Wind/ Whistling noise - 2009 Accord - Drive Accord Honda Forums
Old 02-24-2011, 06:08 PM
danc danc is offline
I know there are a few threads around this but I couldn't find anything relating to an actual fix that worked. Has anyone figured out a fix for the wind/whistling noise you here once you hit 55 mph?
Thanks
Old 02-24-2011, 06:09 PM
AccordV6-271's Avatar
AccordV6-271 AccordV6-271 is offline
4th Gear
Thanks
Thanks for posting this....id like to know too.....i have a 2010 coupe and it is also tainted with this problem...
Old 02-24-2011, 06:23 PM
h2oboy's Avatar
h2oboy h2oboy is offline
2nd Gear
1st where r u hearing it? do u have a pwr roof if so try cleaning around the molding around the roof the dealer told me that dust/dirt can get in there & cause a wind noise "it worked for me" try it & c
h2oboy's Avatar
2nd Gear
Thanks
Old 02-25-2011, 01:18 PM
It sounds like it is coming from the front windshield but it is very hard to pinpoint. I do have the moonroof and will try your idea.
Thanks
Old 03-01-2011, 09:04 AM
h2oboy's Avatar
2nd Gear
Thanks
Old 03-02-2011, 05:27 PM
4th Gear
I took it to the dealer and mentioned the problem. I also told them what I thought was causing it.
There is chrome trim on the door.....there is the same trim on the rear window.
They line up and meet at the edge of the door(when closed).
On the passenger door, the trim on the door was higher then that of the window. As the car is moving, air glides over them like a slide.
On the driver door, the trim on the door was LOWER than the trim on the window. This is also where the noise was coming from. (Air was hitting the second piece of trim....Not like a slide.
They removed and fixed the trim.....Noise is gone ATM
2010 Accord Coupe EX-L V6 6MT
Mods:
OEM Splash Guards / OEM Floor Matts / OEM Trunk Tray / License Plate Frames / 18x8 Moda MD7 Rims / Michelin X-ICE Winter Tires / Black Exhaust Tips / OEM Cargo Net / 8000K HID Lows / 3000K HID Fogs / Cosmo Short shifter / 25mm spacers in the rear and 20mm spacers in the front w/ stock rims / Shifter bushings / JDM grille / Plasti DIP!!!
Old 03-04-2011, 07:30 PM
frankbarry frankbarry is offline
My First Post
2009 Accord Whistle
We just purchased this one with a "Perfect Fit" bug deflector and was told by the dealer that it was not a Honda product and likely the cause. Today we put rags between the guard and the hood- Voila no more whistle.
Does any body have a real solution to eliminate the noise.
Title goes here
close
video goes here
