Price estimate for Transmission flush - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 02-19-2012, 06:41 PM
dlaxman31's Avatar
dlaxman31 dlaxman31 is offline
4th Gear
I have about 55k on my 2006 Honda Accord v6 and need to get the transmission flushed (first ever I believe). I'm curious how much a transmission flush should cost. Also what should I ask for/look for when getting it done.
I don't have the time/feel comfortable doing it myself.
Thanks for your input.
Old 02-19-2012, 06:54 PM
LarrynKy LarrynKy is offline
They advise against a flush. But rather a transmission drain and refill. It should be about $75-$85. There are some information out here showing it is quite easy to do yourself (looks easier than an oil change). Will take about 3 qts of Honda transmission fluid to refill.
Old 02-19-2012, 07:32 PM
2006accord4 2006accord4 is offline
2006 I4 MT
yeah don't be a wuss and do it yourself
This is all you need.
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 76k miles
Old 02-19-2012, 08:03 PM
LeaDxPainT LeaDxPainT is offline
3rd Gear
Honda Flush = Drain and Refill x3
If you do find the time, it's as simple as an oil change. Maybe simpler, you don't have to deal with a filter.
'06 Accord Sedan I4 5MT
Old 02-19-2012, 08:18 PM
BLCKFLSH's Avatar
BLCKFLSH BLCKFLSH is offline
Make that BluFlsh
There is a filter, although the dealership will not change it. Changing the filter is a little more complicated. Change the fluid as often as necessary, to keep it clean. IMO, you can't tell how dark/dirty the fluid is, just by looking at the dipstick. I drain the fluid into a large clear container, so I can see exactly what's in the fluid and how dark it is. How much metal there is stuck to the drain plug magnet, and the filter should also be considered, to decide how soon you need to drain and fill again. Here's a how-to link for you.
http://www.driveaccord.net/forums/sh...ad.php?t=13804
92 EX Sedan auto - sold after 12 years (140k miles)
03 EX V6 Sedan auto (120k miles) - present car
Old 02-19-2012, 08:27 PM
strate l o s s strate l o s s is offline
4th Gear
just DIY, as easy/easier then engine oil. Why pay $80 anywhere when they change engine oil for $20 but this is the same if not easier to do.
2012 Accord Sedan EX- Crystal Black Pearl I4
why does everyone have huge mod list in sig ? make build thread->link it
Old 02-20-2012, 01:04 AM
NightMarcher01's Avatar
NightMarcher01 NightMarcher01 is offline
aka 'The Gif King'
A transmission drain and refill is NOT easier than changing your oil! You guys need to stop lying to yourselves! Lol
OP... If you're gonna do it the correct way, it'll cost you a little over $100. But if you let the dealer do it the correct way, it'll cost you more like $500! LMAO
2003 Honda Accord Sedan
http://www.cardomain.com/ride/3877738
CHECK IT OUT!
Old 02-20-2012, 05:19 AM
3rd Gear
Oil Change:
1) Loosen oil cap
2) Remove drain plug and wait for oil to drain
3) Remove oil filter
4) Reinstall drain plug with new washer
5) Reinstall oil filter
6) Refill with x quarts of oil
Auto Transmission Change:
1) Loosen Dipstick
2) Same as above
3) Optional, Honda does not instruct to have this done every flush or at all even.
4) Same as above
5) Optional
6) Same as above but with ATF
I have a manual transmission and changing the mtf takes much longer because the fill plug is not an easy one to reach. I follow the same drain fill procedure with my wife's Civic except I can refill the atf through the dipstick hole. It takes the same amount of time to do an ATF drain and refill as it does an oil "drain and refill".
ATF drain and refill can be spaced out to every 10k miles or "flush" every 30k. Local dealership quoted me about $100 for a transmission drain and refill for the Civic. I know it's not a same car, but it gives you an idea. The quote was given a few years back.
