Ebay foglight cause a whole lot of electrical mess - Drive Accord Honda Forums
Old 06-24-2012, 05:38 AM
popoho popoho is offline
I just installed a after market foglight from Ebay (K2) and followed the instruction on the video the have. Once everything is done, the foglight is operational. But now I have a slew of other electrical issues.
The A/C compressor does not turn on kick in. The high beam, door lock beep, driving light, windshield washer, INT wiper all not working.
The instruction call to splice the foglight power wire (white) to all time power on the honda. Splice red wire from foglight to ACC on honda under the dash.
I check all the fuses and none are blown.
Did I messed up big time? Is it hard to diagnose what went wrong and fix? At one point the check engine light did came on.
I am at a total loss here.
2007 Accord SE V6 Graphite Pearl
USA SPEC Ipod Interface
Old 06-24-2012, 08:34 AM
mobiless2's Avatar
mobiless2 mobiless2 is offline
mobiless2
You should order the factory fog light harness & switch. Use the lights, but use factory harness.
2005 SSM LX I-4 Auto Sedan: TL-S FSB / TL-S RSB / Tokico HTS Shocks / Neuspeed Sport Springs / 18" Element SC Wheels / 225-45-18 / TSX Rotors / CR-V Dual Piston Calipers / Drum to Disk Conversion / SS Brake Lines / K&N SRI / Japspeed TSX Header / TSX IM / P2R Thermal Gaskets / Ralco Pulleys / HFP Front Lip / OEM Deck Lid Spoiler / TSX Mirrors / OEM Fogs / HID Retro-Fit / K40 251K
2009 ASM EX I-4 Auto Sedan: Weapon-R I Throttle / TL FSB & RSB / Morimoto H1 / OEM Fog / K40 / Viper 5704 101K
Old 06-24-2012, 08:45 AM
2006accord4 2006accord4 is offline
2006 I4 MT
Put everything back the way it was and pray you didn't damage anything.
2006 Accord LX Coupe I4 MT Silver, V6 battery upgrade, Front Lip, Blitzsafe V.3X aux/iPod adapter, Valentine 1, 57k miles
Old 06-24-2012, 09:46 AM
StrikingAccord's Avatar
StrikingAccord StrikingAccord is offline
Striking-A-Chord
Hopefully you didn't damage anything
I uninstalled my Ebay fogs
2004 Accord EX V6 Coupe
GO STEELERS!!
Old 06-24-2012, 12:36 PM
t-rd t-rd is offline
5th Gear
tear out the aftermarket wiring and put in factory ones, this is how I "fixed" mine. You can find entire sets of Honda OEM fog lights on ebay.
Old 06-24-2012, 12:49 PM
mobiless2's Avatar
mobiless2
The harness & switch are the weak link with the eBay fog lights. OEM harness & switch is inexpensive.
Old 06-24-2012, 01:24 PM
tintzbychavez tintzbychavez is offline
i got the ebay kit and made my own harness with relay... it has its own power, fuse, ground and switch, the only thing i tapped into was and ignition source so it turns off with the car.. other than that i can turn them on and use them as DRL...
Old 06-24-2012, 02:59 PM
I did take everything apart and reverse to the way everything was but it did not help. I will recheck the fuses again. Talking to a friend of mine, he seems to think the power to each of those items that are not working are not getting enough power. There could be a short somewhere in the connection. Ugh!
Old 06-24-2012, 11:32 PM
mc1114 mc1114 is offline
5th Gear
http://www.hondapartscheap.com/find-...FOGLIGHT%20KIT
What parts are required if only the ebay lights are used and the rest is OEM?
2006 Silver Coupe 6-6MT w/ Navi 83k
2006 Black Coupe 6-5AT (sold)
2005 Graphite Coupe 6-5AT (sold)
2003 Black Coupe 6-6MT (sold)
Old 06-25-2012, 05:29 AM
03LXV6's Avatar
03LXV6 03LXV6 is offline
Moderator
5, 7, 8, 9
2007 EX-L 4DR
Old 06-25-2012, 05:39 AM
5th Gear
The first thing I did when I bought my first set of ebay fog lights was throwing the wiring harness into the garbage. I then purchased the OEM wiring harness which doesn't require splicing of anything. A year later, the chrome inside the cheap housings started getting dull. I ended up buying OEM housings after that, which made a huge difference.
My original install had a short, and it was caused by the cheap made in china bulbs.
Old 06-25-2012, 08:57 AM
gen_unknown_7.5's Avatar
gen_unknown_7.5 gen_unknown_7.5 is offline
4th Gear
Send a message via AIM to gen_unknown_7.5
You would also need 6 on the list. I just installed my ebay fogs on Friday. I used the ebay wiring and everything worked out fine, however, I did have to cut and extend the harness that connects from the dash to the battery. The remote power source I tapped it into a black/yellow wire, near the main ignition wire (solid red).
2007 Accord SE Alabaster Silver Metallic Sedan
HIDs 6k, Tint F:23% R:17%, Complete LED Interior + License, OEM All-weather Mats, TL 20 RSB/27.2 FSB, USA-spec PA15-HON2, Decklid Spoiler, K&N drop in Air Filter, OEM window Visors, WeatherTech Bug Deflector, Modded front license plate, Inspire Fog Lights Reps (3k), Hybrid Tail Lights (Reps), Sypder Projector Headlights
Old 06-25-2012, 09:30 AM
cheap_deal cheap_deal is offline
3rd Gear
why isnt someone not coming up with a good harness along with the ebay fog light.
im sure they could make a lot of money.
2007 Accord 2.4lt A/T sedan
Old 06-25-2012, 11:34 AM
4th Gear
Demand is not THAT high. Accords are not known to be modded frequently. When I think of accord, I think its a family car, its reliable, and relatively more mature compared to a civic. Civic on the other hand, plenty of young people drive it, and there is a market for aftermarket parts as oppose to us accord folks. Just my 2 cents.
Old 06-25-2012, 11:45 AM
Valkyrie1911 Valkyrie1911 is offline
4th Gear
And this is the reason I went and paid the money for the OEM Honda kit. Too many stories of people screwing up their electrical systems. IMO you get what you pay for, hopefully you didn't do any damage. I've been happy with my OEM ones and you can get them onsale if you look. Still, $300 now, or much more later to repair possible electrical damage.
2004 Accord Coupe i4, San Marino Red
Current mod list: OEM fog light kit, Xenondepot LED interior and license plate kit (6k white), AEM Cold Air Intake
Future mod list: Tint, Retro HIDs, OEM style LED taillights, Coilovers, New wheels (07-08 TL Type-S I think)
