Please post how to install amp !!! - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > The Honda Accord Lab > Audio & Electronics
Old 05-04-2011, 02:15 PM
danis1999 danis1999 is offline
8th gear
Please someone who knows how to install amplifier with component speakers and RCA converter from very beginning. i was looking all over the place here. All i need is step by step. im not audio guru and really need to understand how to do so . i've been help once to install amplifier with rca converter in my mazda 6 but now i have honda accord 2011 coupe lx-s no nav. no climate control. and i have polk 6.5 component speakers with crossovers and twitters. and i really need help with this. real problem begins with rca and crossovers.
in polks manual says connect all wires to crossover and then from crossover to amp. i just cant figure out this. plus front speaker harness have 4 wires. why does it have 4 wires?
i dont want to install in the audio shop ,no way. want to learn and do it my self ,thats the whole point of having car. its yours you want to do it your way.
thank you guys.
Old 05-04-2011, 06:37 PM
xJoeMama78's Avatar
xJoeMama78 xJoeMama78 is offline
Out of Control
Send a message via AIM to xJoeMama78 Send a message via MSN to xJoeMama78 Send a message via Yahoo to xJoeMama78
  1. Front speaker wires from back of head unit to LOC (RCA convertor you called it).
  2. RCA cables (1 pair) from LOC to amp.
  3. Speaker wires (2 per side) from amp to crossover that came with the new speakers.
  4. Speaker wires (4 per side) from crossover to speakers. Two wires will go to each woofer and two to each tweeter. The crossover should have markings to tell you which outputs are for the tweeter and which is for the woofer.
  5. Power cable from battery to inline fuse to amp. Closer to the battery the fuse is the better. Find an existing grommet to run it through or drill a new hole through the firewall. If you drill a new hole be sure to use a grommet to protect the wire.
  6. Ground from amp to wherever you want to ground it. Keep the wire as short as possible and grind the paint off so it is grounded to bare metal.
  7. Amp turn on. Find a wire that is only hot when the car is turned on and tap into that.
2008 Accord Coupe EX-L L4 Auto ASM
Clear bra | Tint | T-rex | Injen | Weapon R | Eibach | Enkei | Goodyear | SPC | H9/HIR | Hoen | LEDs | Clarion | JL | Focal | Python
1997 F-250 Crew Cab Diesel 4x4
Tymar | Diamond Eye | Bilstein | Clarion | Fosgate | JL
Old 05-04-2011, 07:41 PM
8th gear
thanks a lot to you,but i still have a questions.
how do i get sound if i use wires from head unit to LOC? damn, i wish someone do a whole write up with pics about this, so no more new topics about amp could be. i will do it if i clear all my questions
Old 05-04-2011, 08:21 PM
xJoeMama78's Avatar
Out of Control
The LOC should have what looks like speaker wires and two female RCA outputs. You connect the speaker wires on the LOC to the speaker wires coming out of the head unit. You then connect a set of RCA cables from the LOC to the input on the amp. Then you run speaker wire from the output of the amp to the new crossovers.
Basically the radio will output the signal to the LOC which will send it to the amp, then to the crossovers, and finally the speakers.
I don't know what the color code is for the wiring harness on your car. If you search around the audio threads you might find it.
Old 05-04-2011, 11:01 PM
johnnydinh701's Avatar
johnnydinh701 johnnydinh701 is offline
Dats da way to do...
Send a message via AIM to johnnydinh701
would adding an amp to the speakers make the speakers sound better and be able to hear more of the lows from them? or would it be better to just add a sub?
Title goes here
close
video goes here
