Big 3
I wanna do the big 3 upgrade. I know where im gonna put the neg (-) terminal of the battery to the chasis. Where are the other 2 locations at because the wires for the pos (+) terminal of the battery go somewhere i cant even see
2008 Accord EX i4
Basque Red Pearl Lots Of Mods ;) |
| Sponsored Links | ||
Advertisement | ||
1) Positive battery terminal to Alternator
2) Ground to chassis 3) ground to engine block
2009 honda accord coupe ex-l v6 MODS: To many to list. |
Where are the stock locations of the other 2 wires
2008 Accord EX i4
Sent you a PM of a link to another forum site. Not sure if DA would like it posted here
2011 San Marino Red V6 EX-L Coupe 5AT HFP Suspension 50/35/35 Llumar High Performance |
what's the big 3 upgrade?
2009 4dr Honda Accord i4 EX-L PMM ------------------------------- Mods: Performance Takeda SRI P2R - TBS Weapon-R - iThrottle Controller Exterior OEM Splash Guards 20% Tint all around m3 roof lip spoiler 6000k HID lows/fogs Stephen83's JDM Inspire Decklid Spoiler Debadged Audio JL w3v3 12" Sub JL 250/1 v2 Slasher Amp Scosche Dash Kit AVH-P4100DVD Stereo Interior White LED Interior Maps, Dome, etc... Illuminated floor lights Weathertech Floor/Trunk liner |
It lessens strain on your alternator
Lessens huge voltage drops Helps with dimming of the lighting of the car It should be used before you upgrade a bettery or high output alternator cause it could actually solve problems with the symptoms listed above. And is a fairly cheap thing to do. @sandman69 Thanks, but I'm trying to find the loations where the wire is bolted to the alternator so I can add a 0/1 gauge cable at that exact spot AND where the cable is located that's attached to the engine block that'll go to the chasis. I have an i4 so the layout can be similar to the v6 but some things are differet like egine and battery size so some wires could be placed differently maybe?
2008 Accord EX i4
Where to ground the cables shouldn't matter too much as long as it is a solid ground. The second one he screwed onto the shock tower area, and the third he mounted near the transmission. Just sand the area to make sure it is metal Here is another DIY I found, which is an i4 I believe. http://www.diymyhonda.com/accord/big...rical-grounds/
I understand where they go but he doesn't show where the wire from the pos (+) of the battery ends up going a the alternator. Maybe I didn't look good enough but the picture shows only the engine and the wire attached to it. It doesn't show where the termina is actuall connected to the alternator.
2008 Accord EX i4
I believe he says he uses the same terminal the oem wire goes to.
Here is a youtube DIY on a 2001, which should still work. Basically it is (I think) : - Battery positive to alternator positive - Battery negative to chassis - Alternator negative to chassis
2008 Accord EX i4
Look at my pics and see for yourself. I posted a grounding issue thread a while back about it. I dont see any issues with the positive battery cable unless you are using a much larger battery and upgrading sound and or lights. Then again the best electrical upgrade is making better ground return back to battery and alternator case.
2009 EX-L Coupe - V6 VCM - PMM 0w-20 cap 3.7L TL-SHAWD IM - Functional 65w H9 Lo & Fog / 80w HB3 Hi Cargo hooks & net Crosstour knob Duralast Gold 24F-DLG I4 hood rod MDX spacer & Runners - Ported Moded OEM CAI Mobil 1 0w-20 & M1-110 NAPA #18514 Odyssey garnish - Flush fitted Painted splash guards PXAMG & HDRT Rear: Belt, head rests & ANC delete Service Grade Electricals Test Pipe Window UP mod Valvoline Type VI Next: Acura TL-SHAWD Heads HFP suspension |
I added an 8 gauge ground to the block/engine mount and alternator yesterday on my 7th gen and it took care of an idle drop issue I was having. So maybe you don't need massive wires to actually do some good on a stock car.
Her name is Nikki and she runs like a banshee: 07 4dr Ex-L V6 6mt - Bronze Gm Syncromesh Fm, TL-S sway bars, Ingalls torque damper, Stage 1 exhaust mod, Intake resonator delete, short shifter, RV-6 V3 j-pipe, RV-6 V3 PCD's, P&P intake runners, semi-ported/polished intake plenum with custom throttle body spacer, TL-S trans mount, 06 TL 5 spoke rims |
just get a Buddy Club Grounding Kit. I love mines and looks cool!
08 Alabaster Silver EX-L V6 AT / Custom 3" CBE with HKS Ti Carbon Muffler / RPF1's 18x9 +35 / Nitto NTO5 / Spec Condensor / BC Racing Coilovers / SPC Rear Camber Kit / SPC Rear Toe Kit / SPC Rear Trailing Arm Kit / Injen CAI / RV6 PCD / RV6 V2 J-pipe / RV6 Test pipe |
What does it do, that upgrading the cables wouldn't do? That is pretty steap
It smoothed out everything, electronics runs smoother, and doesn't have a shit ton of wires.
| Sponsored Links | |
Advertisement | |
