Eagle Eyes Halo Projectors DRL and High don't work - Drive Accord Honda Forums
Old 06-08-2012, 07:37 PM
Stegall_85 Stegall_85 is offline
Hey guys. Just installed new Eagle Eyes halos in my 2008 Accord EX. Now the Halos work, signals, LEDs, low beams, but my DRL don't come on and my highs don't work either. I'm pretty sure the halo's are intended to be the DRLs, but I get nothing, and my DRL Indictator light is on. I try to switch to highs, but my lows stay on. I haven't checked the fuses yet. Did I blow my DRL relay? Could it be the bulbs? My OEM setup everything worked. I'm gonna check my fuses tomorrow. Should I be going to a higher amp fuse?
So to clarify, in the regular DRL position, I get nothing. With lights on I get halos and lows. When I click to high beam the indicator on the gauges lights up, but the lights stay on lows.
Please help
Old 01-12-2013, 11:00 PM
beekayhoax beekayhoax is offline
2nd Gear
bump
Don't wanna thread jack but, I just installed my retro, with dual Morimoto xB LED rings and FX-R projectors for low beams.
I wired the halo's to my side markers which run on the same fuse as the DRL's and turn signals. The fuse keeps blowing out. its a 10 amp fuse, should I go up to 15 amps? I tried that and it blew too.
I checked all the wiring and I don't see it shorting, all the + and -'s are separated and wrapped
2009 Accord V6 CBP w/ Navi - AT
WeatherTech Digital Floor Liners & Visors - Switchback LED's - EagleEye Black Tails - Viper
ContourCam - Crosstour Shifter Knob - CREE 9W Reverse LED's - Switchback Turns w/ stock Sedan Yellow Reflector Caps
Mugen Rad&Engine Oil Caps - 'Mug Style' Grill - GutterGuard Lower Grill
Optima RedTop ~ 0 Gauge - Kenwood Class D Mono Amp - Kicker L5 10"
JL Audio JX360.4 - Polk DB6501 Components (Rear Deck/Front Doors) - JL Audio Cleansweep
TSX Rear Sway Bar
HFP 19's
Old 01-14-2013, 07:45 AM
korrupt3dazn's Avatar
korrupt3dazn korrupt3dazn is offline
2008 Honda Accord V6 EX-L
Send a message via AIM to korrupt3dazn Send a message via Skype™ to korrupt3dazn
I would
1. 12 volts to the Halo Rings and see if that powers up properly.
2. Hook up a Volt Meter to the connections you are tapping the Rings into to see if you have the right polarity\Voltage.
2008 Honda Accord EX-L V6 Coupe w/ Navi
Previous Cars:
2004 Accord EX-L I4
2000 Accord EX V6
