Windshield Washer fluid not spraying out(can't hear motor running either) - Drive Accord Honda Forums
Old 03-08-2011, 06:25 PM
hondaguy2582's Avatar
hondaguy2582 hondaguy2582 is offline
3rd Gear
Vehicle is a 2003 accord ex(parents vehicle). Has happened once under cold temperatures where the cold temps caused the lines to freeze. The dealer did the recall on the wiper motor, but not the pump at the time.
Fast forward to now, the pump doesn't run or spray anything. Fuse is good. Just wondering if I should just replace the entire washer motor?
Thanks,
Old 03-09-2011, 12:12 AM
paperboy42190's Avatar
paperboy42190 paperboy42190 is offline
Out of Control
double check if the connection near the washer reservoir is still good. mine didnt work and i found out it was because the connection came loose
2007 Acura TL Type-S
Old 03-09-2011, 05:46 AM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
Is it not working in the cold again? Is it well below freezing? The washer motor in some cars can be very hard to hear when the engine is running. I was trying to help a friend troubleshoot the same problem about 2 weeks ago on his non Honda and neither of us could hear the washer motor. When it warmed up a few days later his washers worked like a champ. You might want to wait for a warm up before you spend any money on a pump.
2006 Accord Coupe silver 6 speed
Old 04-18-2011, 12:52 PM
JCaccord08 JCaccord08 is offline
i have a 2008 honda accord coup LX-S and my fluid doesnt come out and also i don't hear the motor, but its been like this for one week, it was kinda cold here in jersey, so ima give it about another week or so if nothing then dealer here i come..lol..
Title goes here
close
video goes here
