V6 valve adjustment - Drive Accord Honda Forums
Go Back   Drive Accord Honda Forums > Honda Accord Factory Facts > 2004 Honda Accord Instructions
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 06-13-2006, 09:40 AM
princess's Avatar
princess princess is offline
ready to go....
Send a message via AIM to princess
V6 valve adjustment
1 of 9
NOTE: Adjust the valves only when the cylinder head temperature is less than 100 F (38 C).
Remove the cylinder head covers.
Set the No. 1 piston at top dead center (TDC).
Align the pointer (A) on the front upper cover with the No. 1 piston TDC mark (B) on the front camshaft pulley
I kicked cancer's butt! You might be next!!!! :) I survived a fatal heart attack, PRAYERS WORK!
(_l_)(_/_)(_l_)(_\_)(__)(_l_)(_/_)(_l_)(_\_)(__)(_l_) butt dance.
the latest in a long line of Hondas:
Ours: '06 Ridgeline RTL with Nav Steel Blue, rear view & cargo cameras, iVES, hitch, INfinity speakers, running boards, alternate front grille, garnish, roof rack, now with 18" Ridgeline rims
little '98 Civic sedan, everything still works! Named Mater.
Old 06-13-2006, 09:42 AM
princess's Avatar
ready to go....
2 of 9
Select the correct thickness feeler gauge for the valves you're going to check.
Valve Clearance
Intake:
0.20-0.24 mm (0.008-0.009 in.)
Exhaust:
0.28-0.32 mm (0.011-0.013 in.)
Old 06-13-2006, 09:43 AM
princess's Avatar
ready to go....
3 of 9
Insert the feeler gauge (A) between the adjusting screw and the end of the valve stem on No. 1 cylinder, and slide it back and forth; you should feel a slight amount of drag.
Old 06-13-2006, 09:44 AM
princess's Avatar
ready to go....
4 of 9
If you feel too much or too little drag, loosen the locknut (A), and turn the adjusting screw (B) until the drag on the feeler gauge is correct.
Tighten the locknut and recheck the clearance.
Repeat the adjustment, if necessary.
Old 06-13-2006, 09:46 AM
princess's Avatar
ready to go....
5 of 9
Rotate the crankshaft clockwise. Align the pointer (A) on the front upper cover with the No. 4 piston TDC mark (B) on the front camshaft pulley.
Check and, if necessary, adjust the valve clearance on No. 4 cylinder.
Old 06-13-2006, 09:47 AM
princess's Avatar
ready to go....
6 of 9
Rotate the crankshaft clockwise. Align the pointer (A) on the front upper cover with the No. 2 piston TDC mark (B) on the front camshaft pulley.
Check and, if necessary, adjust the valve clearance on No. 2 cylinder.
Old 06-13-2006, 09:49 AM
princess's Avatar
ready to go....
7 of 9
Rotate the crankshaft clockwise. Align the pointer (A) on the front upper cover with the No. 5 piston TDC mark (B) on the front camshaft pulley.
Check and, if necessary, adjust the valve clearance on No. 5 cylinder
Old 06-13-2006, 09:50 AM
princess's Avatar
ready to go....
8 of 9
Rotate the crankshaft clockwise. Align the pointer (A) on the front upper cover with the No. 3 piston TDC mark (B) on the front camshaft pulley.
Check and, if necessary, adjust the valve clearance on No. 3 cylinder.
Old 06-13-2006, 09:51 AM
princess's Avatar
ready to go....
9 of 9
Rotate the crankshaft clockwise. Align the pointer (A) on the front upper cover with the No. 6 piston TDC mark (B) on the front camshaft pulley.
Check and, if necessary, adjust the valve clearance on No. 6 cylinder.
Install the cylinder head covers.
Old 04-09-2010, 03:48 PM
jmg7666 jmg7666 is offline
Just looking for verification...
OK, first of all I have this clicking or ticking noise coming from the top of my 04 V6 Accord. A couple of people told me it sounds like a valve. So I start googling and run into this forum. ( So being an owner I had to register ) Sounds like I need a valve adjustment. So I call a Honda service dept. and guess what they say? "You don't adjust those valves they have hydraulic lifters." BUT! (Big BUTT) In my Haynes manual, it actually gives instructions. Also, I found this wonderful post.
So, just curious if someone has already done this procedure before I go out and waste a WHOLE $14 on the 2 gaskets. And about an hour (yes, I'm very slow and careful) taking off the intake and valve covers.
Any help is appreciated!
Peanut Butter Jelly Time!!!!
Old 04-12-2010, 03:07 PM
ivirovets's Avatar
ivirovets ivirovets is offline
3rd Gear
What I've heard is that the lifter tick is a normal sound to an extent in our accords. But I to am curious, because mine seems kind of loud.
'04 EX-L V6 Sedan, 20mm TL-S sway bar, Resonator delete, Apexcone 35W 5000k HID, Hardwired Escort 8500
Old 04-13-2010, 08:56 AM
princess's Avatar
ready to go....
jmg7666, yes, they are adjustable.... the V6s that weren't were the old original ones. The ones in my '03 Accord were adjusted at 15K. Honda's "as needed" policy is bunk! If they come out of adjustment by decreasing the gap, they'd probably never make noise.... yet not perform correctly!! We've done ours at 15k time frames. Never had a noisy one.
ivirovets, yes, SOME sound is normal. It's usually not that much though. Having heard thousands of engines, some sounds are simply normal & the ol' ears ignore them. If I heard it, then it wasn't normal.
Old 10-27-2010, 12:30 PM
princess's Avatar
ready to go....
bump for member
Old 10-30-2010, 08:11 AM
HAccord3.0 HAccord3.0 is offline
Fully Loaded!!!
Directions
Princess,
Could you pleae give me the directions on how to remove the Intake Manifold and Valve Covers so I can do a valve adjustment on a 2004 Honda Accord 3.0 V6? Thank you!
Old Yesterday, 01:55 PM
Strath's Avatar
Strath Strath is online now
4th Gear
Originally Posted by HAccord3.0 View Post
Princess,
Sorry for the necro but I could also use instructions on removing the valve covers.
Title goes here
close
video goes here
