Water Pump DIY for 4 Cyl? - Drive Accord Honda Forums
Old 01-08-2012, 06:44 PM
deyomatic deyomatic is offline
2nd Gear
Does anyone know of a DIY for the water pump replacement on a 4cylinder Accord- mine's an '04. I'm planning to do the serp. belt and PS pump and thought I'd see how much of a pain the water pump is.
Thanks.
Old 01-08-2012, 07:09 PM
Rattmann Rattmann is offline
5th Gear
Is it Leaking?
Old 01-09-2012, 03:24 AM
2nd Gear
No, it's functioning fine, I just figured I'd see how much of a pain it is. I have to replace the Steering pump, serpentine belt, and belt tensioner and I wouldn't want to remove all that stuff and put it back to find out that I have to take it all off again if the water pump craps out in 10,000 miles.
More than likely, I'll see what's involved, it'll either be really easy or really hard and I won't do it anyway because it's working just fine!
Old 01-09-2012, 05:48 AM
nehonda's Avatar
nehonda nehonda is offline
6th Gear
I believe its driven by the timing chain, so its much more involved than you are doing for the surpetine belt change, but Im not as familiar with your 7th gen as my 6th gen.
2000 Accord SE I4 F23A1 Auto - Sold @174k miles & 10 years ownership
1998 Accord LX I4 F23A1 5 speed - sons DD in DC
1986 Accord LX Auto Totaled @137k miles
1983 Accord LX 5 spd My Second Accord traded in
1978 Accord LX 5 spd My First Accord sold @ 100k
Old 01-09-2012, 06:17 AM
rszappa1 rszappa1 is offline
6th Gear
No it is not.. The water pump is driven by the surpetine belt. From looking in the chilton book it is a very easy job to do...
Old 01-09-2012, 04:30 PM
korrupt3dazn's Avatar
korrupt3dazn korrupt3dazn is offline
2008 Honda Accord V6 EX-L
Send a message via AIM to korrupt3dazn Send a message via Skype™ to korrupt3dazn
looks easy..
2008 Honda Accord EX-L V6 Coupe w/ Navi
Previous Cars:
2004 Accord EX-L I4
2000 Accord EX V6
Old 05-14-2013, 06:00 AM
71Rcode 71Rcode is offline
Nice how to - thanks for posting it. Any idea on the lifespan of the OEM water pumps? My i4 ('06 model) has 93k on her with no signs of leaking.
Old 05-14-2013, 06:41 AM
6th Gear
Mine has 192,000 on it and no leaks or noise...
Old 05-14-2013, 09:10 AM
great to know! I won't plan on changing until necessary then. Same coolant and heater hoses, too?
Drew03Accord Drew03Accord is offline
Out of Control
I'll put it simply. It can last the life of the car, is relatively easy to change and will give you prior warning before failure. Leave it alone till you need to change it. If you have $$$ burning a hole in your pocket, I have an Paypal account.
Coolant is to water pump what oil is to engine. Change the coolant every few years, your pump lasts longer.
2003 LX Sedan, i4 + Automatic. 170K and counting.
Old 05-14-2013, 05:37 PM
turbointegra209's Avatar
turbointegra209 turbointegra209 is offline
thanks i needed to change mine also ...without DIY people would be be spendin more money to dealership
Old 05-14-2013, 06:40 PM
CarlR33's Avatar
CarlR33 CarlR33 is offline
6th Gear
218K on my original. Change the fluid at recommend intervals and your OK.
03 Accord LX I4 5spd, 230k miles.
Old 05-15-2013, 04:05 AM
Thanks, Carl. Check on the regular coolant changes. Have you changed any of your coolant or heater core hoses? thanks, man.
Old 05-15-2013, 05:32 AM
6th Gear
On mine all the hoses are original also.... and the thermostat
Old 05-15-2013, 06:30 AM
Out of Control
All original here too.
