Transmission flush question - Drive Accord Honda Forums
Old 05-16-2011, 05:11 PM
ateebtk ateebtk is offline
Hi,
I bought my 2000 Accord LX (4cyl ; vtech) @ 126k miles from private seller who got all oil changes + service done at her local dealership. I have put in timing belt, water body, necessary belts, had throttle body cleaned and put in new engine air filter.
I know the only major weakness of this model is the transmission and I want to do everything to increase its longevity.
QUESTION > When to do transmission fluid flush and new fluid replacement?
QUESTION > Is it ok to flush with cheapest transmission fluid and top off with Honda Recommended fluid ?
QUESTION > What rpms + mph does your transmission shift in the 4 gears (for 4 speed auto)?
Thanking in advance,
ATK
Old 05-16-2011, 05:37 PM
G Stone's Avatar
G Stone G Stone is offline
Greg
Answer: Never do a transmission flush. The flush can clog the internal transmission filter and cause irreparable harm on the transmission. Tranny fluid should be changed approx every 15K with Honda Z-1 or equivalent.
2012 Hyundai Sonata SE Turbo
1999 Honda Accord EX Coupe - SOLD
3.0L V6
166,800 miles
35% Tint
Old 05-16-2011, 07:16 PM
txn txn is offline
3rd Gear
See answer below.
Originally Posted by ateebtk View Post
Hi,
ANSWER: If you are not sure when the ATF was changed by the previous owner, then you want to drain & refill 3 times (with some driving between each D & R).
Otherwise, you drain and refill 1 time every 15 K miles.
ANSWER: You could but, I wouldn't.
How much does it cost per drain/refill with cheap fluid ?
Honda DW-1 is $5.75/qt and you need 3 qts per drain and refill.
Is the saving worth the risk of something go wrong later ?
ATK
1999 Accord LX 4-dr, I-4
Old 05-17-2011, 05:03 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
Hi,
ATK
If you dont know the dealers history of changing the ATF, change it ASAP. Drain and refill with 3 quarts of new ATF is the easiest way to maintain these transmissions. Repeat 2 or 3 times for a more complete replacement. You can safely do a cooling line flush on these 4 cyl cars. Do a search here or on you-tube for that procedure. Do not do any flushes that involve adding chemicals or externinally pressurizing the transmission.
I have heard of this being done, but I would just stick with Honda ATF or something better. I use Valvoline Maxlife. Lots of info here on alternate ATF if you search.
The rpms and mph shift points all depend on the amount of throttle applied.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 05-17-2011, 10:28 AM
appreciate the responses so far but should it flush transmission asap even if the fluid on dip stick is rosy/ slight pink and doesn't smell burnt?
Old 05-17-2011, 10:38 AM
txn txn is offline
3rd Gear
As nehonda wrote:
"If you dont know the dealers history of changing the ATF, change it ASAP".
If you think your ATF is still new then do a color comparison.
Put a drop of old ATF on a piece of paper towel then put a drop of new ATF next to it.
If the 2 drops are close enough in color, then maybe you can wait till next oil change.
Old 05-17-2011, 10:40 AM
TCHondatoy's Avatar
TCHondatoy TCHondatoy is offline
3rd Gear
I have always been advised never to a transmission flush! Due to the high pressure and stirring up metal debris that has settled over time at the bottom of your transmission. You could always due a drain and fill which doesn't replace 100% of the fluid but about 1/3.
Old 05-18-2011, 11:27 AM
TUBHMOOBVAJ's Avatar
TUBHMOOBVAJ TUBHMOOBVAJ is offline
3rd Gear
Drain the tranmission, fill it, drive it for a day, drain it again and fill it again.
1999 Honda Accord LX 4-Cyl
15' OEM 2002 SE rims
Yokohoma all season tires
AEM SRI
Apexi WS2 catback exhaust
Red and clear tail lights
Chrome Headlights without amber
DDM Tuning 55W 6000K low bean
Nokya Hyper Yellow 2500K high bean
01-03 Honda Civic foglights w/DIY OEM Fog switch
Title goes here
close
video goes here
