How to reset the Check Engine light - Drive Accord Honda Forums
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-16-2006, 01:53 PM
minstrel614 minstrel614 is offline
I followed the document posted by Princess on the Sticky Throttle body thread (http://www.driveaccord.net/forums/at...achmentid=4260) to clean the throttle body on the 00 SE but made a stupid mistake.
When I put the things back together, I forgot to reattach the MAP connector. Afterwards when I started the car, the engine was running but the idle speed was dangersly low and the "Check Engine" light came on. I shut off the engine and check the connections and found the disconnected MAP connector. So I rechecked everything and reattached all of the connectors, and I tried to start the engine again. Now the idle speed went back to normal and the car ran ok, but the "Check Engine" light stayed on.
How can I reset the check engine light? I heard that disconnecting the battery cable may not work - I can't find the radio code so I didn't try it yet (I thought it was on a piece of paper in the manual but just couldn't locate it).
'00 Accord SE and '04 Odyssey EX
Old 07-16-2006, 01:57 PM
BenjiBoy650's Avatar
Go to the fusebox on the passenger side of the car (interior) and pull the clock fuse for ~3-5 mins. It only affects the clock and the computer, you won't need a radio code if I recall.
Old 07-16-2006, 03:03 PM
That worked! Thanks!
One of the threads (maybe the sticky throttle thread) mentioned after cleaning the throttle body one should make the computer re-learn the idle speed... Is that really necessary? I thought the computer is supposed to "learn" the engine running conditions "on the job"?
Old 07-16-2006, 03:12 PM
You could try it but IMO it's a bit of a waste of gas. Eventually it will just reprogram itself. I have never done the idle learn procedure and have no problem - I've disconnected the pre-cat O2 sensor a few times with the engine on too, for shop assignments, so I don't think it's a big deal. I remember the car used to vibrate but that could have been bad gas, or just a temporary thing with not doing the idle learn...either way it's fine for me now.
Old 07-17-2006, 06:41 AM
Thanks for the info. I will skip that step.
