Upgrade from LX/SE 11.1" rotors to EX 11.8" rotors? - Drive Accord Honda Forums
Old 12-07-2011, 08:47 PM
John Bravo's Avatar
John Bravo John Bravo is offline
2nd Gear
Hello,
I would like to know if all Accords use the same front brake calipers; if so, would it be possible to swap out caliper brackets to upgrade the 11.1" brakes to the (somewhat) larger 11.8" EX brake rotors? Would they still fit under 16" wheels? I did a quick search, but most of the results had to do with the rear brakes and premature wear.
Warm Regards,
John Bravo
Old 12-07-2011, 09:02 PM
mi08coupe mi08coupe is offline
4th Gear
Check a Honda parts site like College Hills Honda or Bernardi Honda and see if the part #s are the same for the two calipers.
I can tell you that EX front discs and calipers will work with 16" wheels, as I use 16" steelies as my winter wheels. Its a close fit, but they work fine.
2008 Accord Coupe EX-L I4 NON_NAVI
R94 San Marino Red
Old 12-08-2011, 05:57 AM
starbot starbot is offline
3rd Gear
I have no real knowledge, but would be willing to bet the calipers are indeed the same, can't really imagine how they would make em any cheaper for the LX. Also shocked to hear they put smaller rotors in the Accord... the brakes kind of **** enough as it is.
Like the above poster said, there's an enormous amount of clearence so 16's wouldn't be an issue.
2008 PMM/Ivory 6-6
Old 12-08-2011, 06:32 AM
ededic00's Avatar
ededic00 ededic00 is offline
3rd Gear
I have a 2009 Accord Coupe V6, which I assume has the bigger rotors and im currently running 16" wheels for the winter and have no issues. Hope this helps.
2009 Honda Accord Coupe EX-L V6 Automatic
Mods:
-HFP Lip Kit, Megan EZ Coilovers, Progressive 22mm rear swaybar, J-Power Control Arms (rear), Roof Spoiler M3 style, Takeda SR Intake
Cars Owned:
2006 BMW 325xi 6 speed
2005 Chrysler 300c HEMI
2006 Chrysler 300 V6
2000 Chrysler Sebring Coupe LXi
Old 12-08-2011, 09:21 AM
Edaccord08 Edaccord08 is offline
Out of Control
you will need whole brake assembly that is used with EX+ , caliper assembly , pads and rotors .
Might be best to get parts off new model in junkyard ,except pads and rotors .
You can get them retail for about 125 or Remanufactured for 100 from Honda , thats not to bad .
http://www.hondapartsdeals.com/hpa_p...nGroupID=16222
Ed
2008 Accord LX, Alabaster Silver Metallic
gone 1985 XR4Ti
gone 1974 Opel Manta rally
Old 12-08-2011, 10:13 AM
el Vato's Avatar
el Vato el Vato is offline
4th Gear
Send a message via Yahoo to el Vato
As long as you are swapping out your 11.1 calipers and rotors for the 11.8 caliper and rotor off an EX, they should fit. The other way this will work is if you get brackets made so your calipers fit over the 11.8.
08' Accord Sedan EX V6 Silver/Black Leather
  • 18x9 Falken RT-7M et45 front et35 rear
  • 245/45/18 Falken Ziex 612
  • Rays Engineering Duraluminum
  • HFP Suspension
  • 12.6" Wilwood BBK
  • USDM Mugen Grille
  • 20% Tint
Old 12-08-2011, 10:39 AM
peter01592's Avatar
peter01592 peter01592 is offline
NJDR
your caliper wont fit over the rotor
2009 honda accord coupe ex-l v6
MODS:
To many to list.
Old 12-08-2011, 12:49 PM
Out of Control
right, the 11.8 rotors are thicker by 5mm than the 11.1 and it be hard to make bracket for only a 3/8 movement in radial position out .
