Honda should issue a Recall on VTC actuator issues then a TSB - Drive Accord Honda Forums
View Poll Results: VTC Failure
Recall 7 77.78%
STB 2 22.22%
Voters: 9. You may not vote on this poll
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 03-31-2011, 03:22 PM
Rattmann Rattmann is offline
5th Gear
VTC Recall or TSB
The result of VTC actuator complete mechanical failure is catastrophic.
The valves from the intake of either cylinder 2&3 or 1&4 WILL result in a tensioner to fail and a fantastic collision of the valve with the piston.
This is exactly what happened to my K24Z3 motor.
Honda took the engine for further investigation and research.
They gave me a New Engine as a Fix for my 2008ExLnav accord
All this at 50K miles.
The Following 2 Users Say Thank You to Rattmann For This Useful Post:
08EX-L (07-24-2014), Sean D. (05-19-2014)
Old 03-31-2011, 03:42 PM
rox08cpe rox08cpe is offline
I hope that you do a recall. I wanna take my car in for the tsb but I'm afraid they are going to charge me if I take it.
Old 03-31-2011, 03:48 PM
johnnydinh701's Avatar
johnnydinh701 johnnydinh701 is offline
Dats da way to do...
Send a message via AIM to johnnydinh701
i tried to shove the tsb in their face about this but they said its not an issue unless my car really does fail.... ??
Old 03-31-2011, 03:55 PM
I forgot to mention my car has 70k miles so It passed the powertrain warranty. ****s
Old 03-31-2011, 03:56 PM
Edaccord08 Edaccord08 is offline
Out of Control
Originally Posted by Rattmann View Post
VTC Recall or TSB
Sorry, you had problems but I doubt very much there will be a recall . How many vehicles did this affect ? . It would have to be massive amount for recall or a safety issue which its not .
To bad you don't have pics of the parts, I be interested to see what happened .
Here is my opinion of what happened .
1) If nothing else goes wrong the VTC only allows 50 deg variance in the intake cam . As long as nothing happens to tension the valves can't hit the pistons no matter of cam is 0 -50deg (this is a normal amount during driving ) .
I think what happened to yours is you had tensioner failure maybe both VTC and tensioner . the only way I can see VTC causing a piston to valve issue is if the VTC housing broke apart leading it to more than 50deg movement .
Glad you got your car back an fixed .
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 03-31-2011, 03:59 PM
GoLowDrew's Avatar
GoLowDrew GoLowDrew is offline
Low Gear
Unfortunately, that's how TSB works. When you think maybe Honda can gain a lot (or avoid loosing) goodwill by checking and redo things if necessary to start to give owners the trouble-free experience they expect in a Honda product.
TSB is there to show them how to fix a common problem in hope of saving some diagnostic time. It's not suppose to be a prevention kind of thing (too bad).
2010 Accord EX-L V6 Sedan.
2014 Odyssey Touring Elite
Old 03-31-2011, 04:04 PM
5th Gear
As you said, "I think what happened to yours is you had tensioner failure maybe both VTC and tensioner . the only way I can see VTC causing a piston to valve issue is if the VTC housing broke apart leading it to more than 50deg movement", This is the exact case.
Too bad Honda will not show me the parts or the exact reason but only allude to the above.
What I am saying is to watch out when the warranty runs out!
Old 04-13-2011, 06:14 AM
shadow85's Avatar
shadow85 shadow85 is offline
5th Gear
Honda needs another sueing like the Rear Brake Settlement.
2013 ACCORD EX I4 Sdn MSM
2008 ACCORD LX-P I4 Sdn PMM
Old 04-13-2011, 06:34 AM
Out of Control
You have to remember the VTC is not something the tech can open hood and check it easily , the procedure is to take apart valve train and with compressed air applied to various ports see that VTC is in right position . If your not having any noise I can see why there not going to do anything, even when is only few sec noise it is still going to be hard % wise to prove .
Ed
gone 1985 XR4Ti
Old 04-13-2011, 07:02 AM
Aviography's Avatar
Of course you are not going to get any kind of receptive response when you "shove the tesb in their face".............
TSB shows how to fix a problem when it breaks, recall is a totally different scenario.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 10-26-2012, 05:03 PM
BSTE BSTE is offline
VTC Recall or TSB
Having the same VTC issue on my 08 Accord "Cold Starts", it started once a month to once in a while at about 58,000 miles and now at 69,000 it drives me nuts at almost every cold start.
Old 10-26-2012, 05:50 PM
CitizenR CitizenR is offline
2nd Gear
I think Honda should do a recall. I'm on my third actuator and still have issues on cold starts. Drives. Me. Nuts.
It seems to me Honda is risking losing a lot of good will with the potential for catastrophic engine failure. I'm sure their decision would be driven by economics - how much does it cost to recall vs. how much does it cost to deal with individual issues as they arise.
Last edited by CitizenR; 10-26-2012 at 06:39 PM. Reason: error - third, not second
Old 10-26-2012, 05:55 PM
danny_379's Avatar
danny_379 danny_379 is offline
3rd Gear
What does TSB stand for?
Old 10-26-2012, 07:36 PM
mi08coupe mi08coupe is offline
5th Gear
Technical Service Bulletin
2008 Accord Coupe EX-L I4 NON_NAVI
R94 San Marino Red
Old 10-27-2012, 05:39 AM
Mechanic Mechanic is offline
5th Gear
Originally Posted by CitizenR View Post
I think Honda should do a recall. I'm on my third actuator and still have issues on cold starts. Drives. Me. Nuts. . . .
If you're on your third VTC, the problem isn't the VTC, it's the tech doing the work.
Also, jfi, the term "recall" is a term of art. A "recall" is an obligation imposed on the manufacturer of the vehicle by the NHTSA to notify the vehicle owner of a safety-related defect. The replacement of a VTC isn't that, although I understand your frustration dealing with the circumstances you described. FWIW, there weren't that many VTC failures, particularly after mid-'09. More importantly, if the work is done correctly, it's a one-time fix.
