK Leather 5AT Navi
FIRST CAR- 1971 BMW 2000, IN 1982
Old 02-02-2011, 07:26 AM
GoLowDrew's Avatar
Low Gear
As much as this is true, there are actually benefits to changing things a bit early. Take ATF. Many Honda Auto trans owners would change and replace their ATF 2X as early from what the owner's manual said, and some even do it every year.
Is it a direct guarantee? No. Is it a good prevention? Maybe.
An extra $36 every two years (DIY) is better than $3,000 for a transmission.
