Transmission fluid? - Drive Accord Honda Forums
Old 05-11-2012, 03:30 PM
AccordV6-271's Avatar
AccordV6-271 AccordV6-271 is offline
4th Gear
Question Transmission fluid?
I recently decided that I was going to swap the transmission fluid in my 6mMT to GM's friction modified blend. I bought this exact fluid off www.paceperformance.com and received the package today. I was surprised to see an off brand in the box. I got ACDelco part # 88900399.
I went on to their site to make sure I actually ordered the right thing and there was a note that stated "this transmission fluid(the gm type) was replaced with the stuff they sent me(ACDelco)."
Is it the exact same stuff in a different package, or is it different?
I don't want to do the swap until I know that it's the EXACT same.
What do you guys think?
2010 Accord Coupe EX-L V6 6MT
Mods:
OEM Splash Guards / OEM Floor Matts / OEM Trunk Tray / License Plate Frames / 18x8 Moda MD7 Rims / Michelin X-ICE Winter Tires / Black Exhaust Tips / OEM Cargo Net / 8000K HID Lows / 3000K HID Fogs / Cosmo Short shifter / 25mm spacers in the rear and 20mm spacers in the front w/ stock rims
Old 05-11-2012, 03:39 PM
Artema's Avatar
Artema Artema is offline
Michael
Does their site say you agree to a swap if they decide to do it? I would reverse the charges, that's messed up.
Old 05-11-2012, 05:21 PM
4th Gear
Thats the weird thing....I never agreed to anything like that
Mods:
Old 05-11-2012, 06:25 PM
Danielc409's Avatar
Danielc409 Danielc409 is offline
Sugar coating for you ..
Don't worry, I believe it's the same stuff. They have been changing their name / part numbers. Do a little google searching. Supposedly the original part number for the GM synchromesh is outdated, so when cross referenced with that number, it brings up 88900399. They simply changed to AC Delco is all.
2011 Subaru STi - Stage 2 - Plasma Blue Pearl
My member journal / build thread @ IWSTI
2008 Honda Accord Coupe V-6 EX-L AT NBP
No longer owned
Old 05-11-2012, 06:43 PM
ypsibird's Avatar
ypsibird ypsibird is offline
6th Gear
This thread provided a heads up on the change.
http://www.driveaccord.net/forums/sh...hromesh&page=2
2006 Accord Coupe silver 6 speed
Old 05-11-2012, 06:51 PM
Danielc409's Avatar
And how did you find this thread?
There is just about an answer for everything using the search feature OP! Use it! .. just bust'n your balls.
No longer owned
Old 05-11-2012, 09:19 PM
tcwhite's Avatar
tcwhite tcwhite is offline
2nd Gear
Yes it is the same stuff. I just did mine with the new part number last night. Good to go.
Old 05-12-2012, 10:23 AM
bronzy77's Avatar
bronzy77 bronzy77 is offline
2009 Accord Coupe V6/6
Yes it is the same. It's what I used, so far so good. No missed shifts, and I am no longer ultra careful in releasing the clutch after upshifting into third. Best tip I've seen on the forum!
2009 Black Coupe V6 6speed
Old 05-12-2012, 11:36 AM
4th Gear
Thanks guys
Mods:
Old 05-12-2012, 01:10 PM
ezshift5's Avatar
ezshift5 ezshift5 is offline
6th Gear
+1.5.......
I've felt like that since 2009. (thanks Avio/YpsiBird)
ez.......(at 52,000 on same GM goo: no 2nd-3rd problem since, not one).
2005 Accord EX V-6 Coupe 6M
Taff. White;cargo net;7-24-05
'13 VW JETTA SPTWGN TDI 6M
Build date:03/12/2013 NO NAV
ZERO SUNROOF:CANDY WHITE
1982 VW Rab. Diesel Pickup 5M
Mojave Beige/ac/bedliner/alloys
(sold to restoration outfit)
