Getting strange noise when turning hard right, possibilities? - Drive Accord Honda Forums
Old 06-16-2011, 01:49 PM
ebigg2000's Avatar
ebigg2000 ebigg2000 is offline
2nd Gear
This sound is sort like a grinding or shuttering and only happens on a really hard right. If I'm taking a easy right hand turn around a corner I don't hear it, but if I'm in a parking lot and have to turn the car sharply to get in spot or after backing out and turning myself straight I hear it. Any clues what this could be?
2006 Honda Accord Sedan VP 2.4L Auto
Mods:
Custom bent 2 1/2" High Performance Catback Exhaust with Cherry Bomb Turbo Muffler, Weapon R Dragon cold air intake with optional ram air charge and heat shield, Chrome Trim around wheel wells, Ugraded Tire Width to 215/60/15 from stock 195/65/15, Rear Wing, Racing stripes, Hood scoop, Pin strips, Honda Windows Logo, AM Rims, Rear Speakers
Planned Mods
Window Tint, New Wheels, TSX Intake Manifold, Coilovers, TSX headers, Body Kit.
Old 06-16-2011, 05:18 PM
miagi99's Avatar
miagi99 miagi99 is offline
I've had similar issue but mine was at higher speeds and it was drive axle but in your case I'd check if your wheel bearings are bad. You can jack it up and press, pull, and lift ont he wheel. It should not budge at all if there is play then you know it is wheel bearing. good luck.
2005 Accord EX V6
Old 06-16-2011, 06:10 PM
Aviography's Avatar
Aviography Aviography is online now
I would suspect the CV joint, have someone look to see if the CV joint boot is torn and allowing lubricating grease to be flung out, this leaves little grease inside the boots and will quickly cause wear and damage to the CV joints.
TL shift knob, Hidden Hitch,
DA Moderator Team
Old 06-17-2011, 11:43 AM
bl_twisted_stl's Avatar
bl_twisted_stl bl_twisted_stl is offline
2nd Gear
Originally Posted by aviography View Post
i would suspect the cv joint, have someone look to see if the cv joint boot is torn and allowing lubricating grease to be flung out, this leaves little grease inside the boots and will quickly cause wear and damage to the cv joints.
+ 1
2006 Accord EX-L Sedan V6MT : Mud guards, 20mm TL rear sway bar, trunk tray, Akebono pads + Brembo rotors
2006 Pilot EX-L : Roof rack, hitch, side steps, bug deflector, mud guards, fender flare kit, bull bar, driving lights, cargo tray, Akebono pads + Brembo rotors, transmission cooler
2006 CRF250R
1985 TRX125
1987 Mustang GT
Old 06-17-2011, 11:48 AM
Dreamacre's Avatar
Dreamacre Dreamacre is offline
7th Gear
Originally Posted by bl_twisted_stl View Post
+ 1
+2
- It is just a car -
2015 CR-V, EXL, AWD
2005 Accord Sedan EX-L AT
(Just traded - 2009 Accord Coupe 6/6 Black)
Old 06-17-2011, 12:00 PM
ebigg2000's Avatar
2nd Gear
Thanks, I"ll get someone to look under there for me. Any idea about estimated cost for this type of repair? What a bummer I just saved up for my Fujita CAI and placed the order for it before my wife told me about the sound. Looks like I might have to send it back if it is an expensive repair.
Mods:
Planned Mods
Old 06-17-2011, 12:27 PM
Edaccord08 Edaccord08 is offline
Out of Control
Best bet is to jack up front and check all suspension points along with CV joint/boots . use pry bar to check ball joints, tie rod ends, wheel bearings , swaybar links etc looking for play an noise when flexed .
could be any of these including CV but generally CV makes a clicking noise most times ,unless its real bad .
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 06-17-2011, 12:42 PM
Dreamacre's Avatar
7th Gear
Mostly now, they sell the whole shaft including the CV joint and boot and it is usually cheaper to do it this way. Should be @ $120 for the shaft + labor. Call around and price them out.
2015 CR-V, EXL, AWD
Old 06-17-2011, 01:45 PM
2nd Gear
just a reference when I looked up my Accord, from auto parts warehouse dot com
Replacement Axle Assembly
* List Price: $94.41
* You Save: $47.85
* Our Price: $46.56
* Low price guarantee
* In Stock
CV AXLE ASSEMBLY, NEW -- Includes axle nut, joints, and boots; Manufactured from 100 percent new components to ensure proper fit and operation; Provides maximum safety and stability, restores vehicle's handling and control, and improves passenger comfort over the toughest and roughest driving conditions; Backed by 1-year, unlimited-mileage warranty.
* Condition: New
* Quantity Sold: Sold individually
* Product Fit: OE replacement
* Warranty: 1-year, unlimited-mileage warranty
2006 CRF250R
1985 TRX125
1987 Mustang GT
Old 06-18-2011, 07:14 AM
ebigg2000's Avatar
2nd Gear
Whew....what a relief, I thought it would be way more than that. I think I can keep my CAI now when it gets here. Thanks guys
Mods:
Planned Mods
Old 06-18-2011, 12:50 PM
ntextreme3's Avatar
ntextreme3 ntextreme3 is offline
04 Accord V6 6spd
assuming it is in face one of the driveshafts, its not a hard thing to change.. not at all.. most likely theres a procedure for on here for it.. Biggest issue would be something not wanting to come off lol (whether it be rust or whatever)
2004 Accord Coupe EX V6 6spd
San Marino Red
Continental ExtremeContact DWS
TL-S 20mm RSB/27.2mm FSB
K&N Typhoon Intake
Paul's Intake Manifold Spacer
ATLP V1 J-Pipe/RV6 Race Pipe
XLR8 Mounts (62a)
XLR8 Pulley (not installed)
Blitzsafe Hon Aux DMX v.2
Hand-Stitched (Red) Shift Boot
OEM Style Wing
Lighting:
Retro & LED Fog Strip
Full LED Interior + Footwells, Door Side Pockets, Reverse
Pic of most of the LEDs
Reverse LEDs
Custom-lit Coin Tray
My Coin Tray DIY
-CARDOMAIN-
Old 06-18-2011, 09:50 PM
NHAccord's Avatar
NHAccord NHAccord is offline
603
agreed, still, you probably can tackle this yourself w/ jack stands if your mechanically inclined. Ive done a handful on various hondas and others. But yeah, any sort of under body work can quickly become a nightmare w/ broken or stripped hardware. If your car is clean underneath id go for it. assuming its torn
2005 Accord LX PZEV
- liquid smoke powdercoated rims
- Alpine 6x9s
- OEM mudflaps
Old 06-21-2011, 02:36 PM
ebigg2000's Avatar
2nd Gear
Whew! Thank goodness it wasn't anything bad. Haha it turned out when my buddy helped me remove my front bumper to do a resonator delete he forgot to put back some of the clips by the right wheel well and it was flopping around a bit and rubbing the wheel on tight turns. Everything is squareed away now. No I just have to wait on getting my cold air intake put in. I've given up on the Fujita, the place I ordered it from didn't have it stock and I had to wait three days before they told me, and I called three other places today they were all out also so I ended up ordering a Weapon R based on based on a cold air intake shootout I read in DSport magazine. The Weapon R was a close 2nd to the Fujita
Mods:
Planned Mods
Title goes here
close
video goes here