Old 02-20-2012, 04:28 PM
aka 'The Gif King'
Originally Posted by LeaDxPainT View Post
Oil Change:
1) Loosen oil cap
1) Loosen Dipstick
2) Same as above
4) Same as above
5) Optional
But as I stated, the correct way... OP asked for a transmission FLUSH, a flush consist of changing out the WHOLE transmission fluid, not just 3 quarts.
While an oil change is simply drain and refill. A transmission fluid change consist of the same thing, BUT also taking the car out for a drive and going through each gear, then going back and doing ANOTHER drain and refill, then again! Go out for a drive and go through all the gears, then go back.... AGAIN! And do another drain and refill.
Yeah I think you get the point.
CHECK IT OUT!
Old 02-20-2012, 06:28 PM
3rd Gear
The post was in response to your quoted text above, of course it's going to take longer to do a flush. As was mentioned above, Flush=Drain and Refill x3.
Sorry OP, I'll stop derailing your thread. Just don't want people to get the wrong idea about DIY maintenance.
Old 02-20-2012, 07:11 PM
4th Gear
Honda only recommends doing a drain and fill, a complete flush is only recommended on rare occasions.
I seen the Honda newsletter.
Old 02-20-2012, 07:15 PM
thegrouch thegrouch is offline
5th Gear
full flush can be done with a transmission flush machine. I've used one before. It really isn't that necessary. Just do a drain and refill every other or third oil change. It is the best way to ensure the transmission fluid is clean and it will also make the auto trans live longer.
1991 Honda Accord EX
Old 02-20-2012, 07:16 PM
4th Gear
a flush machine Honda advises to NEVER use that. I just drain and fill my cars.
Easy breeezy
python6mt python6mt is offline
3rd Gear
I have an 06 5at and I just did a flush at ~75k (really hoping they did it at certification at ~50k). I'm borderline paranoid because of all the problems with the early 7gens, and the 7.5gens typically haven't gotten to the 130k-ish miles where the log thread is littered with failures.
With that said, let's recap:
A 1x drain/fill takes 3qt ATF and is definitely easier than an oil change. The fill bolt is only slightly tough to get to because it's so far down; a long extension solves this problem immediately (also why you need the long funnel). If you're paranoid, do this with every oil change. If you're moderately concerned, every 15k. Most dealerships will charge $100 for this, though it costs all of $24 in fluid (retail prices, you can definitely get the stuff for $6/qt).
A tranny *flush* as others have said, takes 3x drain/fill + another fill, for a total of 12qts. This is because the tranny really has 7qts in it, but only 3 come out on the drain. To mostly replace the fluid, you have to do the exchange 3 times - AND drive it between each time to completely mix the fluid. Alternatively, you can sit it on jack stands and run the car through all the gears each time (much quicker). At 55k, I would highly recommend you do the flush, but I don't doubt that the dealer would charge you about $500 for the service given that it's more time consuming than difficult. Total cost in fluids, though: $100 shipped. A good interval for a flush is every 30k (which is why I highly recommend it since you're nearly double) if you never do any other changes; maybe 45k if you drain/fill at 15k; paranoid people will still flush at 30k despite constant drain fills
As for the ATF filter: it's probably a good idea to change it at 55k, though you're probably going to have to do that one yourself, or fight with the dealer to convince them that it exists in the first place, much less agree on a reasonable price to do the change. Word of advice: look up the name of the service manager and always to talk to them when possible. In my experience, the service advisors are typically trained to write you up for retail prices and not much else. Service managers can actually be reasoned with and are much more pleasant...
13 i4 CVT Navi MSM/Gray
06 6-6 Navi CBP/Ivory GMSMFM TL-S RSB Coming soon: TL-S FSB
Old 02-21-2012, 05:16 AM
rszappa1 rszappa1 is offline
6th Gear
Man how many times does this come up................................ NO FLUSH ON A HONDA TRANNY..Drain and fill only..................
