08 EX-L Navi V6 Check Engine Light Issues - Drive Accord Honda Forums
Old 05-14-2012, 05:45 AM
aN4rk1 aN4rk1 is offline
2nd Gear
I bought the car last August with 90k KMS (56k miles) on it and this first happened about a month ago. I was on the highway, using the cruise control at 120 km/h. The check engine light started flashing for about a minute, then became solid with the VSA light and the traction lost light (Little triangle with the exclamation mark inside it) light, both solid. It drove just fine, so I got home and cleared the light by disconnecting the battery.
All was good, it didn't come back on until yesturday. Same thing happened, check engine light flashing, then went solid with the other two lights. Cleared it. Again it came back. Cleared it AGAIN, and this time the check engine light just stays flashing while the two other lights are just on.
I am worried on what it could be? From googling it maybe a misfire code for cylinder #3? Maybe a bad ignition coil or cable?
I manager to get an innova OBD-II code reader (this one: http://www.innova.com/Product/FullDe...9-16B3A0334F7F) from a friend at work and am going to try and read the code tonight. My questions are:
1) Where is the port? From googling it seems its somewhere in and around the driver side foot well?
2) Is this the right reader? I know the protocols changed with this generation of accords.
3) Anyone have similar issues?
Old 05-14-2012, 05:51 AM
Metal Metalic's Avatar
Metal Metalic Metal Metalic is offline
6th Gear
The ODBII port is near the hood relase... it is vertical along side the kick panel.
Should work as long as it is ODBII as stated.
No, the only thing that comes to mind with VSA off / Traction light error is TPMS air pressures need checked.
2009 EX-L Coupe - V6 VCM - PMM
0w-20 cap
3.7L TL-SHAWD IM - Functional
65w H9 Lo & Fog / 80w HB3 Hi
Cargo hooks & net
Crosstour knob
Duralast Gold 24F-DLG
I4 hood rod
MDX spacer & Runners - Ported
Moded OEM CAI
Mobil 1 0w-20 & M1-110
NAPA #18514
Odyssey garnish - Flush fitted
Painted splash guards
PXAMG & HDRT
Rear: Belt, head rests & ANC delete
Service Grade Electricals
Test Pipe
Window UP mod
Valvoline Type VI
Next:
Acura TL-SHAWD Heads
HFP suspension
Old 05-14-2012, 05:56 AM
coupe7 coupe7 is offline
2010 coupe'
Autozone will pull you're trouble codes for free. But when it comes to sensors i recommend honda only.
Hids
Fog light
Mud guards
10 inch sub
Weather Tech
Snow tires
Led interiors
K N drop in filter
Old 05-14-2012, 05:59 AM
2nd Gear
Thanks for the reply.
I dont think its TPMS as I have had a TPMS sensor go off before. It looked like this: http://carpoolwithbill.com/wp-conten...lay1.jpg?w=300
When it came on, I drove to a gas station, filled up all 4 tires with air and it was good. The check engine light was not on for this.
This is what my dash looks like now:
http://www.carcomplaints.com/media/c...72c263bb7r.jpg
2nd Gear
Thanks but Autozone is only in the US. I live in Canada
Old 05-14-2012, 08:06 AM
pmdbruin pmdbruin is offline
4th Gear
I think you have the same problem as this guy: http://www.driveaccord.net/forums/sh...ad.php?t=71038
Except he didn't find out what the problem is. I'm sure your OBDII reader will give you more information.
2011 Accord Coupe I4 EX-L CBP
Old 05-14-2012, 08:18 AM
ilovelamp's Avatar
ilovelamp ilovelamp is offline
5th Gear
Based on the image of your dash, you have an engine code and your tpms is not functioning properly, nothing to do with tire pressure. Without knowing the codes there isn't much to do. Take it to the dealer if there are no other shops or parts stores that will read it.
2010 Accord EX-L V6 PMM Sedan (w/o nav)
My First Honda!
X-tour shiftknob
Philips HIR 9012 Low Beams
Old 05-14-2012, 09:09 AM
2nd Gear
Why do you think its TPMS? The TPMS light didnt come on. TPMS = tire pressure monitoring system. I am going to go home and get it read, and report back asap.
A little more information. The car's idle is very rough. When I stop at a stop light I can feel a huge vibration of some sort, it feels like its from the engine. I cant accelerate hard at ALL, the car "shudders", feels like when someone who doesn't know how to drive manual, driving for the first time.
Old 05-14-2012, 09:14 AM
4th Gear
People are getting the TPMS light confused with the (!) light that you have on. In other cars, the TPMS light looks very very very similar to the (!). In the Accord, however, I believe the TPMS light is basically the words "TPMS" lit up. You'll have to forgive people since it's very easy to mix up the two.
Old 05-14-2012, 09:31 AM
ilovelamp's Avatar
5th Gear
My apologies, as stated, the tpms light says tpms. I thought I read tpms. From my reading, the vsa and exclamation light could signal an issue with the brakes, the vsa system itself or a potential slippage being constantly detected by the system.
Based on the other symptom, a misfire is possible. The car could be stuck in vcm, limp mode.
My First Honda!
X-tour shiftknob
Old 05-14-2012, 10:59 AM
2nd Gear
No Problem
Yes this is my guess as well. Ugh, stuck at work, really want to get this fixed
Old 05-14-2012, 01:59 PM
AccordHFPMTL's Avatar
AccordHFPMTL AccordHFPMTL is offline
3rd Gear
hmmmm I would check around the MAP sensor.... Msg me if you want details..
Canadian Spec HFP 6-6 Black series 139/200
Takeda SRI
RV6 Jpipe
Magnaflow resonated Cat-Back
Old 05-14-2012, 02:52 PM
2nd Gear
Hey Guys,
just got home and read the code. It came up as cylinder #3 missfire. Ok so now what do I do? I am going to clean the spark plug for now and see if it comes back. If it does, does that mean I need to change the ignition coil? Also, which ones is cylinder #3? I found this schematic for honda v6 engines, is this correct?
http://autorepair.about.com/library/...bl-fo-0284.htm
Old 05-14-2012, 03:09 PM
ilovelamp's Avatar
5th Gear
Hey Guys,
That's the schematic I found ad well. You just need to replace the plug. Isn't your car undrr warranty though? Going by US, its 5 year 60 miles.
My First Honda!
X-tour shiftknob
Old 05-15-2012, 05:15 AM
2nd Gear
Used that schematic and cleaned the plug. It was VERY black. Drive around after and to work this morning and it seems ok. I don't think its under warranty. I bought it used and its at 123k Kms at the moment.
