Trunk Springs - Drive Accord Honda Forums
Old 12-06-2011, 07:55 PM
Oo_Tut_oO's Avatar
Oo_Tut_oO Oo_Tut_oO is offline
3rd Gear
Trunk Springs
Hey everyone,
I noticed that when I open the trunk it doesn't lift up by itself like I'm used to with the 06 I have and the 09 I used to have. If I am correct this is affected by the trunk springs? I do have a deck lid spoiler installed on the car which I know has a heavy duty spring bar. Any advice on how to make it lift a little higher is appreciated. Pictures would help too
Current Cars:
2006 Honda Accord SE Royal Blue Pearl/Gray
2012 Honda Accord EX-L V6 w/ Navi Crystal Black Pearl/Black
Past Cars:
2009 Honda Accord EX-L I4 Taffeta White/Ivory
Old 12-06-2011, 09:55 PM
MM49's Avatar
MM49 MM49 is offline
Honda Racing Evolution
Its the spoiler ! My trunk doesn't lift up either because of the spoiler. If you want it to lift up properly then REMOVE THE SPOILER no other choice lol
Old 12-07-2011, 01:15 PM
Oo_Tut_oO's Avatar
3rd Gear
But on the '09 I had the trunk lifted up higher than this '12 and it had a full wing spoiler on it! I'm sure the wing spoiler is heavier than the decklid.
Current Cars:
Past Cars:
Old 12-07-2011, 01:38 PM
GoLowDrew's Avatar
GoLowDrew GoLowDrew is offline
Low Gear
When I installed my spoiler, I had to remove the counter balance weight. Trunk lift went back to the way it was.
It's in the center of the trunk lid, away from you, toward the rear glass side.
I had a post and pic here (on someone's thread as a DIY). Pop out the tab. Peel back the trunk lining. You should see it. Remove with screw driver.
Too lazy to look it up.
2010 Accord EX-L V6 Sedan.
2009 Odyssey EX-L RES
Old 12-07-2011, 03:07 PM
MM49's Avatar
....... My trunk doesn't lift up properly from the beginning
Maybe GolowDrew can be more of a active guy and find us both the solution he is talking about but to be honest it doesn't really bother me
Old 12-07-2011, 03:50 PM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
Are the heavy duty springs installed? The factory spoiler comes with springs that you have to use with the spoiler.
The springs should have a second notch to lock in and give them more tension but I don't know which is which.
2007 EX-L 4DR
Old 12-07-2011, 03:56 PM
Oo_Tut_oO's Avatar
3rd Gear
The spoiler came installed from the dealer so I'm not so sure how the stock one looked. I'm assuming the stock one has two white springs and the heavy duty spring is a single black one. The notch positions is what I am unsure about.
I'll try to go and find GoLowDrew's post and I'll repost it here if i find it...
Current Cars:
Past Cars:
Old 12-07-2011, 11:44 PM
Oo_Tut_oO's Avatar
3rd Gear
GoLowDrew is this it???
http://www.driveaccord.net/forums/sh...08&postcount=9
Current Cars:
Past Cars:
Old 12-08-2011, 01:02 AM
kimbahpnam's Avatar
kimbahpnam kimbahpnam is offline
6th Gear
actually there is another choice which is 1. heavy duty trunk springs and 2. remove metal trunk weight
2008 EX-L V6 ASM
AFTERMARKET
Inspire Headlights + LS 430 Retrofit (HID 5000k, switchback LEDs), Megan SS Coils, V6 Coupe Wheels, Mugen Style Kit, Inspire LED Mirrors, Takeda SRI, VS Clear Bra, 20% sides/32% Rear Tint, 3M Black Roof Vinyl, Sun Strip Visor, WT Digifit Liners, Inspire Trunk Garnish, JDM Decklid Spoiler, M3 Style Roof Spoiler, Modulo Sport Grille, LED Taillights, Full LED interior/exterior, Odyssey/Mesh Lower Grille, TSX 17mm RSB, P2R TBS, Crosstour Shifter, CF Trim, Trunk CCFLs
Old 12-08-2011, 05:09 AM
scb2755 scb2755 is offline
5th Gear
kimbah is correct, MM IS WRONG
can anyone confirm or deny the existence of trunk weights in a LXS coupe?
Old 12-08-2011, 08:37 AM
GoLowDrew's Avatar
Low Gear
Yes, and here is the pic. I can't find my thread/reply, but saved this pic. See where B is. Start opening it up from there. Now move over to the center. In line with the rear center brake light.
Yes, because it was a coupe guy that helped me with my sedan. He described it where it was in his coupe, which lead me to find it in my sedan. That's where this pic came from.
FYI, the A are also weights too, but don't remove it as they help the trunk closed.
After my spolier with "stock" springs, it seems dead. It unlocks but won't pop up. Without the weight, it's about 90% the way it was. IMO, more than good enough.
Old 12-08-2011, 03:09 PM
Oo_Tut_oO's Avatar
3rd Gear
Thank you all for the help. My first choice is adjusting the heavy duty spring that is already installed. Does anyone know an ideal latch position for them? If not I'll go ahead and remove the trunk counter weight.
Current Cars:
Past Cars:
Old 12-08-2011, 05:26 PM
Bubb@ Bubb@ is offline
Hey everyone,
You can buy a heavy duty spring bar from the dealership. They are used on accords with the lighted and unlighted wing spoiler.
Old 12-08-2011, 08:03 PM
Oo_Tut_oO's Avatar
3rd Gear
Are you aware of how the heavy duty spring bar looks? I'm assuming its the black one that I have and that the stock ones are beige...
Current Cars:
Past Cars:
Old 12-08-2011, 10:01 PM
tai tai is offline
4th Gear
the stock one and the heavy duty look about the same, except the heavy duty one was "heavier" and a bit thicker. I had a decklid spoiler originally on mine and was unsatisfied that whenever I popped the trunk it would only unlatch but never pop up so I swapped out one of the trunk springs with the heavy duty one. Made a world of difference.
For the V6, I know that there should be 2 heavy duty trunk springs you can swap out.
09 LX PMM
FX-R Retrofit | 15% Tint All Around | V6 bumper w/ independent fog switch | LED trunk and tails | JDM folding turn signal mirrors
For Sale: Rays 19x8.5 +35 wrapped in Dunlop/Kumho
