Low Idle RPMs and Stalling - Drive Accord Honda Forums
Old 08-24-2011, 08:16 PM
NevinL1's Avatar
NevinL1 NevinL1 is offline
1999 Accord
I would like to start off this thread by saying that today I had the oil and transmission fluid changed. Now, the problems that I have been experiencing for the past month(s) or so is that the transmission seems to have been slipping/not catching and the RPMs while idling seem to be too low. Another guess is that gas may not be getting though the gas line quickly enough when starting the car cold.
Here is what happens: Every night, after getting out of work, at around 10pm, when the temp ranges from the mid 50s to lower 70s, I start the car, turn the ac, headlights, and radio on, then shift into reverse. I turn the steering wheel all the way to the right to back out of my spot. By this point the RPMs are dangerously low and the car sounds as if it is about to stall. I let up off the brake pedal and back up slowly, giving it no gas, I slowly back up while the car seems like it will stall, vibrates, and makes a grinding noise. I hit the gas but nothing responds until after a few seconds. Then, something catches and I shoot backwards from the pressing of the gas. Same thing then happens after shifting into drive to take off. The same also happens when driving straight out of the driveway in the morning. Tonight, the car actually did stall while I was backing up.
As a related issue, my RPMs have always seemed a bit low while sitting there idling.
Please, does anyone have any ideas as to what this could be? This problem bothers and worries me.
Old 08-27-2011, 07:41 AM
cpberry1 cpberry1 is offline
starting point...
Search EGR port cleaning - an easy starting point that might just fix your problem.
Good luck!
Old 08-27-2011, 06:33 PM
96accordcoupe's Avatar
96accordcoupe 96accordcoupe is offline
02-SE
I would start by cleaning your throttle body and IACV. Start with that before anything and report back.
2002 Honda Accord SE Coupe 2.3 I-4 VTEC (DD)
Taffeta White 134,xxx Miles
1992 Lexus SC400 83,xxx miles *My Toy*
Past Car:
1996 Honda accord coupe LX! 106,xxx miles
*Totaled as of 3-31-10 Dumb People!*
http://www.driveaccord.net/forums/sh...ad.php?t=45234[/SIZE]
Old 08-28-2011, 06:39 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
+1
The EGR should not effect the idle when the car is first started, so I doubt that is your problem.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Title goes here
close
video goes here
