TL and TL-S front/rear sway bars upgrade info - Page 5 - Drive Accord Honda Forums
  #61
Old 10-14-2011, 11:15 AM
thisaznboi88's Avatar
thisaznboi88 thisaznboi88 is offline
Out of Control
make a DIY. this is on my list to do for the front.
GONE AND BUSY in PHARM SCHOOL!
  #62
Old 10-20-2011, 05:37 PM
kazhuveri kazhuveri is offline
Accord fan
Did the 17mm sway bar upgrade on my 2006 VP last weekend. Had to get the Acura equivalent of the following parts, since the VP doesn't have a sway bar at all. It did improve the ride a lot.
52300-SDC-A01 SPRING, RR. STABILIZER 1
52306-SDA-A01 BUSH, RR. STABILIZER HOLDER 2
52308-SZ5-000 HOLDER, STABILIZER BUSH 2
52320-SDA-A01 LINK, R. RR. STABILIZER 1
52325-SDA-A01 LINK, L. RR. STABILIZER 1
90002-S10-000 NUT, FLANGE (10MM) 2
90212-SA5-003 NUT, SELF-LOCK (10MM) 2
93402-08016-08 BOLT-WASHER (8X16) 4
2006 Honda Accord VP (I4) AT Original Owner
  • Alabaster Silver
  • Bridgestone Turanza Serenity tires at 32k miles
  • Honda battery at 48k miles
  • Honda battery at 63k miles
  • Transmission Fluid 1x D&R at 53K miles
  • Honda Front Pads and Brake Fluid D&R at 58K miles
  • Transmission Fluid 4x D&R at 63K miles
  • 17mm RSB at 64K miles
  • Transmission Fluid 1x D&R at 80K miles
  • Bridgestone Turanza Serenity Plus tires at 80k miles
  • ~25 mpg 50% city 50% highway
  #63
Old 10-20-2011, 07:42 PM
XLDeluxe's Avatar
XLDeluxe XLDeluxe is offline
4th Gear
Congrats man! great stuff for sure.
By the way, I crawled under my accord the other day to check the front sway bar and how its positioned, I dont think theres any way I can squeze any type of wrench in there to unscrew the bolts that hold the bushing holder
  #64
Old 10-21-2011, 03:13 AM
Ilovemyvtx's Avatar
Ilovemyvtx Ilovemyvtx is offline
4th Gear
^I did it on a lift and it was still a huge pain. Totally worth it though.
Her name is Nikki and she runs like a banshee: 07 4dr Ex-L V6 6mt - Bronze
Gm Syncromesh Fm, TL-S sway bars, Ingalls torque damper, Stage 1 exhaust mod, Intake resonator delete, short shifter, RV-6 V3 j-pipe, RV-6 V3 PCD's, P&P intake runners, semi-ported/polished intake plenum with custom throttle body spacer, TL-S trans mount, 06 TL 5 spoke rims
  #65
Old 10-21-2011, 05:26 AM
XLDeluxe's Avatar
4th Gear
how did u get a wrench to fit, I understand that a flex connector was used but its so tight my fingers hae trouble fitting in there
  #66
Old 10-21-2011, 07:36 AM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
You probably should read the Neuspeed installation pdf that's listed in the 1st post of this thread.
2006 Accord Coupe silver 6 speed
  #67
Old 11-03-2011, 03:16 PM
SteeleAccord SteeleAccord is offline
i just ordered my type-s sway set up. looks like a great bang for the buck mod. i'm still undecided on oem honda endlinks referenced in the stick or the moog's for 1/2 of the price...
thoughts?
  #68
Old 11-03-2011, 03:24 PM
Out of Control
the car has a lot of oversteer now with the tl-s rear. I used to have the base TL before this. But I know how to control it so its fine.
  #69
Old 11-03-2011, 03:58 PM
Artema's Avatar
Artema Artema is offline
Michael
That's why if you do the rear you should do the front.
  #70
Old 11-03-2011, 04:20 PM
Out of Control
chill. The front is on its way. lol
  #71
Old 11-03-2011, 04:26 PM
Artema's Avatar
Michael
woot!
  #72
Old 11-03-2011, 04:35 PM
Out of Control
I did the hollow front to save weight and give it a more neutral feel.
  #73
Old 11-04-2011, 06:01 AM
Evolved1 Evolved1 is offline
3rd Gear
Installing this today!
  #74
Old 11-14-2011, 05:19 PM
installed...
initial impressions are exactly as hoped. i put in the type-s all around & new moog end links in the rear (left stock up front). i'm glad i bought the new end links, the rear bar & links look like they came off of a go-cart! no wonder why they've had some issues with broken ones.
the body roll is greatly reduced. i've only been able to drive about 30 miles so it's definitely still the initial impression, but i live near a very large rotary & did a few laps around it!
if anyone is still on the fence about this, then get off and get them. the bars cost $130, the links were another $50. for under $200 the car is much less of a mush-mobile.
  #75
Old 12-09-2011, 09:17 AM
Titleist Titleist is offline
2nd Gear
Originally Posted by Aviography View Post
Rear Sway (20mm): TL-S 6MT (use this if you ARE upgrading the front sway bar)
Rear Sway (17mm) TL Base model (use this if you DO NOT plan to upgrade the front sway bar)
Quick question about this. I do not plan on doing a front sway bar, but is that 3mm difference going to get the rear end out? I've been meaning to do this for years, but now that this is my daily driver, I'm going to.
