What Type of Capacitor for 08 Accord Coupe - Drive Accord Honda Forums
Old 06-07-2011, 05:24 PM
HondaGuido08c's Avatar
HondaGuido08c HondaGuido08c is offline
Honda Guido 0809
Send a message via AIM to HondaGuido08c
Well, Looks like My HID (right side passenger) is starting to flicker. I tried everything but this. I just don't know what type of Capacitor to get for such a new car, can I get some advice? I already ordered new bulbs, and I have 2 ballasts in my garage that I am going to swap out. all 35Ws. But, I just want to try a capacitor in case this happens with everything I rewire.
Thanks,
Chris
Oh, v6 Coupe 3.5
- HondaGuido08c -
* 20% Tints All Around
* 35% Tinted Taillights
* 8K HID Kit
* JDM Stage 2 Yellow Fogs
* JDM Stage 2 High Beams
* Customized Red Calipers
* K&N Typhoon 69 Series SRI (Intake)
* Upgraded Trunk & License Plate Lights
* Interior Blue Lighting + Underlighting
Future Mods:
19" or 20" Black Rims
Falken Tires
Future Car in Progress:
Nothing Catching My Eye
Member of NYC ALIVE
Old 06-07-2011, 05:36 PM
Markus's Avatar
Markus Markus is offline
Corvalis TTX
You don't need a capacitor for the 8th gen. And I doubt that a capacitor will help with your flickering.
Mark
08 Accord EX-L V6 sedan (non navi)
2012 Infiniti G37X | 2012 Porsche 911 Turbo S | 97 Jaguar XJ6 | 95 Ford Taurus SHO | 77 MGB | 2012 Cessna 400 Corvalis TTX
Old 06-07-2011, 06:14 PM
Honda Guido 0809
Hmm I was reading up on it, and a lot of people are saying that it helps. But, I am going to try my new lights when they come, if not I'll switch the Ballasts too.
Thanks
- HondaGuido08c -
* 8K HID Kit
Future Mods:
Falken Tires
Member of NYC ALIVE
Old 06-07-2011, 06:25 PM
gunmetal's Avatar
gunmetal gunmetal is offline
niiice!
ill get back to you on this thread... of PM me..
2010 Accord Coupe EX I4 Auto PMM
Old 06-07-2011, 07:14 PM
Aviography's Avatar
Everything else being equal, i.e. no bad connections, no sub-standard or defective ballasts or HID capsules, and using 35 watts kit, there is absolutely no need or benefit to use a capacitor, HID is not like your audio system needing large instantenous power to drive the subs, it's a steady current draw, the capacitor won't fix the real problem you have if your light is flickering during operation.
Using a capacitor in an attempt to fix the flickering completely meaningless and useless.
My bet is that your ballast is likely at fault.
TL shift knob, Hidden Hitch,
Acura TL 5-spoke rims 235/45-17 Bridgestone Pole Position RE960
DA Moderator Team
Old 06-07-2011, 07:27 PM
Honda Guido 0809
Thanks, I'll check it out. Like I said, I am changing everything out when my new bulbs come
- HondaGuido08c -
* 8K HID Kit
Future Mods:
Falken Tires
Member of NYC ALIVE
