Does HFP suspension need camber kit on sedans?
I'm considering getting HFP suspensions for my sedan but I have concerns about camber changes. I know there's the general rule of how much a drop would require a camber kit. Would I be able to get away without a camber kit and not have to worry about tire wear?
2011 CBP Accord Sedan EX V6 Morimoto Mini H1 Megan EZ Streets J-Power Camber TSX 17mm Rear Sway Bar |
| Sponsored Links | ||
Advertisement | ||
Main thing that will cause tires to wear out faster is toe, not camber.
If you get a good alignment and toe is spot on, then you have nothing to worry about and will be fine without a camber kit. |
I had to do both camber, and toe arms in the rear to get it back to -1.3 deg of camber on my sedan. Camber arms alone only brought it back to -1.8 deg...
YMMV |
Same. HFP put me at -3.1. Best to get it all done at once if possible since the camber kit installation will require realignment.
2011 CBP Sedan EX-L V6 | http://inspiredaccord.blogspot.com Vossen CV3 | Nitto 555 | BC Coilovers/SPC Arms | Mugen/Modulo Kit | Sarona Roof Spoiler | Quad Morimoto/xBa2 Halo/WIFI RGB Demon Eyes Retrofit | Fog Light Retrofit | Inspire OEM Mirrors/Garnish | Eagle Eyes Trunk/Tails | Full LED Exterior/Interior | UltraGauge | Takeda SRI | JET MAF | Magnaflow/Vibrant | SprintBooster | UR/Progress Bars | EBC Brakes | Duralast Gold | Next: RV6 J-Pipe |
Okay thanks. I don't plan on getting all the extra toe/camber stuff now is cause I'm a little tight on money. If I can manage on just a good alignment, then that's good enough for me.
You'll be in the neighborhood of -3 to -3.2 deg of camber with no adjustable arms... FYI.
Good luck |
Here's the Honda Installation Instructions for your suspension. The last step lists Honda's recommended camber and toe settings. It may be useful as a point of reference for you.
http://www.handa-accessories.com/acc...pension2dr.pdf
2006 Accord Coupe silver 6 speed |
| Sponsored Links | |
Advertisement | |
