TL and TL-S front/rear sway bars upgrade info
Part numbers:
(all bolts holding the original brackets and end-links to the frame can be re-used) Front Sway (27.2mm): TL Base Model (hollow) 51300-SEP-A01 - SPRING, FR. STABILIZER - 1x 51306-SEP-A01 - BUSH, FR. STABILIZER HOLDER - 2x 51308-SDA-A00 - BRACKET, FR. STABILIZER - 2x Front Sway (27.2mm): TL Type-S 6MT (solid) 51300-SEP-A21 - SPRING, FR. STABILIZER - 1x 51306-SEP-A01 - BUSH, FR. STABILIZER HOLDER - 2x 51308-SDA-A00 - BRACKET, FR. STABILIZER - 2x Rear Sway (20mm): TL Type-S 6MT (use this if you ARE upgrading the front sway bar) 52300-SEP-A11 - SPRING, RR. STABILIZER - 1x 52308-S3M-A00 - HOLDER - 2x 52306-SEP-A11 - BUSH, RR. STABILIZER HOLDER - 2x Rear Sway (17mm) TL Base model (use this if you DO NOT plan to upgrade the front sway bar) 52300-SEP-A03, 17mm Bar -1x (p/n for 2005 base TL) 52306-SEP-A02, Bushing -2x 52308-S3M-A00, Holder -2x If you are so inclined to upgrade to the heavier duty and newer end-link: See http://ww2.justanswer.com/uploads/jo...27_swaybar.pdf TSB for details Rear stablizer link kit (includes both links and new self-locking nuts) P/N 06523-S84-A00, H/C 8019309 Individual parts contained in the kit 1 of 52320-SDA-A01 1 of 52325-SDA-A01 2 of 90002-S10-000(upper bolts) 2 of 90212-SA5-003(lower bolts) My personal opinion: The TL Type-S front and rear sway bar combination gave me back the ideal handling characeterstics I was looking for. Discussion threads and other instructions: http://www.driveaccord.net/forums/sh...ht=tl+sway+bar (User opinions) http://import.neuspeed.com/media/att...15.20.27.2.pdf (Neuspeed installation instruction) http://www.driveaccord.net/forums/sh...highlight=sway (installation of RSB on an I-4 sedan) http://www.cardomain.com/ride/281873...edan-4d/page-2 (step-by-step with images on RSB install on an I-4 sedan)
2005 Satin Silver V6 Coupe 6 speed, Venture Shield clear protetive film, TL shift knob, Hidden Hitch, GM Friction Modified Synchromesh transmission fluid 2007 Acura TL-S front/rear sway bars, Clutch slave cylinder restrictor valve delete. Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960 Honda steel rims 225/55-16 Michelin Alpin PA2 __________________ DA Moderator Team DriveAccord.Net Forum Rules & Regs DriveAccord.net Classified Rules |
| Sponsored Links | ||
Advertisement | ||
Good Stuff Av!
oh wow i was just looking into this literally today. haha thanks!
2007 Honda "Nikita" Accord I-4 LX Sedan Graphite Pearl -Blackhoused MH1 Retrofit projectors with DDM 4500k HIDs -Soundgate aux integration -Diode Dynamics stage 2 kit (license plate, front door lights) -Aftermarket Inspire Fogs with 4300k HIDs -TL Type S rims! -OEM Decklid Spoiler -Nokya Hyper Yellow DRL -JL Audio TR690 rear speakers -Polk DB 6501 front speakers -K&N Short Ram Intake -Acura TL RSB Cardomain |
i have the acura tl type s front and rear sway bars, its a very good combo! my car handles beautifully with a hint of understeer so in the case of a slide, the rear end will not slide out
2007 Acura TL Type-S |
whats this exhaust hanger everyones talking about? got a pic?
Is it true that there is a difference between the Solid and Hollow front sway bar? Meaning one of them has to be modded to fit? Or do they both just swap in with a PITA install? I heard somethin in the other thread about having to drill out the hole on the control arm or somethin like that.
Awesome, thanks Av. Hopefully I'll get both on some point this summer. Might just take it somewhere to get the front put on, one of my control arm bushings is shot anyway, so prolly have em do it while they got it.
The Pope Things that we go thru that don't kill us, makes us stronger. What we learned from these events are now tools in which we can use to help others. My youngest son, RIP 10/3/2004 (He was 19 at the time) My mom, RIP 4/6/2011 Forum Rules: http://www.driveaccord.net/forums/sh...ad.php?t=19181 |
any advantages of the newer endlinks? i didnt know there was an issue with endlinks breaking...
Gracias! This is now a complete resource! Glad to see my request to clean this up got heard.
As for my review, it's sort of assumptive at this point. I've got the 20mm rear, and the 27.2 solid with the TL-S endlinks - but everything else suspension wise is stock. With my center of gravity still similar to a Ford F250, I'm still not confident enough in the car to take the turns very aggressively yet. However, this combination is a significant increase in sway reduction over stock IMO. The rear does feel like it wants to get out a little bit if I corner too fast, but overall, a great improvement. As for the endlink concern. I broke my stock one's on the first test drive. The TL-S endlinks are far 'beefier'. I'll post pictures later. |
I feel like a complete idiot, after cross checking the part numbers with my already received Park Acura invoice part numbers, I noticed that I ordered the 51300-SEP-A31 front sway bars (07-08 TL base) instead of the the 51300-SEP-A01, during my research I remember on V6P there was a major debate going on at the time saying that the hollow one did not require the drilling, while a solid one did, so that is the reason why i went with the A31... Now I wonder if i actually sway bar would actually fit...
2007 Accord SE Alabaster Silver Metallic Sedan HIDs 6k, Tint F:23% R:17%, Complete LED Interior + License, OEM All-weather Mats, TL 20 RSB/27.2 FSB, USA-spec PA15-HON2, Decklid Spoiler, K&N drop in Air Filter, OEM window Visors, WeatherTech Bug Deflector, Modded front license plate, Inspire Fog Lights Reps (3k), Hybrid Tail Lights (Reps), Sypder Projector Headlights |
Do you mean A21? Like AV said, both bars are the same, one is just hollow but both should bolt up no problem (well PITA install but still the same). I got my front bar and its the A21, but I need a control arm bushing replaced, so I'm just gonna take the car in somewhere and have them put the FSB while its up.
![]() The rear should be coming tomorrow, prolly put that on Thursday night, we'll see. |
I mean, I bought A31 when I wanted A21, the only difference between the A31 and A21, is the year model. A31 is for 07-08 while A21 is 04-06. I should not have a problem with the install other than it being a PITA right? Im not that much of a handy man, which is why I purchased parts that should bolt up without any modifications such as drilling.
And you will not be disappointed with the rear sways Accordguy, it makes the car THAT much more fun to drive =]
Yeah I heard the whole package turns our cars into Trains on Rails
| Sponsored Links | |
Advertisement | |
