Foaming power steering fluid - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 03-23-2006, 05:56 PM
91EX 91EX is offline
Go Tigers!
My rack and pinion has had a slow leak so I decided to add some Lucas power steering stop leak. This was a few months ago. It has kept leaking but very little.
The last two days I've noticed that fluid is overflowing out of the resevoir. It is very foamy. I don't notice any change in steering effort.
Is this a sign of pump on its way out or is this a result of using the Lucas product?
I remember reading in a post on one of the many boards I belong to that this, or one of their other products, caused foaming.
Thanks.
Old 03-23-2006, 08:58 PM
Inspector1's Avatar
Inspector1 Inspector1 is offline
O do u know the buffinman
It's probably the Lucas stuff, I have read that also on the BTOG forum.
Time to flush the system
I1
4 Honda family...
08 EXL V6 W/Nav PMM 4Dr @ 111K miles
My daily driver
08 Pilot EX-L Dark Cherry Pearl @ 48K miles
The Mrs. daily driver
The Kids
07 EXL I4 Moroccan Red Pearl 4Dr @ 88K Acquired 6/13
06 EXL I4 Carbon Bronze Pearl 4Dr @ 100K Acquired 3/13
Gone but not forgotten....
02 EXV6 Naples Gold 4Dr
96 VP I4 Heathermist 4Dr
Old 03-24-2006, 03:36 PM
Go Tigers!
I drained as much as possible w/o running the pump, then refilled and ran. I did this twice and am still getting foam. Not sure if it will still overflow or not, only time will tell.
While running, is it normal to see some foaming in the res.?
Old 03-26-2006, 04:19 AM
RTexasF's Avatar
RTexasF RTexasF is offline
Old Bird...sometimes wise
No it's not!
Old 03-26-2006, 04:27 PM
Go Tigers!
If it's not normal, then what's the cause? Contaminated fluid or pump going south?
Old 03-28-2006, 08:05 AM
Go Tigers!
Now I'm getting a sort of whine while turning under idle or low acceleration. It's a sound that sounds like rubbing you finger against a clean glass window. After I hear this, I have the overflowing problem. I don't believe it's any suspension parts. Still have the foaming issue too. Maybe the pump or the steering rack? Any ideas?
Thanks
Al
Old 03-28-2006, 04:26 PM
Inspector1's Avatar
Sounds like a pump problem with the noise you are hearing.
I1
4 Honda family...
My daily driver
The Kids
Old 03-29-2006, 07:21 PM
Fredsvt's Avatar
Fredsvt Fredsvt is offline
Moderator
You have a suction side leak (return) either the rack is pulling in air somehow or the oring on the p/s pump inlet is no good. (the little bolt on elbow with the clamped line going to the reservoir)
The oring is fairly common, did you recently have belts or a timing belt done?
Disturbing the pump is sometimes enough to cause this. The orings rarely leak fluid, but will pull in air.
Air in a hydraulic pump will cause whining.
Old 03-30-2006, 05:10 AM
Go Tigers!
I did do the belts not long ago, about a month. A chipmunk was in the engine compartment and when I started the car...(you get the idea). Should I replace the o-ring or just try tightening it first? The car is down right now anyway, putting in a new radiator.
Old 03-30-2006, 12:36 PM
Go Tigers!
Well I don't think the return line on the p/s pump is the culprit. I do believe that a leak is causing air to get into the system. I do have a leak in the steering rack and as a result of further investigation, a leaking boot on the tie rod.
Now here's another question:
Does the boot seal the steering fluid or is there a seal on the tie rod itself going into the rack?
Auto parts stores sell a replacement boot kit, but if the seal is bad, that won't cure the problem.
What do y'all think.
Thanks
Al
Old 03-30-2006, 04:22 PM
Fredsvt's Avatar
Moderator
The piston seal inside the rack is bad, the boots are not supposed to fill up with fluid. Time for a rack.
It's unlikely that the rack leaking will cause you to have an air leak, as those pistons work under pressure.
The return fittings may look just fine, and the bolts will be tight, but for some reason the orings, once aged don't like to be disturbed. For the couple of cents the oring costs you could try it.
A more rare problem is a leaking shaft seal on the pump. They may get a little damp, but for some reason on longer runs they pull in air.
I've seen some, not just Hondas, that do this, and the reservoir ends up gushing out foam after a highway run.
Old 03-30-2006, 05:47 PM
Go Tigers!
The line that goes directly from the res. to pump(return?), has a pressed fitting in the pump. The exit for the pump has a bolted on fitting with an o-ring. Fredsvt, which fitting are you refering to?
You hit the nail on the head about the res. overflowing after being on the highway for a while. Do you think I should swap out the pump? Or is there a rebuild kit for it and would that be worth it?
Old 03-31-2006, 07:17 PM
Fredsvt's Avatar
Moderator
I'm sorry, I could be having a brain fart here. Most of the later models have a bolt on return (supply) fitting with a spring clamp on the line.
While checking online, your's does have the pressed in return. My bad.
I've seen several of the pumps, mainly on Integras leak from the pump body itself. I'm sure you could buy all the needed parts to rebuild it yourself, I'd price it both ways though. If you have any severely worn internal parts, it may make the diy rebuild worth it.
Stick with Honda parts. I'm not trying to be a pita in regards to aftermarket stuff. But, I've seen many horrors lately with aftermarket reman parts.
I think Honda offers a reman pump. I just checked online and they only show a new one on the online parts lists that I use. Wow! Made me wake up quick. Damn expensive bugger it is.
Old 04-06-2006, 01:51 PM
Go Tigers!
I replaced the pump shaft seal today. I ran it for a few minutes just idling in the drive and no foaming. I know that it was leaking from that seal as when I removed the pulley, there were signs of leakage down the front of the pump. I just hope that ended my foaming problems. I still have the leaking rack, but that's another project.
A seal for 6.29 beats paying 200 or so for a rebuilt pump.
Thanks Fredsvt for all your help.
By the way, the threads on the p/s pump shaft are lefthanded for future references.
Old 04-11-2006, 05:59 AM
06accordexl 06accordexl is offline
Use only Honda approved fluid
In the past if Honda approved was not used it will cause foaming. This will also cause noise.
2003 Honda Odyssey
2006 Accord EX-L Carbon Bronze Pearl
rear decklid spoiler, mud flaps and pinstriping
Title goes here
close
video goes here