Ed
gone 1985 XR4Ti
Old 12-08-2011, 07:06 PM
DieselVQ's Avatar
DieselVQ DieselVQ is online now
Freelance Gynecologist
John, what are you looking to get out of switching the rotors to a larger diameter?
Regards,
Diesel.
'12 Accord Coupe
Old 12-09-2011, 02:51 PM
3rd Gear
I love my car- especially the drive train, but the brakes are terrible. To think the LX brakes are even less capable isn't comforting.
2008 PMM/Ivory 6-6
Old 12-09-2011, 02:54 PM
Out of Control
AFAIK the LX uses same brakes as gen7 V6 did .
rotor size is not always best indicator of brake performance .
On many vehicles simple pad change improves braking performance by large factor .
I would look at the width more than diameter .
Ed
gone 1985 XR4Ti
Old 12-09-2011, 06:29 PM
John Bravo's Avatar
2nd Gear
Thank you all for the input! I do not yet own an Accord; I currently drive a 2001 Ford Taurus, but at 220k miles I am getting a bit nervous about repairs. The Taurus has been an amazing car both in terms of reliability and fun (believe it or not haha!). The engine is original and runs like new...but the transmission is known to be a weakpoint. My transmission is original and that scares me.
I don't look to gain much, if anything, from a rotor swap. The 2000 and older Taurus (non-SHO) came with 10.9" rotors and they could be upgraded to the 11.6" brakes simply by replacing the caliper bracket (easy find in a junkyard...any Taurus 2001+ will have them). I don't believe larger diameter rotors would necessarily improve the braking ability of the car, but I do believe that more massive rotors would tolerate repeated abuse in a much more reliable fashion. I am not a racecar driver, but I like to take my car out for a flogging every now and then.
Honestly, I only wanted to know if the swap was as simple as with the Taurus. When I saw 11.1" rotors on the Honda website, my initial impression was that these are severly undersized for a full-size car. I don't recall the width being specified, and I would agree that plays a role in overall braking quality. At the time, it seemed reasonable to believe the 11.8" brakes are more massive than the 11.1" brakes...initial impressions.
Once again, thank you all for the discussion I've enjoyed lurking on this site for the past month. My girlfriend has a long history of Honda Accord ownership. Her current ride is a Red 2010 Accord Coupe, 4cyl 5AT. I had never considered the Accord to be an interesting car until I drove hers...my first words were, "it feels like the seat - whole car in fact - is tailored to me!" It only got better as I drove through the countryside around some winding roads. The steering was perfectly weighted, the engine had ample power...I could not express in words the joy I got from her car. Since that time I've been dreaming of owning one
Cheers!
Old 12-10-2011, 02:00 PM
Highlanduh's Avatar
Highlanduh Highlanduh is offline
4th Gear
Cheers!
If you got that much joy out of a 4cyl, get yourself a V6 w/HFP suspension, put a 22mm RSB in and some stickier tires, and you'll be in Heaven.
'08 NBP Sedan EX-L V6
Acura TL A-Spec 18x8 with 245/40/18 Hankook Ventus V12, HFP Suspension, SPC 3-arm, Progress 22mm RSB, OEM Deck Lid Spoiler, Roof Spoiler, WeatherTech Side Deflectors, T-Rex Billet Grilles, Crosstour Woodgrain Trim & Shift Knob, OEM Remote Starter, OEM Backup Sensors, Switchblade Keys, Door Sill Trim, Aluminum Pedals, JDM Steering Wheel, OEM Cargo Net, Eagle LED Tails, Takeda SRI, P2R TBS
KUDA Mount with CarComm iPhone Pass-thru Cradle and USA SPEC PA15-HON2 interface
Old 12-10-2011, 02:26 PM
mobiless2's Avatar
mobiless2 mobiless2 is online now
mobiless2
John B, no Honda does not use the same caliper & bracket for all models. You will need rotors, calipers & brackets, but an easy bolt on.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 245K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 99K
