02 Accord sputtering around 4000 rpm - Drive Accord Honda Forums
Old 02-18-2011, 06:12 PM
koolfrog koolfrog is offline
My First Post
My Wife's 2002 Accord EX I4 with At with 220k. All mantience has been done at the dealer. Today during hard acceleration the car started sputtering between 3500- 4000 rpm. The tach was bouncing back and forth between those numbers and the car kinda jerking along. Let off the acclerator it goes way and runs fine. Get back on it and it does it again, when it reaches 4000 rpm. It is due for a service next week. Any ideas?
Old 02-20-2011, 10:28 AM
pbm517 pbm517 is offline
2nd Gear
My 2001, with half those miles, started doing the same thing intermittantly (along with a CEL). I changed the cap, rotor and wires and it went away ...or so I thought.
It started doing it again yesterday (along with the CEL coming back). I'm now thinking it's an ignition coil problem.
Old 02-20-2011, 11:12 AM
sodaks2k sodaks2k is offline
Moderator
I'd guess the plugs, cap, and rotor. When was the last time they were done?
Did you ever get the CEL read? It does no good to guess when you can know by having it read.
2014 MSM Accord Sport Sedan 6M
Old 02-20-2011, 11:38 AM
2nd Gear
I wasn't given the code (number) but the mechanic said "it needed a tune-up" after checking it with the code reader.
I had changed the plugs at 80K but the cap, rotor and wires were original so I assumed....
I hate to give the dealer $100 to read a code...because I'm certainly not paying the dealer to change the cap. rotor and wires (or possibly the coil which is $87 at Bernardi parts).
Mine is 'sputtering' at 3K on the tach and once I stay below that it's OK.
Do you think ignition coil is a good prognosis?
Old 02-21-2011, 11:47 AM
Moderator
It could be the coil pack. Autozone and Advanced Auto check/read codes for free where I live. I know in some states that can't though. Give them a call (if you haven't) and see if they can. Don't worry so much about the wires as OEM wires are pretty good. I noticed a difference in mine after changing the cap and rotor as mine would slightly hesitate from 2.5-3k. That was around 170k miles I think.
Title goes here
close
video goes here
