MM Code 3 at 63,000 miles!!!
The maintenance minder on my Accord threw a code 3 at ~63,000 miles. Code 3 means that I have to change the transmission fluid.
The owner's manual states: Driving in mountainous areas at very low vehicle speeds or trailer towing results in higher transmission and transfer temperatures. This requires transmission and transfer fluid changes more frequently than recommended by the Maintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission and transfer fluid changed at 60,000 miles (100,000 km), then every 30,000 miles (48,000 km) (For A/T only ![]() I have never pulled a trailer, or driven in mountainous areas. Is there anything wrong with my transmission? Why is it throwing this code so early?
2006 Honda Accord VP (I4) AT Original Owner
| Sponsored Links | ||
Advertisement | ||
Nothing wrong with your transmission. Just change it out if it's telling you to do so. If you have 63K, the fluid is going to be very very dirty by now, if it's never been changed before. And while you're at it, change out the ATF filter too. |
I was under the understanding that Honda recommends ATF change only at 120,000 miles, in normal conditions.
No code thrown. I just change it out because it's cheap insurance against transmission wear and tear and/or failure.
This thread is what made me decide to have fluid changed out earlier than what Honda recommends. Car actually shifted better after first change too. For second change, I switched out the Honda fluid for Redline. |
| Sponsored Links | |
Advertisement | |
| Tags |
| fluid, transmission fluid change |
